After importing library files, compiling indicates insufficient SRAM space
zenging
I am using S32K311, I added the library file to the project through new, after compiling, there will be an error. May I ask if there is any solution.
After I checked (Remove unused sections), it still does not work, and the same error will occur when compiling.
zenging
Hi, I need to add something extra because I saw an error message that seemed to be about a lack of Sram space.
So I made some changes to the (.ld) file to expand the SRAM space for normal compilation and debugging.
However, when I modified it and recompiled it, I found a hard fault. I would like to ask some questions.
1. Am I on the right path?
2. What should be done about this hard fault?
3. If my thinking is wrong, what method should I use to solve the problem I meet?
thank you
