AN5426 Typo Error?
AN5426 Typo Error?
2,289件の閲覧回数
dustin_wen
Dear Sir,
In AN5426, Hardware Design Guidelines for S32K1xx Microcontrollers, Rev. 4, Figure 20, Connection of I2C-bus devices to the I2C-bus. RP1 and RP2 both pull up SDA, and SCL is not pulled up.
I believe this is an typo error.  RP1 and RP2 should pull SDA and SCL respectively.
Regards.
タグ(1)
2,209件の閲覧回数
dianabatrlova
Dear Dustin Wen,
Thank you for your report. You are right, this is a typo.
I already reported this to the responsible team.
Diana
