ANFC_reader library interfacing
Lakhbir_01
I have been using the nfc and have used the aNfc_readerliberary but
I am getting conflict between AnfcRL_MemMap.h and MemAcc_MemMap.h
getting the following error  :
In file included from D:/Project/../../../aNFCReaderLibrary/intfs/phpalFelica.h:346,
from D:/Project/../../../../aNFCReaderLibrary/intfs/phNfcLib.h:85,
from D:/Project/WLC/../../../common/inc/phApp_Init.h:24,
from ../common/src/phApp_Init.c:13:
D:/Project/../../../../comps/phStubs/include/non_autosar/S32K3XX/AnfcRL_MemMap.h:7184:6: error: #error "MemMap.h, no valid memory mapping symbol defined."
7184 | #error "MemMap.h, no valid memory mapping symbol defined."
Julián_AragónM
Hi @Lakhbir_01,
This question needs to be redirected to the aNFC library team (contact: [email protected]), as we do not support the automotive NFC library through this support channel.
However, normally the MemMap error means that another module has already defined a section macro before the NFC library tries to define its own. If zero or more than one symbols are defined, this will cause errors.
Please check if you have all of the symbols necessary in your project's settings, or if you have all of the packages that aNFC library asks for integration.
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2329100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EANFC_reader%20library%20interfacing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2329100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20been%20using%20the%20nfc%20and%20have%20used%20the%20aNfc_readerliberary%20but%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EI%20am%20getting%20conflict%20between%20AnfcRL_MemMap.h%20and%20MemAcc_MemMap.h%3CBR%20%2F%3E%3CBR%20%2F%3Egetting%20the%20following%20error%26nbsp%3B%20%3A%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3EIn%20file%20included%20from%20D%3A%2FProject%2F..%2F..%2F..%2FaNFCReaderLibrary%2Fintfs%2FphpalFelica.h%3A346%2C%3CBR%20%2F%3Efrom%20D%3A%2FProject%2F..%2F..%2F..%2F..%2FaNFCReaderLibrary%2Fintfs%2FphNfcLib.h%3A85%2C%3CBR%20%2F%3Efrom%20D%3A%2FProject%2FWLC%2F..%2F..%2F..%2Fcommon%2Finc%2FphApp_Init.h%3A24%2C%3CBR%20%2F%3Efrom%20..%2Fcommon%2Fsrc%2FphApp_Init.c%3A13%3A%3CBR%20%2F%3ED%3A%2FProject%2F..%2F..%2F..%2F..%2Fcomps%2FphStubs%2Finclude%2Fnon_autosar%2FS32K3XX%2FAnfcRL_MemMap.h%3A7184%3A6%3A%20error%3A%20%23error%20%22MemMap.h%2C%20no%20valid%20memory%20mapping%20symbol%20defined.%22%3CBR%20%2F%3E7184%20%7C%20%23error%20%22MemMap.h%2C%20no%20valid%20memory%20mapping%20symbol%20defined.%22%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2329210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ANFC_reader%20library%20interfacing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2329210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259893%22%20target%3D%22_blank%22%3E%40Lakhbir_01%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThis%20question%20needs%20to%20be%20redirected%20to%20the%20aNFC%20library%20team%20(contact%3A%20%3CA%20href%3D%22mailto%3Aautomotive_nfc%40nxp.com%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eautomotive_nfc%40nxp.com%3C%2FA%3E)%2C%20as%20we%20do%20not%20support%20the%20automotive%20NFC%20library%20through%20this%20support%20channel.%3C%2FP%3E%0A%3CP%3EHowever%2C%20normally%20the%20MemMap%20error%20means%20that%20another%20module%20has%20already%20defined%20a%20section%20macro%20before%20the%20NFC%20library%20tries%20to%20define%20its%20own.%20If%20zero%20or%20more%20than%20one%20symbols%20are%20defined%2C%20this%20will%20cause%20errors.%3C%2FP%3E%0A%3CP%3EPlease%20check%20if%20you%20have%20all%20of%20the%20symbols%20necessary%20in%20your%20project's%20settings%2C%20or%20if%20you%20have%20all%20of%20the%20packages%20that%20aNFC%20library%20asks%20for%20integration.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
