SOC:S32G378A - MM Query
1,343 次查看
mmayappa
I am referring to S32G3 RM, found S32G378A . I have some queries as below.
1) What is the meaning of this line wrt S32G378A
Cortex-A53_2 and Cortex-A53_3 have been de featured in cluster 0 and cluster 1.
2) How many A53 cores available and do they belong to the cpu cluster ?
1,301 次查看
Daniel-Aguirre
Below will be some comments on regards of your questions:
For the information that we can see on regards of S32G378A, the "defeatured" word refers to the A53_2 and A53_3 cores not available under both Cluster_0 and Cluster_1, meaning that the only cores available are A53_0 and A53_1 for each cluster, hence there are only 4 A53 cores available (2 A53 cores per cluster) [Page 5, S32G3 Data Sheet, Rev. 2, 02/2023]:
The answer seems to be contained under the above answer. There are 4 A53 cores, 2 per cluster.
Please, let us know.
