flexcan enable
flexcan enable
Abhiram_m_s
I am trying to enable flexcan0 by building a patch for s32cc.dtsi file. After i enable, i am not able to see it in s32g3 board when i type ip link show. I have check the custom kernel config and it is enabled for flexcan. Can you please let me know how to proceed further.
Thank you
chenyin_h
Hello, @Abhiram_m_s
Thanks for the question.
May I know which version BSP you are working with? On a custom board or reference board from NXP?
I have checked the flexcan0/1 on RDB3 with BSP40, seems they are enabled by default and could work correctly.
Best Regards
Chenyin
