S32G3 Internal RTC
S32G3 Internal RTC
77373
Is the example for using RTC as a wakeup source available under the M7 examples?
Thanks in advance!
77373
Hi, @alejandro_e
Thank you for your reply, I had create a ticket as tutorial.
https://support.nxp.com/s/case/500Te00000aJj7y/s32g3-internal-rtc
alejandro_e
Hello @77373,
Thanks for reaching out to us. I was not able to find RTC-wakeup examples delivered on the RTD, let me check internally if we have something that can match your requirements. I will get back to you once I have more information.
Thanks.
alejandro_e
Hello @77373,
To follow on this topic, please create a private ticket as described in this tutorial: Tutorial for NXP Support Case Portal. Please add the link to this post and my username so we can ensure I follow up with the topic.
Thanks in advance!
