UDP Development with LWIP
1,827件の閲覧回数
Naveenkumar_Muthusamy
Hi all,
i am trying to develop the UDP application using the LWIP stack.
i have installed the TCP/IP stack and i have tested the TCP/IP code , ping is working for TCP/IP , but i need to develop UDP based application for sending data using UDP,
There was an example under udpecho.c file, for which i have created a new task, but in wireshark, i am unable to see any UDP packets,
Kindly help me in bring up #s32g2 @Daniel_aguirre
1,771件の閲覧回数
MayanksPatel
Hi @Naveenkumar_Muthusamy,
Hope you are doing well.
Can you please share TCP/IP Stack version?
Have you checked the for error in packet sending using UDP in firmware? is configuration of udp is proper?
Please share firmware changes done for switching tcp connection to udp connection.
Mayank s Patel
