S32G3 LLCE on GoldVip image
5,151 次查看
MrAlexIV
I built and installed the GoldVip image on the SD card (using Yocto), as described in chapter 23 of the GoldVip-User-Manual.pdf, also including the components required for LLCE. When I boot the system, I can indeed see that the LLCE firmware is loaded. I also see that the llce_can entries in the DTS (attached) are set to “okay,” and in the .config I have:
CONFIG_CAN_LLCE=y
CONFIG_CAN_LLCE_CORE=y
CONFIG_CAN_LLCE_CONTROLLER=m
My problem, however, is that I don’t see the llce_can interfaces with ifconfig or ip link show; I only see can0 and can and can1 (which belong to FlexCAN).
How is this possible?
5,084 次查看
chenyin_h
Hello, @MrAlexIV
Thanks for your reply.
From the release notes, the BSP44 and LLCE1.0.10 are used in GoldVIP1.14, from the log, seems it was 1.0.9 used? would you mind checking it from your test?
Chenyin
12 回复数
599 次查看
lucindaschatz
tnx 4 post
650 次查看
GioMusto
Hi @MrAlexIV. I have the exact same problem. Did you find a solution?
4,507 次查看
chenyin_h
Hello, @MrAlexIV
Thanks for the reply.
The method provided could be used under pure BSP44, GoldVIP utilize the BSP44 for its A53 side implementation, however, it is a whole reference software for automotive purposes, all CAN uses are managed by the real time cores, therefore adding LLCE-CAN to Linux may not be successful.
I suggest referencing the chapter 14 of GoldVIP User Manual, to get details of how the LLCE-CAN are handled in the GoldVIP.
Chenyin
4,868 次查看
chenyin_h
Hello, @MrAlexIV
Glad to hear that the issue has been fixed
You are welcome.
Chenyin
4,988 次查看
chenyin_h
Hello, @MrAlexIV
I did a quick test with the BSP44 Yocto source directly, with the modification on the conf/local.conf
DISTRO_FEATURES:append = " llce-fw-load llce-can"
NXP_FIRMWARE_LOCAL_DIR = "PATH_TO_LLCEFW"
Once rebuilt, the llcecan0-15 could be seen from the linux shell.
Chenyin
4,872 次查看
MrAlexIV
I fixed the error for the BSP. It was a silly error name in the local.conf.
Thank you for your support
4,926 次查看
MrAlexIV
Thank you for your reply.
I tried with the BSP44.0, but I still can't see the interface. I used the lines you mentioned.
I attach the boot logs (with some operations I did).
Also, in the boot I can clearly see this message :
"[ 7.054478] llce_mb 43a00000.llce_mb: LLCE modules are under reset. Is the LLCE firmware loaded?
[ 7.062890] llce_mb: probe of 43a00000.llce_mb failed with error -13"
I uploaded the binaries before doing the build and changed the local.conf as you mentioned (the same procedure I did with the binaries of the LLCE 1.0.9, but at least there the firmware seemed uploaded).
5,085 次查看
chenyin_h
Hello, @MrAlexIV
Chenyin
4,531 次查看
MrAlexIV
I was able to build the BSP 44 image with the enabling of the LLCE FW.
Then I was trying to build my YOCTO image starting from the GoldVip base image and the attached local.conf file.
I managed to build the image, but when it is loaded on the SD card and the board is on, no LLCE interfaces appear in ifconfig output. Although, I can see the LLCE interfaces as enabled in the DTS file after the build (attached as well).
Can you explain how to face with this situation?
Thank you.
5,070 次查看
MrAlexIV
Thank you for the observation.
Yes, I was using 1.0.9, but I now re-builded with the 1.0.10.
Anyway, I always have the same problem (I do not see the interfaces). I also noticed that I can't start the board in booting in NOR Flash Boot Mode (log attached).
5,125 次查看
chenyin_h
Hello, @MrAlexIV
Thanks for your post.
1. May I know which version GoldVIP you are working with?
2. Would you mind sharing me with the full booting log from console?
Chenyin
5,122 次查看
MrAlexIV
I am using GoldVip 1.14.0
I attach the boot log in the following file
%3CLINGO-SUB%20id%3D%22lingo-sub-2156589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGoldVip%20%E5%9B%BE%E5%83%8F%E4%B8%8A%E7%9A%84%20S32G3%20LLCE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E5%9C%A8%20SD%20%E5%8D%A1%EF%BC%88%E4%BD%BF%E7%94%A8%20Yocto%EF%BC%89%E4%B8%8A%E6%9E%84%E5%BB%BA%E5%B9%B6%E5%AE%89%E8%A3%85%E4%BA%86%20GoldVIP%20%E9%95%9C%E5%83%8F%EF%BC%8C%E5%A6%82%20%3CSTRONG%3E%3CEM%3EGoldVip-User-Manual.pdf%3C%2FEM%3E%3C%2FSTRONG%3E%20%E7%AC%AC%2023%20%E7%AB%A0%E6%89%80%E8%BF%B0%EF%BC%8C%E8%BF%98%E5%8C%85%E6%8B%AC%20LLCE%20%E6%89%80%E9%9C%80%E7%9A%84%E5%85%83%E5%99%A8%E4%BB%B6%E3%80%82%E5%BD%93%E6%88%91%E5%90%AF%E5%8A%A8%E7%B3%BB%E7%BB%9F%E6%97%B6%EF%BC%8C%E6%88%91%E7%A1%AE%E5%AE%9E%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%20LLCE%20%E5%9B%BA%E4%BB%B6%E5%B7%B2%E5%8A%A0%E8%BD%BD%E3%80%82%E6%88%91%E8%BF%98%E7%9C%8B%E5%88%B0%20DTS%EF%BC%88%E9%99%84%E5%90%8E%EF%BC%89%E4%B8%AD%E7%9A%84%3CSTRONG%3Ellce_can%3C%2FSTRONG%3E%E6%9D%A1%E7%9B%AE%E8%A2%AB%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%22okay%22%EF%BC%8C%E8%80%8C%3CSTRONG%3E.config%20%3C%2FSTRONG%3E%E4%B8%AD%E7%9A%84%20%E6%88%91%E6%9C%89%3CBR%20%2F%3ECONFIG_CAN_LLCE%3Dy%3CBR%20%2F%3ECONFIG_CAN_LLCE_CORE%3Dy%3CBR%20%2F%3ECONFIG_CAN_LLCE_CONTROLLER%3Dm%3CBR%20%2F%3E%E4%BD%86%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%88%91%E5%9C%A8%20ifconfig%20%E6%88%96%20ip%20link%20show%20%E4%B8%AD%E7%9C%8B%E4%B8%8D%E5%88%B0%3CSTRONG%3Ellce_can%3C%2FSTRONG%3E%E6%8E%A5%E5%8F%A3%EF%BC%9B%E6%88%91%E5%8F%AA%E7%9C%8B%E5%88%B0%20can0%E3%80%81can%E5%92%8C%20can1%EF%BC%88%E5%B1%9E%E4%BA%8E%20FlexCAN%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%80%8E%E4%B9%88%E5%8F%AF%E8%83%BD%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252410%22%20target%3D%22_blank%22%3E%40MrAlexIV%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%8F%90%E4%BE%9B%E7%9A%84%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E5%9C%A8%E7%BA%AF%20BSP44%20%E4%B8%8B%E4%BD%BF%E7%94%A8%EF%BC%8CGoldVIP%20%E5%88%A9%E7%94%A8%20BSP44%20%E8%BF%9B%E8%A1%8C%20A53%20%E7%AB%AF%E5%AE%9E%E7%8E%B0%EF%BC%8C%E4%BD%86%E6%98%AF%EF%BC%8C%E5%AE%83%E6%98%AF%E4%B8%80%E4%B8%AA%3CSPAN%3E%E7%94%A8%E4%BA%8E%E6%B1%BD%E8%BD%A6%E7%94%A8%E9%80%94%E7%9A%84%E5%AE%8C%E6%95%B4%E5%8F%82%E8%80%83%E8%BD%AF%E4%BB%B6%EF%BC%8C%E6%89%80%E6%9C%89%20CAN%20%E7%94%A8%E9%80%94%E9%83%BD%E7%94%B1%E5%AE%9E%E6%97%B6%E5%86%85%E6%A0%B8%E7%AE%A1%E7%90%86%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%B0%86%20LLCE-CAN%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20Linux%20%E4%B8%AD%E5%8F%AF%E8%83%BD%E4%B8%8D%3C%2FSPAN%3E%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E5%8F%82%E8%80%83GoldVIP%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E7%9A%84%E7%AC%AC14%E7%AB%A0%EF%BC%8C%E8%AF%A6%E7%BB%86%E4%BA%86%E8%A7%A3GoldVIP%E5%A6%82%E4%BD%95%E5%A4%84%E7%90%86LLCE-CAN%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%90%AF%E7%94%A8%20LCE%20%E5%9B%BA%E4%BB%B6%E5%90%8E%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E5%BE%97%E4%BB%A5%E7%89%88%E6%9C%AC%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%2044%20%E6%98%A0%E5%83%8F%E3%80%82%3CBR%20%2F%3E%E7%84%B6%E5%90%8E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BB%8E%20GoldVIP%20%E5%9F%BA%E7%A1%80%E9%95%9C%E5%83%8F%E5%92%8C%E9%9A%8F%E9%99%84%E7%9A%84%E6%9C%AC%E5%9C%B0.conf%20%E6%96%87%E4%BB%B6%E5%BC%80%E5%A7%8B%E7%89%88%E6%9C%AC%E6%88%91%E7%9A%84%20YOCTO%20%E9%95%9C%E5%83%8F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E8%AE%BE%E6%B3%95%E7%89%88%E6%9C%AC%E4%BA%86%E9%95%9C%E5%83%8F%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E5%AE%83%E5%8A%A0%E8%BD%BD%E5%88%B0%20SD%20%E5%8D%A1%E4%B8%8A%E5%B9%B6%E4%B8%94%E6%9D%BF%E5%BC%80%E5%90%AF%E6%97%B6%EF%BC%8Cifconfig%20%E8%BE%93%E5%87%BA%E4%B8%AD%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%20LLCE%20%E6%8E%A5%E5%8F%A3%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E7%89%88%E6%9C%AC%E5%90%8E%E5%9C%A8%20DTS%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9C%8B%E5%88%B0%20LLCE%20%E6%8E%A5%E5%8F%A3%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%88%E4%B9%9F%E9%99%84%E5%9C%A8%E9%99%84%E4%BB%B6%E4%B8%AD%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%82%A8%E8%83%BD%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E5%A6%82%E4%BD%95%E9%9D%A2%E5%AF%B9%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252410%22%20target%3D%22_blank%22%3E%40MrAlexIV%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E9%AB%98%E5%85%B4%E5%90%AC%E5%88%B0%E9%97%AE%E9%A2%98%E5%B7%B2%E5%BE%97%E5%88%B0%E8%A7%A3%E5%86%B3%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%E5%AE%A2%E6%B0%94%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BF%AE%E5%A4%8D%E4%BA%86%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E8%BF%99%E6%98%AF%20local.conf%20%E4%B8%AD%E4%B8%80%E4%B8%AA%E6%84%9A%E8%A0%A2%E7%9A%84%E9%94%99%E8%AF%AF%E5%90%8D%E7%A7%B0%E3%80%82%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%82%3CBR%20%2F%3E%E6%88%91%E7%94%A8%20BSP44.0%20%E8%AF%95%E8%BF%87%E3%80%81%E4%BD%86%E6%88%91%E8%BF%98%E6%98%AF%E7%9C%8B%E4%B8%8D%E5%88%B0%E7%95%8C%E9%9D%A2%E3%80%82%E6%88%91%E7%94%A8%E4%BA%86%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E5%8F%B0%E8%AF%8D%E3%80%82%3CBR%20%2F%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%EF%BC%88%E8%BF%98%E6%9C%89%E6%88%91%E5%81%9A%E7%9A%84%E4%B8%80%E4%BA%9B%E6%93%8D%E4%BD%9C%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E6%88%91%E8%83%BD%E6%B8%85%E6%A5%9A%E5%9C%B0%E7%9C%8B%E5%88%B0%E8%BF%99%E6%9D%A1%E6%B6%88%E6%81%AF%EF%BC%9A%3CBR%20%2F%3E%3CEM%3E%22%20%5B7.054478%5D%20llce_mb%2043a00000.llce_mb%EF%BC%9ALLCE%20%E6%A8%A1%E5%9D%97%E5%A4%84%E4%BA%8E%20RESET%20%E7%8A%B6%E6%80%81%E3%80%82LCE%20%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E4%BA%86%3C%2FEM%3E%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CEM%3E%5B7.062890%5D%20llce_mb%EF%BC%9A%E5%AF%B9%2043a00000.llce_mb%20%E7%9A%84%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%E4%BA%86%EF%BC%8C%E9%94%99%E8%AF%AF%E6%98%AF%20-13%20%22%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E6%88%91%E5%9C%A8%E7%89%88%E6%9C%AC%E4%B9%8B%E5%89%8D%E4%B8%8A%E4%BC%A0%E4%BA%86%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%B9%B6%E6%8C%89%E7%85%A7%3C%2FEM%3E%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E6%9B%B4%E6%94%B9%E4%BA%86%20local.conf%EF%BC%88%E6%88%91%E5%AF%B9%20LCE%201.0.9%20%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E6%89%80%E5%81%9A%E7%9A%84%E8%BF%87%E7%A8%8B%E7%9B%B8%E5%90%8C%EF%BC%8C%E4%BD%86%E8%87%B3%E5%B0%91%E5%9B%BA%E4%BB%B6%E4%BC%BC%E4%B9%8E%E5%B7%B2%E7%BB%8F%E4%B8%8A%E4%BC%A0%E4%BA%86%EF%BC%89%E3%80%82%3CEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252410%22%20target%3D%22_blank%22%3E%40MrAlexIV%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%20BSP44%20Yocto%20%E6%BA%90%E7%A0%81%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%BF%AB%E9%80%9F%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%AF%B9%20conf%2Flocal.conf%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E4%BF%AE%E6%94%B9%3C%2FP%3E%0A%3CP%3EDISTRO_FEATURES%3Aappend%20%3D%22%20llce-fw-load%20llce-can%22%3CBR%20%2F%3E%20NXP_FIRMWARE_LOCAL_DIR%20%3D%22PATH_TO_LLCEFW%22%3C%2FP%3E%0A%3CP%3E%E9%87%8D%E5%BB%BA%E5%90%8E%EF%BC%8C%E5%B0%B1%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20linux%20shell%20%E7%9C%8B%E5%88%B0%20llcecan0-15%20%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%84%8F%E8%A7%81%E3%80%82%3CBR%20%2F%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%201.0.9%20%E7%89%88%EF%BC%8C%E4%BD%86%E6%88%91%E7%8E%B0%E5%9C%A8%E9%87%8D%E6%96%B0%E6%9E%84%E5%BB%BA%E4%BA%86%201.0.10%20%E7%89%88%E3%80%82%3CBR%20%2F%3E%E6%80%BB%E4%B9%8B%EF%BC%8C%E6%88%91%E6%80%BB%E6%98%AF%E9%81%87%E5%88%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%88%E6%88%91%E7%9C%8B%E4%B8%8D%E5%88%B0%E6%8E%A5%E5%8F%A3%EF%BC%89%E3%80%82%E6%88%91%E8%BF%98%E6%B3%A8%E6%84%8F%E5%88%B0%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E6%88%96%E9%9D%9E%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%90%AF%E5%8A%A8%E6%9D%BF%EF%BC%88%E9%99%84%E4%B8%8A%E6%97%A5%E5%BF%97%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252410%22%20target%3D%22_blank%22%3E%40MrAlexIV%3C%2FA%3E%20%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%EF%BC%8CGoldVIP1.14%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BA%86%20BSP44%20%E5%92%8C%20LLCE1.0.10%EF%BC%8C%E4%BB%8E%E6%97%A5%E5%BF%97%E6%9D%A5%E7%9C%8B%EF%BC%8C%E4%BC%BC%E4%B9%8E%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%201.0.9%20%E7%89%88%EF%BC%9F%E6%82%A8%E8%83%BD%E4%BB%8E%E6%82%A8%E7%9A%84%E6%B5%8B%E8%AF%95%E4%B8%AD%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%3CSTRONG%3EGoldVip%201.14.0%3CBR%20%2F%3E%3C%2FSTRONG%3E%E6%88%91%E5%9C%A8%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%E4%B8%AD%E9%99%84%E4%B8%8A%E4%BA%86%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252410%22%20target%3D%22_blank%22%3E%40MrAlexIV%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E8%AF%B7%E9%97%AE%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%20GoldVIP%EF%BC%9F%3C%2FP%3E%0A%3CP%3E2%E3%80%82%E4%BD%A0%E4%BB%8B%E6%84%8F%E5%92%8C%E6%88%91%E5%88%86%E4%BA%AB%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%9A%84%E5%AE%8C%E6%95%B4%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252410%22%20target%3D%22_blank%22%3E%40MrAlexIV%3C%2FA%3E%20%E3%80%82%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E4%B9%9F%E5%AE%8C%E5%85%A8%E4%B8%80%E6%A0%B7%E3%80%82%E4%BD%A0%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2393149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20LLCE%20on%20GoldVip%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2393149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A24%E6%9D%A1%E5%B8%96%E5%AD%90%3C%2FP%3E%3C%2FLINGO-BODY%3E
