S32G-PROCEVB3-S Blink LED
Thinh
Hello Supporter
We have an EVB3 Board and try simple setting up to verify
- S32G Vehicle Network Processing Evaluation Board 3 | NXP Semiconductors
  1. Try flashing one sample blob file from S32FT to verify the board is worked
  • C:\NXP\S32FlashTool_2.3.3\examples\S32G\SRAM\S32G_TestTransmission_921600_8E1_0x34080000_SRAM.bin
  • -> Good
  1. Now create a simple blinking LED step in this instruction apply to EVB3
  • Target to this demo is flashing 2 these LEDs
  1. Preparation setting up
  • Follow instruction create project but adapt to EVB3 (instruction applied to RDB)
  • Modify the .mex file
  • Generate successfully
  • Create the image (.blob) to program Flash (QSPI protocol) using IVT tool
  • Switch to Boot mode Serial
    • Power OFF the board from the SW10 switch
      J50: 1-2
      SW14: 1-OFF, 2-OFF
      SW15: 1-OFF, 2-ON
      J158: 3-5 and 4-6
  • Upload the algorithm file to QSPI
  • Then flashing .blob file
  • Turn off the board and switch to boot config
      J50: 1-2
      SW14: 1-ON, 2-OFF
      SW15: 1-OFF, 2-OFF
      J158: 3-5 and 4-6
      SW6: BOOTCFG[5:7]: 6-OFF, 7-OFF, 8-OFF
      SW7: All OFF
      SW8: All OFF
      SW9: All OFF
      Power ON the board
  • Wait sometimes but D14 and D15 LED not flashing
Would you please help to check my project uploaded in attachment above
Thank you,
Joey_z
hi,Thinh
Thank you for contacting us.
You can try to modify the demo of Port_Example_S32G399A_M7 for your application. You only need to modify the pin content for this demo.
Change the port in the Config Tool.
Then, click the "update code" button and build project to generate the Image.
Hope this can help you.
Joey
Thinh
Thank you Joey
But seem it not working yet after I flashing SW to M7 - No LED blinking yet
Would you please help to check the attachment, or can you please send me the blob bin file using SD card for checking.
Thank you,
Joey_z
hi,Thinh
Thank you for your information.
I have tried to test in my side.
If you set the pin Level value is the Low, you can find the LED light after initial the  Port_Init(NULL_PTR);.
If you also want to observe the LED blinking, you can try to modify the code as the following picture.
Joey
Thinh
Thank you Joey
I have tried but seem not working yet.
Please note that I created the blob image using IVT tool and flashing to QSPI
Would you please help to send me one .blob file which you can generated for me can verify in my EVB3-S?
Thank you
Joey_z
hi,Thinh
Thank you for your reply.
I will help you to check it.
Also, do you have any debugger for your Board?
Joey
Thinh
Currently using UART boot to flashing SW,
I am waiting ordered Debugger
Thinh
One question
What is the different between these 2 bin files in
As my understanding it boot to Single core - M7 (S32G_TestTransmission_921600_8E1_0x34080000_SRAM_SINGLE.bin) and Multicore (S32G_TestTransmission_921600_8E1_0x34080000_SRAM.bin)
Is that correct?
Because when flashing S32G_TestTransmission_921600_8E1_0x34080000_SRAM.bin -> It working
But when I used the same way but using S32G_TestTransmission_921600_8E1_0x34080000_SRAM_SINGLE.bin, nothing happen.
How can we use this S32G_TestTransmission_921600_8E1_0x34080000_SRAM_SINGLE.bin? I don't see it in any document
Thank you!
Thinh
Please note that target is running the project standalone single M7 Core only
Thinh
Here is my project sample attachment
%3CLINGO-SUB%20id%3D%22lingo-sub-2249084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G-PROCEVB3-S%20Blink%20LED%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Supporter%3C%2FP%3E%3CP%3EWe%20have%20an%20EVB3%20Board%20and%20try%20simple%20setting%20up%20to%20verify%3C%2FP%3E%3CP%3E-%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS32G-VNP-EVB3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32G%20Vehicle%20Network%20Processing%20Evaluation%20Board%203%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FP%3E%3COL%3E%3CLI%3ETry%20flashing%20one%20sample%20blob%20file%20from%20S32FT%20to%20verify%20the%20board%20is%20worked%3C%2FLI%3E%3C%2FOL%3E%3CUL%3E%3CLI%3EC%3A%5CNXP%5CS32FlashTool_2.3.3%5Cexamples%5CS32G%5CSRAM%5CS32G_TestTransmission_921600_8E1_0x34080000_SRAM.bin%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_0-1764141109499.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_0-1764141109499.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_0-1764141109499.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_0-1764141109499.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367281i522FAC4EC523673E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_0-1764141109499.png%22%20alt%3D%22Thinh_0-1764141109499.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_1-1764141168275.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_1-1764141168275.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_1-1764141168275.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_1-1764141168275.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367282i89CE642FCC62A15D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_1-1764141168275.png%22%20alt%3D%22Thinh_1-1764141168275.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E-%26gt%3B%20Good%3C%2FLI%3E%3C%2FUL%3E%3COL%3E%3CLI%3ENow%20create%20a%20simple%20blinking%20LED%20step%20in%20this%20instruction%20apply%20to%20EVB3%3C%2FLI%3E%3C%2FOL%3E%3CUL%3E%3CLI%3ETarget%20to%20this%20demo%20is%20flashing%202%20these%20LEDs%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_2-1764141339034.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_2-1764141339034.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_2-1764141339034.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_2-1764141339034.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367284iDF97D0A468FC6335%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_2-1764141339034.png%22%20alt%3D%22Thinh_2-1764141339034.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3COL%3E%3CLI%3EPreparation%20setting%20up%3C%2FLI%3E%3C%2FOL%3E%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_3-1764141624958.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_3-1764141624958.png%22%20style%3D%22width%3A%20359px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_3-1764141624958.png%22%20style%3D%22width%3A%20359px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_3-1764141624958.png%22%20style%3D%22width%3A%20359px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367285i8D4F4B0FAB220837%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_3-1764141624958.png%22%20alt%3D%22Thinh_3-1764141624958.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_4-1764141666454.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_4-1764141666454.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_4-1764141666454.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_4-1764141666454.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367286i4F0BF65E2AF1AFD8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_4-1764141666454.png%22%20alt%3D%22Thinh_4-1764141666454.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3EFollow%20instruction%20create%20project%20but%20adapt%20to%20EVB3%20(instruction%20applied%20to%20RDB)%3CUL%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Ftraining-presentation%2FTP-S32G-VNP-RDB3.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32G-VNP-RDB3%20Software%20Enablement%20Training%20Presentation%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3EModify%20the%20.mex%20file%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_5-1764141965121.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_5-1764141965121.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_5-1764141965121.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_5-1764141965121.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367289i5EE377EA0A9F8395%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_5-1764141965121.png%22%20alt%3D%22Thinh_5-1764141965121.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3EGenerate%20successfully%3C%2FLI%3E%3CLI%3ECreate%20the%20image%20(.blob)%20to%20program%20Flash%20(QSPI%20protocol)%20using%20IVT%20tool%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_6-1764142568033.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_6-1764142568033.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_6-1764142568033.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_6-1764142568033.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367297i84FE45AD960583F9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_6-1764142568033.png%22%20alt%3D%22Thinh_6-1764142568033.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3ESwitch%20to%20Boot%20mode%20Serial%3CUL%3E%3CLI%3EPower%20OFF%20the%20board%20from%20the%20SW10%20switch%3CBR%20%2F%3EJ50%3A%201-2%3CBR%20%2F%3ESW14%3A%201-OFF%2C%202-OFF%3CBR%20%2F%3ESW15%3A%201-OFF%2C%202-ON%3CBR%20%2F%3EJ158%3A%203-5%20and%204-6%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3EUpload%20the%20algorithm%20file%20to%20QSPI%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_8-1764142955886.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_8-1764142955886.png%22%20style%3D%22width%3A%20320px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_8-1764142955886.png%22%20style%3D%22width%3A%20320px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_8-1764142955886.png%22%20style%3D%22width%3A%20320px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367303i75F36B1A36328599%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_8-1764142955886.png%22%20alt%3D%22Thinh_8-1764142955886.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3EThen%20flashing%20.blob%20file%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_10-1764143088855.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_10-1764143088855.png%22%20style%3D%22width%3A%20277px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_10-1764143088855.png%22%20style%3D%22width%3A%20277px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_10-1764143088855.png%22%20style%3D%22width%3A%20277px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367307i1327A54F2FC298B3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_10-1764143088855.png%22%20alt%3D%22Thinh_10-1764143088855.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3ETurn%20off%20the%20board%20and%20switch%20to%20boot%20config%3CUL%3E%3CLI%3EPower%20OFF%20the%20board%20from%20the%20SW10%20switch%3CBR%20%2F%3EJ50%3A%201-2%3CBR%20%2F%3ESW14%3A%201-ON%2C%202-OFF%3CBR%20%2F%3ESW15%3A%201-OFF%2C%202-OFF%3CBR%20%2F%3EJ158%3A%203-5%20and%204-6%3CBR%20%2F%3ESW6%3A%20BOOTCFG%5B5%3A7%5D%3A%206-OFF%2C%207-OFF%2C%208-OFF%3CBR%20%2F%3ESW7%3A%20All%20OFF%3CBR%20%2F%3ESW8%3A%20All%20OFF%3CBR%20%2F%3ESW9%3A%20All%20OFF%3CBR%20%2F%3EPower%20ON%20the%20board%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3EWait%20sometimes%20but%20D14%20and%20D15%20LED%20not%20flashing%3C%2FLI%3E%3C%2FUL%3E%3CP%3EWould%20you%20please%20help%20to%20check%20my%20project%20uploaded%20in%20attachment%20above%3C%2FP%3E%3CP%3EThank%20you%2C%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-PROCEVB3-S%20Blink%20LED%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPlease%20note%20that%20target%20is%20running%20the%20project%20standalone%20single%20M7%20Core%20only%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-PROCEVB3-S%20Blink%20LED%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHere%20is%20my%20project%20sample%20attachment%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-PROCEVB3-S%20Blink%20LED%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20Joey%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBut%20seem%20it%20not%20working%20yet%20after%20I%20flashing%20SW%20to%20M7%20-%20No%20LED%20blinking%20yet%3C%2FP%3E%3CP%3EWould%20you%20please%20help%20to%20check%20the%20attachment%2C%20or%20can%20you%20please%20send%20me%20the%20blob%20bin%20file%20using%20SD%20card%20for%20checking.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EThank%20you%2C%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-PROCEVB3-S%20Blink%20LED%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20Joey%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20have%20tried%20but%20seem%20not%20working%20yet.%3C%2FP%3E%3CP%3EPlease%20note%20that%20I%20created%20the%20blob%20image%20using%20IVT%20tool%20and%20flashing%20to%20QSPI%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_0-1764218782745.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_0-1764218782745.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367489i074B67CD0123174C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_0-1764218782745.png%22%20alt%3D%22Thinh_0-1764218782745.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Thinh_1-1764218874847.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Thinh_1-1764218874847.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367490iE2B437ECF6BA6D6E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Thinh_1-1764218874847.png%22%20alt%3D%22Thinh_1-1764218874847.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EWould%20you%20please%20help%20to%20send%20me%20one%20.blob%20file%20which%20you%20can%20generated%20for%20me%20can%20verify%20in%20my%20EVB3-S%3F%3C%2FP%3E%3CP%3EThank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E
