when try to use sudo command in bbclass in bsp37
814 次查看
irfank
When i try to use sudo command in bbclass(“sources/meta-alb/classes/image_types_fsl_flashimage.bbclass)in bsp37, i get below error. However, The same error is not exist when i execute outside bitbake. Also, When i try to use sudo command in bsp35, the same error is not exist, too.
0 回复数
