S32G ETH2CAN Problem
Jacky888
Hi NXP team,
We are currently studying S32G3 ETH2CAN. According to “AN13423: Using CAN2CAN, CAN2ETH and ETH2CAN Features of LLCE on S32G Application Note”, after building int_app.elf, we need to use TRACE32 to debug the sample application.
Our questions are:
  1. If we do not have a TRACE32 debugger, can ETH2CAN still run?
  2. If yes, how should it be implemented?
Jacky
Joey_z
hi,Jacky
Thank you for contacting us.
>>>Yes, but the debugger is the good way to debug the code.
>>>You can try to create the Blob file of int_app.elf, and flash the Blob file to SD-card of Nor-Flash. Then, set the S32G to boot from SD of QSPI.
You can refer to this document for the boot from SD card.
https://community.nxp.com/pwmxy87654/attachments/pwmxy87654/S32G/7641/1/S32G-VNP-RDB2-SW-UG.pdf
Joey
%3CLINGO-SUB%20id%3D%22lingo-sub-2266558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G%20ETH2CAN%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%20team%2C%26nbsp%3B%3C%2FP%3E%3CP%3EWe%20are%20currently%20studying%20%3CSTRONG%3ES32G3%20ETH2CAN%3C%2FSTRONG%3E.%20According%20to%20%3CEM%3E%E2%80%9CAN13423%3A%20Using%20CAN2CAN%2C%20CAN2ETH%20and%20ETH2CAN%20Features%20of%20LLCE%20on%20S32G%20Application%20Note%E2%80%9D%3C%2FEM%3E%2C%20after%20building%20%3CSTRONG%3Eint_app.elf%3C%2FSTRONG%3E%2C%20we%20need%20to%20use%20%3CSTRONG%3ETRACE32%3C%2FSTRONG%3E%20to%20debug%20the%20sample%20application.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20from%202025-12-19%2014-36-15.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202025-12-19%2014-36-15.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370716iF85DE69A3B46636C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202025-12-19%2014-36-15.png%22%20alt%3D%22Screenshot%20from%202025-12-19%2014-36-15.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EOur%20questions%20are%3A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EIf%20we%20do%20not%20have%20a%20TRACE32%20debugger%2C%20can%20ETH2CAN%20still%20run%3F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EIf%20yes%2C%20how%20should%20it%20be%20implemented%3F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EJacky%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2266558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGoldVIP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20ETH2CAN%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%EF%BC%8CJacky%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20us.%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EIf%20we%20do%20not%20have%20a%20TRACE32%20debugger%2C%20can%20ETH2CAN%20still%20run%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26gt%3B%26gt%3B%26gt%3BYes%2C%20but%20the%20debugger%20is%20the%20good%20way%20to%20debug%20the%20code.%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EIf%20yes%2C%20how%20should%20it%20be%20implemented%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26gt%3B%26gt%3B%26gt%3BYou%20can%20try%20to%20create%20the%20Blob%20file%20of%20%3CSTRONG%3Eint_app.elf%3C%2FSTRONG%3E%2C%20and%20flash%20the%20Blob%20file%20to%20SD-card%20of%20Nor-Flash.%20Then%2C%20set%20the%20S32G%20to%20boot%20from%20SD%20of%20QSPI.%3C%2FP%3E%0A%3CP%3EYou%20can%20refer%20to%20this%20document%20for%20the%20boot%20from%20SD%20card.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2FS32G%2F7641%2F1%2FS32G-VNP-RDB2-SW-UG.pdf%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2FS32G%2F7641%2F1%2FS32G-VNP-RDB2-SW-UG.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E
