S32G399 DMA Transfer Time Question
1,963 次查看
Siyan
Hi, NXP,
I use DMA transfer data form NorFlash to SRAM for image loading.
Confused about the time it spending on data transfer.
Transfer total 4MB data from Nor to SRAM:
1.Use eDMA_0 only, it spends 28ms
2.Use eDMA_0 to transfer 2MB and eDMA_1 to transfer remain 2MB at the same time, it spends 50ms
Why is the time increasing instead of decreasing?
标记 (1)
3 回复数
1,953 次查看
Daniel-Aguirre
For S32G, it seems that the AHB interface is the limiting factor for eDMA under QSPI data transfers.
Please, let us know.
1,946 次查看
Siyan
Hi, Daniel,
Does NXP have any suggestion about how to reduce the image loading time.
If our product loads 20MB image from Nor to SRAM, it will spend about 28ms*5=140ms which is unacceptable.
1,932 次查看
Daniel-Aguirre
Thanks for your feedback.
At what frequency do you have configured the QSPI interface for booting?
