linux kernel debugging using s32g debug probe
yellapu_anishkh
Hi ,
I am using NXP S32G VNP EVB Board, i want to do step by step debugging of Linux kernel.
Able to compile and debug baremetal code. Not able to find any document which explains the procedure.
Could you please share the document, if this is possible with S32G Debug probe
Bio_TICFSL
Hello yellapu,
We have this document, https://www.nxp.com/docs/en/application-note/AN4980.pdf
https://www.nxp.com/docs/en/application-note/AN5128.pdf
Besides there are not from S32G processor it can help you with your design.
