Advance LC
Advance LC
609件の閲覧回数
HieuPh
I am trying to advance lifecycle of the board from CUST_DEL to OEM_PROD/SIMULATED_OEM_PROD by using almost service function on HSE_DEMOAPP_S32K3XX_0_2_40_0.
But the ECU is stuck in the while loop of HSE_MU_ReceiveResponseBlocking.
The same case is on the OTP-ATTR (ADKP, Debug Authorization mode), but it's perform after hard reset (ADKP provided, Debug mode changed), just advance lifecycle could not change.
Could you help me to explain the reason why and propose the solution?
Thank you,
0 返答(返信)
