ADC_Multiple_Channel with DMA
2,040件の閲覧回数
Bhuvana
Through DMA I'm reading adc channel 1st its working fine but in run time if I change value only 1st 8 channel is reading the correct data in remaining channels I'm not able to read the data its showing same old data only
3 返答(返信)
2,030件の閲覧回数
PetrS
2,025件の閲覧回数
Bhuvana
Hi @PetrS through this example only I have implemented but I have used only PDB0,ADC0 channels. Every thing is same but not able to identify the problem exactly.
2,002件の閲覧回数
PetrS
seems it is due to sample time is set to be inconsistent with PDB setting. Change ADC0 clock to run from FIRC DIV2 in Clocks tool. Set sample time = 14 in ADC component. Finally if 14 samples are read by DMA, then config 14 pretriggers in PDB0_init.
BR, Petr
