S32G2 load dtb
1,538件の閲覧回数
piaochunri
I got dts both in ATF and in kernal.When the board boots,Which dtb it will actually use?Or it will load both? Thank u.
1,498件の閲覧回数
Daniel-Aguirre
Both DTB/DTS will be used. When booting, TF-A/uboot will use the TF-A DTS/DTB, when uboot passes the control to the kernel, the kernel will use its own DTB/DTS. There is no conflict between both.
Both DTB/DTS should be configured accordingly, if not when uboot passes control to the kernel, devices might not be available to the kernel itself.
Please, let us know.
3 返答(返信)
1,524件の閲覧回数
Daniel-Aguirre
Both DTB's will be used at the end, but the one that is available under the root partition of the SD card should be the Kernel one.
1,505件の閲覧回数
piaochunri
Sorry,I can not understand well and could you describe it more detailed.I can find the same device in DTS both in ATF and kernal. Do they conflict with each other?
1,499件の閲覧回数
Daniel-Aguirre
%3CLINGO-SUB%20id%3D%22lingo-sub-1906259%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G2%20load%20dtb%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1906259%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFATF%E3%81%A8kernal%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7dts%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AEdtb%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E4%B8%A1%E6%96%B9%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1907146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20load%20dtb%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1907146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EDTB%2FDTS%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%E6%99%82%E3%81%AB%E3%81%AF%20TF-A%2FUBOOT%20%E3%81%AF%20TF-A%20DTS%2FDTB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81uboot%20%E3%81%8C%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E5%88%B6%E5%BE%A1%E3%82%92%E6%B8%A1%E3%81%99%E3%81%A8%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E8%87%AA%E8%BA%AB%E3%81%AE%20DTB%2FDTS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%A1%E8%80%85%E3%81%AE%E9%96%93%E3%81%AB%E7%9F%9B%E7%9B%BE%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EDTB%2FDTS%20%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%80%81uboot%20%E3%81%8C%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E5%88%B6%E5%BE%A1%E3%82%92%E6%B8%A1%E3%81%99%E3%81%A8%E3%81%8D%E3%81%AB%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E8%87%AA%E4%BD%93%E3%81%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1906848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20load%20dtb%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1906848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%82%88%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%AE%E3%81%A7%E3%80%81%E3%82%82%E3%81%A3%E3%81%A8%E8%A9%B3%E3%81%97%E3%81%8F%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82DTS%E3%81%A7%E3%81%AF%E3%80%81ATF%E3%81%A8kernal%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E5%90%8C%E3%81%98%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E4%BA%92%E3%81%84%E3%81%AB%E5%AF%BE%E7%AB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1906505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20load%20dtb%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1906505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AB%E4%B8%A1%E6%96%B9%E3%81%AEDTB%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%8B%E3%81%AB%E3%81%82%E3%82%8BDTB%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AEDTB%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
