ADC Can not work by HardwareTrigger using s32k1xx RTD 1.0.1
1,047 次查看
laofu
Hi,@nxp
When i try to build a ADC project trigger by PDB using s32k1xx RTD1.0.1,it can not work,the configure and partial code as follow,do i should import the Pdb_Adc_Ip module?can you provide a example project?
1,028 次查看
Senlent
Hi@laofu
We provide the Adc_Pdb_Ip_example_S32K11x routine, which is implemented based on LLD. As for MCAL to realize PDB+ADC, we do not have such a routine. Seems like the PDB module is not defined in the MCAL standard.
1,012 次查看
laofu
thanks Senlent for you reply to me
