STR fail when pfeng-slave enabled based on SDK BSP35 RC4
1,105 次查看
hittzt
Senior Contributor I
Hi experts,
I tested SDK BSP35 RC4 recently, and found that, the STR(Sleep To Ram) will fail(can not resume from suspend, and no console output), when pfeng-slave feature is enabled.
And the STR will work as normal if pfeng-slave is disabled.
So would you please help to confirm this issue?
Zhantao
1 回复
1,085 次查看
Daniel-Aguirre
Due to this information being related to a pre-release, we recommend sending it to your respective NXP representative or through the NXP online services for them to distributed as needed.
We do apologize for this.
