S32G3 BSP41 PFE2 RGMII to RGMII without PHY on the customized board
XD
Our hardware design connects PFE2 RGMII directly to the switch RGMII without a PHY. The PFE2 is configured with rgmii-id, and we have verified the 125MHz TX clock output. I have come across discussions suggesting the use of a common external clock for both sides. Is clock drifting the only concern in this setup? If so, is it possible to configure PFE2 as a clock slave and use the clock output from the switch to synchronize TX and RX?
XD
alejandro_e
Hello @XD,
I can not access the technical information for the Marvell Switch, however, I see it is relatively similar to the SJA1110, for which you can check the following document: AN13335.pdf, in particular please check section 2.2 RGMII interface in page 8:
Let me know if this information solved your problem.
alejandro_e
Hello @XD,
It is good to support you again. About your question, please refer the the S32G3 - Hardware Design Guidelines, in particular please check sections: 10 Communication Peripherals, 10.1.1 RGMII signal routing requirements and 13.3 High-speed routing recommendations.
There you should be able to find all the relevant information about RGMII on a HW level.
Let me know if you have more questions about this topic.
XD
Hi @alejandro_e ,
It's great that you're helping me again—I really appreciate it.
The guideline you provided is for an RGMII-to-PHY scenario. Do you have any guidelines for a direct RGMII-to-RGMII connection without a PHY?
XD
alejandro_e
Hello @XD,
To the best of my knowledge the same guidelines should apply to any device connected using RGMII, either a PHY or a switch.
with that said, can you share the RGMII device you are connecting the S32G3 to? So I can check if there could be special considerations.
Thanks in advance.
XD
Hi @alejandro_e ,
We have a Marvell switch port running in RGMII mode, connected to PFE2 on our hardware.
XD
alejandro_e
Hello @XD,
XD
Hi @alejandro_e ,
Thank you again for your help. This information is very helpful.
XD
alejandro_e
Hello @XD,
I am glad you found the information helpful. Thanks for accepting my answer as a solution.
Alejandro
%3CLINGO-SUB%20id%3D%22lingo-sub-2034702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G3%20BSP41%20PFE2%20RGMII%20to%20RGMII%20without%20PHY%20on%20the%20customized%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2034702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EOur%20hardware%20design%20connects%20PFE2%20RGMII%20directly%20to%20the%20switch%20RGMII%20without%20a%20PHY.%20The%20PFE2%20is%20configured%20with%20rgmii-id%2C%20and%20we%20have%20verified%20the%20125MHz%20TX%20clock%20output.%20I%20have%20come%20across%20discussions%20suggesting%20the%20use%20of%20a%20common%20external%20clock%20for%20both%20sides.%20Is%20clock%20drifting%20the%20only%20concern%20in%20this%20setup%3F%20If%20so%2C%20is%20it%20possible%20to%20configure%20PFE2%20as%20a%20clock%20slave%20and%20use%20the%20clock%20output%20from%20the%20switch%20to%20synchronize%20TX%20and%20RX%3F%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EXD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2037874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20BSP41%20PFE2%20RGMII%20to%20RGMII%20without%20PHY%20on%20the%20customized%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2037874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F235130%22%20target%3D%22_blank%22%3E%40XD%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI%20am%20glad%20you%20found%20the%20information%20helpful.%20Thanks%20for%20accepting%20my%20answer%20as%20a%20solution.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EAlejandro%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20BSP41%20PFE2%20RGMII%20to%20RGMII%20without%20PHY%20on%20the%20customized%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F238460%22%20target%3D%22_blank%22%3E%40alejandro_e%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThank%20you%20again%20for%20your%20help.%20This%20information%20is%20very%20helpful.%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EXD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20BSP41%20PFE2%20RGMII%20to%20RGMII%20without%20PHY%20on%20the%20customized%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F235130%22%20target%3D%22_blank%22%3E%40XD%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI%20can%20not%20access%20the%20technical%20information%20for%20the%20Marvell%20Switch%2C%20however%2C%20I%20see%20it%20is%20relatively%20similar%20to%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2FSJA1110%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESJA1110%3C%2FA%3E%2C%20for%20which%20you%20can%20check%20the%20following%20document%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13335.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN13335.pdf%3C%2FA%3E%2C%20in%20particular%20please%20check%20section%26nbsp%3B%3CSTRONG%3E2.2%20RGMII%20interface%3C%2FSTRONG%3E%26nbsp%3Bin%20page%208%3A%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditoralejandro_e_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20id%3D%22tinyMceEditoralejandro_e_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-01-31%20115639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-01-31%20115639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F322028iAE0DA744BCA120F2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-01-31%20115639.png%22%20alt%3D%22Screenshot%202025-01-31%20115639.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ELet%20me%20know%20if%20this%20information%20solved%20your%20problem.%3C%2FP%3E%0A%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20BSP41%20PFE2%20RGMII%20to%20RGMII%20without%20PHY%20on%20the%20customized%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F238460%22%20target%3D%22_blank%22%3E%40alejandro_e%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EWe%20have%20a%20Marvell%20switch%20port%20running%20in%20RGMII%20mode%2C%20connected%20to%20PFE2%20on%20our%20hardware.%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EXD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2035865%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20BSP41%20PFE2%20RGMII%20to%20RGMII%20without%20PHY%20on%20the%20customized%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035865%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F235130%22%20target%3D%22_blank%22%3E%40XD%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ETo%20the%20best%20of%20my%20knowledge%20the%20same%20guidelines%20should%20apply%20to%20any%20device%20connected%20using%20RGMII%2C%20either%20a%20PHY%20or%20a%20switch.%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ewith%20that%20said%2C%20can%20you%20share%20the%20RGMII%20device%20you%20are%20connecting%20the%20S32G3%20to%3F%20So%20I%20can%20check%20if%20there%20could%20be%20special%20considerations.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20in%20advance.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2035790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20BSP41%20PFE2%20RGMII%20to%20RGMII%20without%20PHY%20on%20the%20customized%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F238460%22%20target%3D%22_blank%22%3E%40alejandro_e%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EIt's%20great%20that%20you're%20helping%20me%20again%E2%80%94I%20really%20appreciate%20it.%3C%2FP%3E%3CP%3EThe%20guideline%20you%20provided%20is%20for%20an%20RGMII-to-PHY%20scenario.%20Do%20you%20have%20any%20guidelines%20for%20a%20direct%20RGMII-to-RGMII%20connection%20without%20a%20PHY%3F%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EXD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2034885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20BSP41%20PFE2%20RGMII%20to%20RGMII%20without%20PHY%20on%20the%20customized%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2034885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F235130%22%20target%3D%22_blank%22%3E%40XD%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EIt%20is%20good%20to%20support%20you%20again.%20About%20your%20question%2C%20please%20refer%20the%20the%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUGS32G3HDG%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32G3%20-%20Hardware%20Design%20Guidelines%3C%2FA%3E%2C%20in%20particular%20please%20check%20sections%3A%26nbsp%3B%3CSTRONG%3E10%20Communication%20Peripherals%3C%2FSTRONG%3E%2C%26nbsp%3B%3CSTRONG%3E10.1.1%20RGMII%20signal%20routing%20requirements%26nbsp%3B%3C%2FSTRONG%3Eand%26nbsp%3B%3CSTRONG%3E13.3%20High-speed%20routing%20recommendations%3C%2FSTRONG%3E.%3C%2FP%3E%0A%3CP%3EThere%20you%20should%20be%20able%20to%20find%20all%20the%20relevant%20information%20about%20RGMII%20on%20a%20HW%20level.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ELet%20me%20know%20if%20you%20have%20more%20questions%20about%20this%20topic.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
