Upgrading RTD Drivers in EB Tresos Workspace
PZK
Hello Team,
I currently have a working project on the S32G274A board using the LLCE CAN driver (v1.0.2) and RTD drivers (Ethernet, Port, Platform, etc.) version 2.0.0. The EB Tresos configuration workspace for these drivers is functioning successfully for both CAN and Ethernet modules.
I’m now planning to upgrade the RTD (MCAL) drivers from version 2.0.0 to 5.0.0. I would like to understand the process for updating the driver version and regenerating the modules using EB Tresos, preferably by leveraging the existing workspace as a base.
Could you please guide me on the recommended steps or best practices for performing this upgrade?
Thank you!
chenyin_h
Hello, @PZK
Thanks for your post.
The version you ever used is quite old, for this kind of major version updating, I suggest regenerating the code/configuration, you may firstly select the following combination for reference:
LLCE1.0.10, RTD5.0.0QLP03 and others if needed(HSE FW0.2.64, PFE 1.6.0), because this combination was tested before official release.
Then change the settings referencing your previous work, and generate new code/configurations for the following building and testing.
Chenyin
%3CLINGO-SUB%20id%3D%22lingo-sub-2173504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUpgrading%20RTD%20Drivers%20in%20EB%20Tresos%20Workspace%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Team%2C%3C%2FP%3E%3CP%3EI%20currently%20have%20a%20working%20project%20on%20the%20S32G274A%20board%20using%20the%20LLCE%20CAN%20driver%20(v1.0.2)%20and%20RTD%20drivers%20(Ethernet%2C%20Port%2C%20Platform%2C%20etc.)%20version%202.0.0.%20The%20EB%20Tresos%20configuration%20workspace%20for%20these%20drivers%20is%20functioning%20successfully%20for%20both%20CAN%20and%20Ethernet%20modules.%3C%2FP%3E%3CP%3EI%E2%80%99m%20now%20planning%20to%20upgrade%20the%20RTD%20(MCAL)%20drivers%20from%20version%202.0.0%20to%205.0.0.%20I%20would%20like%20to%20understand%20the%20process%20for%20updating%20the%20driver%20version%20and%20regenerating%20the%20modules%20using%20EB%20Tresos%2C%20preferably%20by%20leveraging%20the%20existing%20workspace%20as%20a%20base.%3C%2FP%3E%3CP%3ECould%20you%20please%20guide%20me%20on%20the%20recommended%20steps%20or%20best%20practices%20for%20performing%20this%20upgrade%3F%3C%2FP%3E%3CP%3EThank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2173870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Upgrading%20RTD%20Drivers%20in%20EB%20Tresos%20Workspace%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242423%22%20target%3D%22_blank%22%3E%40PZK%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3EThe%20version%20you%20ever%20used%20is%20quite%20old%2C%20for%20this%20kind%20of%20major%20version%20updating%2C%20I%20suggest%20regenerating%20the%20code%2Fconfiguration%2C%20you%20may%20firstly%20select%20the%20following%20combination%20for%20reference%3A%3C%2FP%3E%0A%3CP%3ELLCE1.0.10%2C%20RTD5.0.0QLP03%20and%20others%20if%20needed(HSE%20FW0.2.64%2C%20PFE%201.6.0)%2C%20because%20this%20combination%20was%20tested%20before%20official%20release.%3C%2FP%3E%0A%3CP%3EThen%20change%20the%20settings%20referencing%20your%20previous%20work%2C%20and%20generate%20new%20code%2Fconfigurations%20for%20the%20following%20building%20and%20testing.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
