Re: S32G274A LLCE CAN
JACK_Q
当前自研板运行在多核模式下,1个A53核是用来和其他设备网络通信任务的,还有几个A53跑的是一些总线通信的驱动,每个类型的总线单独使用一个A53核。现在出现了一个问题是当前给LLCE CAN配置的恢复操作是设置LLCE CAN的模式先stop再start,在实际运行的场景大部分可以恢复通信的,但是有的时候会频繁的执行总线恢复以至于到影响其他的A53正常运行(网络通信任务中断)。想问的是LLCE CAN有那些方法可以总线恢复,还有是为什么LLCE CAN已经单独放置一个核运行还会影响到其他的核。以下是版本信息:S32G_LLCE_1_0_9;SW32G_RTD_4.4_4.0.2_P04_D2312
chenyin_h
Hello, @JACK_Q
您好
麻烦您详细介绍一下您的软硬件测试环境:
1. 在您的系统中,是M核和A核端同时使用吗?M7核运行什么任务?基于哪些软件包?
2. A53端从您的描述来看,每个核都有自己的任务,请问是运行的什么软件?是否是Linux BSP?
Chenyin
%3CLINGO-SUB%20id%3D%22lingo-sub-2415575%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G274A%20LLCE%20CAN%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415575%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20current%20self-developed%20board%20runs%20in%20multi-core%20mode.%20One%20A53%20core%20is%20used%20for%20network%20communication%20tasks%20with%20other%20devices%2C%20and%20several%20other%20A53%20cores%20run%20bus%20communication%20drivers%2C%20with%20each%20type%20of%20bus%20using%20a%20separate%20A53%20core.%20A%20problem%20has%20arisen%3A%20the%20current%20LLCE%20CAN%20recovery%20operation%20is%20configured%20to%20stop%20and%20then%20start%20the%20LLCE%20CAN%20mode.%20In%20most%20actual%20scenarios%2C%20communication%20can%20be%20restored%2C%20but%20sometimes%20bus%20recovery%20is%20executed%20frequently%2C%20affecting%20the%20normal%20operation%20of%20other%20A53%20cores%20(network%20communication%20tasks%20are%20interrupted).%20The%20questions%20are%3A%20what%20methods%20are%20available%20for%20LLCE%20CAN%20bus%20recovery%2C%20and%20why%20does%20having%20LLCE%20CAN%20running%20on%20a%20separate%20core%20still%20affect%20other%20cores%3F%20The%20version%20information%20is%3A%20S32G_LLCE_1_0_9%3B%20SW32G_RTD_4.4_4.0.2_P04_D2312%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415711%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274A%20LLCE%20CAN%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415711%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257205%22%20target%3D%22_blank%22%3E%40JACK_Q%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EHello%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20provide%20a%20detailed%20description%20of%20your%20software%20and%20hardware%20testing%20environment%3F%3C%2FP%3E%0A%3CP%3E1.%20In%20your%20system%2C%20are%20the%20M-core%20and%20A-core%20used%20simultaneously%3F%20What%20tasks%20does%20the%20M7%20core%20run%3F%20Which%20software%20packages%20does%20it%20rely%20on%3F%3C%2FP%3E%0A%3CP%3E2.%20From%20your%20description%2C%20each%20core%20on%20the%20A53%20side%20has%20its%20own%20task.%20What%20software%20is%20it%20running%3F%20Is%20it%20a%20Linux%20BSP%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
