SAF eMCEM FCCU NMI handling
ソリューションへジャンプ
2,761件の閲覧回数
Harish_R
i have configured the NMI reaction in eMCEM module for particular fault. but im not sure how test it.
have configured NMI handler function. but when fault has been injected the NMI handler doesn't hit / execute.
if someone could drop some hints. it would be helpfull.
Harish R
2,690件の閲覧回数
chenyin_h
Hello, @Harish_R
Thanks for your reply.
I mean that since in your EB configuration, the NMI handler set is eMcemUserNmiHandler, and by default in SAF, the handler is NMI_Handler, may I know if you have changed it accordingly?
Chenyin
7 返答(返信)
2,691件の閲覧回数
chenyin_h
Hello, @Harish_R
Chenyin
2,627件の閲覧回数
Harish_R
Hi @chenyin_h
sorry for the delay,
"by default in SAF, the handler is NMI_Handler may I know if you have changed it accordingly"
change NMI handler.? i dint understand. where am i supposed to find this part? in stubs?
but
i have included this. should it be changed anywhere else?
BR,
Harish R
2,604件の閲覧回数
chenyin_h
Hello, @Harish_R
What I mean is, by default, the NMI handler is NMI_handler, which is defined in the vector table, and from your settings, the NMI handler is eMcemUserNmiHandler, how you put your own NMI handler to make it called?
Chenyin
2,711件の閲覧回数
chenyin_h
Hello, @Harish_R
May I know if you have placed your own NMI handler to the following part?
Chenyin
2,708件の閲覧回数
Harish_R
Hi @chenyin_h
yes, i have placed it accordingly.
when is it supposed to hit.? when NMI fault is triggered right?
in EB we configure. NMI Notification Function.
BR,
Harish R
2,744件の閲覧回数
chenyin_h
Hello, @Harish_R
Thanks for your post.
Would you mind sharing your eMcem configuration window? and also the SAF version used?
Chenyin
2,740件の閲覧回数
Harish_R
hi @chenyin_h
Thanks for your time!
Heres the simple configuration that i have for sram fault.
BR,
Harish R
