S32G3 memory map file
chennan
I can not find the S32G3 memory map file in the S32G3 Reference Manual ,where can i find?
Daniel-Aguirre
The memory map is attached as a file inside the PDF. You need a pdf reader that lets you see attached files to a pdf, as shown below:
Please, let us know.
