PFE subsystem bring up on S32G2
14,929 次查看
aaronbaranoff
I am looking for a simple example of how to power up the PFE sub system and setting up the appropriate clocks. I have a driver that I have written that should work on a native A53 (no Linux).  The clocks never come up. I know that prior to me working on this logic I could not get the PFE registers to even read now they read but not everything is working and I have traced it down to this.
Here is the basic code to init the subsystem (this is very fragmented and not clearly explain by NXP) so any source example would be appreciated.
pfe_init(void)
    /* Enable */
    /* Setup DMA coherency */
    volatile uint32_t tries;
    RDC.RD2_CTRL_REG.B.RD2_CTRL_UNLOCK = 1;
    RDC.RD2_CTRL_REG.B.RD2_INTERCONNECT_INTERFACE_DISABLE = 0;
    tries = 0;
    while (RDC.RD2_STAT_REG.B.RD2_INTERCONNECT_INTERFACE_DISABLE_REQ_ACK_STAT != 0 )
        tries++;
        if (tries > MAX_TRIES)
            break;
    tries = 0;
    while (RDC.RD2_STAT_REG.B.RD2_INTERCONNECT_INTERFACE_DISABLE_STAT != 0)
        tries++;
            break;
    /**((volatile unsigned int *)0x4007ca00) = 0x3f; */
    S32G_GPR.PFE_COH_EN.B.DDR = true;
    S32G_GPR.PFE_COH_EN.B.HIF0 = true;
    S32G_GPR.PFE_COH_EN.B.HIF1 = true;
    S32G_GPR.PFE_COH_EN.B.HIF2 = true;
    S32G_GPR.PFE_COH_EN.B.HIF3 = true;
    S32G_GPR.PFE_COH_EN.B.UTIL = true;
    /* Setup EMAC modes -RGMII (ALL PFES)*/
    S32G_GPR.PFE_EMACX_INTF_SEL.B.EMAC0 = 2;
    S32G_GPR.PFE_EMACX_INTF_SEL.B.EMAC1 = 2;
    S32G_GPR.PFE_EMACX_INTF_SEL.B.EMAC2 = 2;
    /* Enable power for PFE */
    S32G_GPR.PFE_PWR_CTRL.B.PWRACK = 0;
    S32G_GPR.PFE_PWR_CTRL.B.PWRCLAMP = 0;
    S32G_GPR.PFE_PWR_CTRL.B.PWRDWN = 0;
    S32G_GPR.PFE_PWR_CTRL.B.PWRISO = 0;
    S32G_GPR.GENCTRL1.B.CTRL = 1;
    /* Setup & Enable the PFE Sys Clock */
    /* Setup and Enable the PFE PE Clock */
    S32G_GPR.LLCE_CTRL.B.EXEVENT = 0;
    S32G_GPR.LLCE_CTRL.B.LINDIVSEL = 0;
    S32G_GPR.LLCE_CTRL.B.LLCE_HTM0_TRC_DIS = 0;
    S32G_GPR.LLCE_CTRL.B.LLCE_HTM1_TRC_DIS = 0;
    S32G_GPR.LLCE_CTRL.B.LLCE_LSPI_TRIG_IN = 0;
    S32G_GPR.LLCE_CTRL.B.PFE_2_LLCE_INT_HS_BP = 0;
    /* Setup EMAC Tx/RX clocks */
    S32G_GPR.GENCTRL0.B.ACCEL_FLXNC_RD0_IDLEREQ = 0; /* normal operation */
    S32G_GPR.GENCTRL0.B.ACCEL_FLXNC_REF_DIV = 0; /* Divide by 2 */
    S32G_GPR.GENCTRL0.B.USBPWRFLT = 0;
    tries = 0;
    do {
        MC_ME.PRTN2_COFB0_CLKEN.B.REQ0 = 1;
        MC_ME.PRTN2_COFB0_CLKEN.B.REQ1 = 1;
        MC_ME.PRTN2_COFB0_CLKEN.B.REQ2 = 1;
        MC_ME.PRTN2_COFB0_CLKEN.B.REQ3 = 1;
        Write_Control_Key();
        MC_ME.PRTN2_PCONF.B.OSSE = 1;
        MC_ME.PRTN2_PCONF.B.PCE = 1;
        MC_ME.PRTN2_PUPD.B.OSSUD = 1;
        MC_ME.PRTN2_PUPD.B.PCUD = 1;
        /* Tell hardware to check above registers for changes */
        tries++;
            break; /* code dies here - the clocks never get enabled
                      therefore it does not come out of reset */
    } while (MC_ME.PRTN2_COFB0_STAT.R != 0xf);
    /* Put PFE in reset */
    MC_RGM.PRST_0[2].PRST_0.B.PERIPH_0_RST = 1;
    tries = 0;
    while (MC_RGM.PSTAT_0[2].PSTAT_0.B.PERIPH_0_STAT != 1)
        tries++;
            break;
    tries = 0;
    do {
        S32G_GPR.GENCTRL1.B.CTRL = 0;
        /* Take the PFE out of reset */
        MC_RGM.PRST_0[2].PRST_0.B.PERIPH_0_RST = 0;
        tries++;
            break;
    } while (MC_RGM.PSTAT_0[2].PSTAT_0.B.PERIPH_0_STAT == 1);
    MC_ME.PRTN2_PCONF.B.OSSE = 0;
    tries = 0;
    while (MC_RGM.PSTAT_0[2].PSTAT_0.B.PERIPH_0_STAT != 0)
        tries++;
            break;
标记 (2)
33 回复数
9,055 次查看
aaronbaranoff
None of the registers in the Red area are NOT accessible (readback 0 always). I can’t talk to them and your PFE code does not seem to use them (otherwise I would expect them to have non-zero values), so that seems to confirm the DMA interface is missing on the instantiations of the GMACs used for the PFE. So, the only way to send raw packets out of the PFE MACs is via the Slave interface (not documented by NXP) or the Debug Interface (which the registers are documented but not the sequence). Please Help and confirm or correct my suspicions.
10,870 次查看
aaronbaranoff
What time zone are you in maybe when can work interactively.
10,878 次查看
aaronbaranoff
Also added S32G_GPR
10,913 次查看
aaronbaranoff
Still no luck. PFE Partition does not fully initialize. The block clocks do not enable. There is no clear documentation on the expected sequence. The turn-on process is in Figure 148 of the S32G2 Reference Manual but it does not mention the block clocks (PRTN2_COFB0_STAT or PRTN2_COFB0_CLKEN). I am hoping some other user who has had luck with this can post an example bit of code. It comes out of reset and the PCS flag says the clocks are enabled but the block clocks don't get enabled but, not clue as to why. I even trying taking the exterenal clocks out of the picture. by using the FIRC.
After setting up (PFE_MACx_RX_CLK, PFE_MACx_TX_CLK, PFE_PE_CLK) to used the default FIRC. PFE partition still comes out of reset but the block clocks being enabled is ignored. I have tried that moving the block clock enable before and after the rest of the is PFE partition out of reset also no impact.
I have tried in EL1 and EL3 modes. I have even trying ignoring the PRTN2_COFB0_STAT regardless of my attempts to enable via  PRTN2_COFB0_CLKEN REQs if I ignore the status that then I can read the PFE registers but writing to some registers fail and the behavior is not correct. See Table 195.
I am using the RDB2 board (untill our board is ready) but have not had any luck.
10,905 次查看
aaronbaranoff
I even tried pushing this to the very early stages in the bootloader and had the same results.
MC_ME.PRTN2_COFB0_STAT.R is 0 (it should 0xf)...
WHY?!?
10,890 次查看
alejandro_e
Hello @aaronbaranoff,
As mentioned, it seems that the fact that MC_ME.PRTN2_COFB0_STAT.R is 0 is a know issue with only a workaround for now, skipping the check. The next thing I can think of to find the root cause is to compare your registers to mine, Please send a register dump of the MC_ME whole register rage, just before configuring PRTN2_COFB0_STAT, that way I can compare it to one of the available examples.
11,139 次查看
aaronbaranoff
Even the AUTOSAR code reports issues with similar things but no solution or clarity.
11,145 次查看
aaronbaranoff
What I am asking is not driver specific. This is a simple register (reference manual) question.
I am trying to get Blocks 0-3 to have their clocks enabled in PRTN2_COFB0_STAT.  Even if I wanted to use your driver per 47.4 I need to (Enable PFE COFB clocks in MC_ME as described in the "MC_ME partition 2 mapping" section in this document.)
This is basic sequence but it does not work and the datasheet does not give any insight as to anything else that is needed. The partition comes out of reset and Figure 148 in the Reference Manual does not cover enabling the block clocks inside the partition.
After this I read PRTN2_COFB0_STAT but the status never shows the clocks enabled.
11,087 次查看
alejandro_e
Thanks for the reference on the AUTOSAR driver bug, I checked internally the change related to that bug fix, the function that got changed is Power_Ip_MC_ME_ConfigureCOFB(), you can see the final implementation in the RTD 5.0.0 QLP3. For what I understand, the problem is not in the writing part of the process, but when reading to verify, you will see in the function that when POWER_IP_MC_ME_PRTN2_COFB0_STAT_RESERVED is defined ad STD_ON the validation for PartitionIndex is skipped. Checking the configuration files for any S32G you will see POWER_IP_MC_ME_PRTN2_COFB0_STAT_RESERVED is true, for example: Resource_TS_T40D11M50I0R0\resource\CORTEXM_S32G2XXM7_s32g274a_bga525.properties:
what I understand is that there is a known issue with that register validation and for now skipping it is the know workaround.
10,974 次查看
aaronbaranoff
I have replicated NXP's code but added checking. The PFE subsystem comes out of reset but the block level clocks do not enable. If I ignore the status the behavior is that I don't get link status although I can read many of the PFE GMAC registers when I write to the DMA registers the values don't stick.
I believe that the status is a clue but get NO insight as to why. I have enabled the clocks and the pin mux prior to the PFE init.
Are there any other rules about being in EL1 vs EL3 mode or similiar I don't see any in the documention.
10,936 次查看
alejandro_e
Can you elaborate on this statement?  "but the block level clocks do not enable. If I ignore the status the behavior is that I don't get link status although I can read many of the PFE GMAC registers when I write to the DMA registers the values don't stick."
I have checked the documentation and just as you, I did not see anything specific considering EL3 vs EL0, however, I would recommend using EL0 to avoid any issue accessing the memory regions.
11,186 次查看
alejandro_e
Thanks for reaching out to us again. At the movement I cannot share any resource that I have not shared before, for instance, the reference manual, FCI API documentation and code or code samples. Since the SW support for the A53 is very focused on Linux and the PFE being such a complicated module, I cannot offer you much support by looking at your program, I can suggest the same I always do, to check the already offered implementations and adapt them to your needs.
I can check internally if there is any plan to release more documents related to the PFE initialization, however I cannot ensure there will be anything helpful for your case.
I will get back to you
10,885 次查看
aaronbaranoff
Attached are the registers dumbs (in excel from the debugger)
10,502 次查看
alejandro_e
Sorry for such a delay in my reply. I was finally able to obtain the differences in the registers just before configuring the  PRTN2_COFB0_CLKEN register, you can find them in the xlsx file attached, you will find the differences marked with a red "X", each register dump is in a different page.
My registers were taken in this context:
10,391 次查看
aaronbaranoff
Thank you for the diffs. The only surprise was the CLKENs for the blocks inside the PFE were not set in the code you. Is that a known issue? I guess it is ignored or not needed.
0x0000000FEL1N:0x0000000040088530000000000x00000000
X
OK, my PFE GMAC has come out of reset and I have valid link status. However, I have one more issue. All the registers outside of the DMA read and write, I can see our writes written as expected. But the DMA ones (TX or RX) seemed to allow us to write (no errors) but the value does not stick (it reads back 0). Is there something else that I am missing. It is like there is an extra external step I need to get the PFE GMAC to come to life that is not documented.
10,347 次查看
aaronbaranoff
It behaves as if the internal clocks are not correct. But since the Subsystem bug does not let us read the status it is hard to tell. I have verified the PIn Mux is setup to the correct pins and the clocks look like they are setup correctly.
10,204 次查看
alejandro_e
You mean the registers in the PFE EMAC correct? this is, the same registers described in the GMAC reference manual.
If so, can you share a dump of all the registers, so that I can compare them with the registers state of the demo app just before sending.
Thanks in advance.
10,085 次查看
aaronbaranoff
Here is the registers just prior to me not being able to successfully write to DMA_CH0_RxDesc_Ring_Length and to DMA_CH0_RxDesc_List_Address. When I write to them and read back the value it reads back 0 even though I write a valid address.
I however can sucessfuly get the link status, write and readback registers like the MAC address.
This code is virtually identical to the code we are sucessfully using control the GMAC. But, on the PFE_MAC2 it does not allow use to read and write to certain registers. (mostly DMA related). In addition to the register comparison. Are the any other things outside of the PFE_MAC2 needed to enable its DMA (addition clocks or resets)?
So in my code. I added checks and the following fail.
    • DMA_CH0_TxDesc_List_Address  (failed readback)
    • DMA_CH0_TxDesc_Ring_Length  (failed readback)
    • DMA_CH0_RxDesc_List_Address  (failed readback)
    • DMA_CH0_RxDesc_Ring_Length  (failed readback)
    • MTL_TxQ0_Operation_Mode (is correct value but I can’t modify it)
    • MTL_RxQ0_Operation_Mode (is correct value but I can’t modify it)
    • MAC_RxQ_Ctrl0 (does not allow accept the write values)
10,082 次查看
aaronbaranoff
Also DMA_SysBus_Mode (failed readback). It is like an internal clock is not configured. But, I have not way of checking that since the PRTN2_COFB0_STAT always reports 0.
10,066 次查看
aaronbaranoff
Could you also compare my MC_CGM_2 registers to yours. I Think there is some clock that is missing and since all the PFE clocks are in that section.
%3CLINGO-SUB%20id%3D%22lingo-sub-2185790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20S32G2%20%E4%B8%8A%E8%B0%83%E5%87%BA%20PFE%20%E5%AD%90%E7%B3%BB%E7%BB%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%AF%BB%E6%89%BE%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E8%AF%B4%E6%98%8E%E5%A6%82%E4%BD%95%E5%90%AF%E5%8A%A8%20PFE%20%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B9%B6%E8%AE%BE%E7%BD%AE%E7%9B%B8%E5%BA%94%E7%9A%84%E6%97%B6%E9%92%9F%E3%80%82%E6%88%91%E7%BC%96%E5%86%99%E4%BA%86%E4%B8%80%E4%B8%AA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%9C%AC%E5%9C%B0%20A53%EF%BC%88%E6%B2%A1%E6%9C%89%20Linux%EF%BC%89%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%20%E6%97%B6%E9%92%9F%E4%BB%8E%E6%9C%AA%E5%87%BA%E7%8E%B0%E8%BF%87%E3%80%82%E6%88%91%E7%9F%A5%E9%81%93%EF%BC%8C%E5%9C%A8%E6%88%91%E7%A0%94%E7%A9%B6%E8%BF%99%E4%B8%AA%E9%80%BB%E8%BE%91%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E7%94%9A%E8%87%B3%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20PFE%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E7%8E%B0%E5%9C%A8%E5%AE%83%E4%BB%AC%E8%AF%BB%E5%8F%96%E4%BA%86%EF%BC%8C%E4%BD%86%E5%B9%B6%E9%9D%9E%E6%89%80%E6%9C%89%E4%B8%9C%E8%A5%BF%E9%83%BD%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%88%91%E5%B0%86%E5%85%B6%E5%BD%92%E7%BB%93%E4%B8%BA%E8%BF%99%E4%B8%AA%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E5%90%AF%E5%8A%A8%E5%AD%90%E7%B3%BB%E7%BB%9F%E7%9A%84%E5%9F%BA%E6%9C%AC%E4%BB%A3%E7%A0%81%EF%BC%88%E9%9D%9E%E5%B8%B8%E9%9B%B6%E6%95%A3%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E4%B9%9F%E6%B2%A1%E6%9C%89%E6%98%8E%E7%A1%AE%E8%A7%A3%E9%87%8A%EF%BC%89%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%83%BD%E6%8F%90%E4%BE%9B%E6%BA%90%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Epfe_init%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%2F*%20%E5%90%AF%E7%94%A8%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%2F*%20%E8%AE%BE%E7%BD%AE%20DMA%20%E4%B8%80%E8%87%B4%E6%80%A7%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%98%93%E5%8F%98%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ERDC%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ERD2_CTRL_REG%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ERD2_CTRL_UNLOCK%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ERDC%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ERD2_CTRL_REG%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ERD2_CTRL_REG%20.%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ERDC%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ERD2_STAT_REG%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ERD2_STAT_REG%20.%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMAX_TRIES%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%89%93%E7%A0%B4%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ERDC%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ERD2_STAT_REG%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ERD2_STAT_REG%20.%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMAX_TRIES%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%89%93%E7%A0%B4%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%2F**((volatile%20unsigned%20int%20*)0x4007ca00)%20%3D%200x3f%3B%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_COH_EN%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EDDR%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_COH_EN%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EHIF0%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_COH_EN%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EHIF1%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_COH_EN%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EHIF2%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_COH_EN%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EHIF3%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_COH_EN%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EUTIL%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%2F*%20%E8%AE%BE%E7%BD%AE%20EMAC%20%E6%A8%A1%E5%BC%8F%20-RGMII%20(ALL%20PFES)*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Epfe_emacx_intf_sel%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EEMAC0%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Epfe_emacx_intf_sel%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EEMAC1%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Epfe_emacx_intf_sel%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EEMAC2%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%2F*%20%E5%90%AF%E7%94%A8%20PFE%20%E7%94%B5%E6%BA%90%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_PWR_CTRL%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPWRACK%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_PWR_CTRL%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPWRCLAMP%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_PWR_CTRL%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPWRDWN%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_PWR_CTRL%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPWRISO%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EGENCTRL1%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ECTRL%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%2F*%20%E8%AE%BE%E7%BD%AE%26amp%3B%20%E5%90%AF%E7%94%A8%20PFE%20%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%2F*%20%E8%AE%BE%E7%BD%AE%E5%B9%B6%E5%90%AF%E7%94%A8%20PFE%20PE%20%E6%97%B6%E9%92%9F%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ELLCE_CTRL%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EEXEVENT%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ELLCE_CTRL%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ELINDIVSEL%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ELLCE_CTRL%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ellce_htm0_trc_dis%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ELLCE_CTRL%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ELLCE_HTM1_TRC_DIS%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ELLCE_CTRL%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ellce_lspi_trig_in%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ELLCE_CTRL%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPFE_2_LLCE_INT_HS_BP%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EGENCTRL1%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ECTRL%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%2F*%20%E8%AE%BE%E7%BD%AE%20EMAC%20Tx%2FRX%20%E6%97%B6%E9%92%9F%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EGENCTRL0%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eaccel_flxnc_rd0_idlereq%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%2F*%20%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EGENCTRL0%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eaccel_flxnc_ref_div%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%2F*%20%E9%99%A4%E4%BB%A5%202%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EGENCTRL0%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EUSBPWRFLT%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%81%9A%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprtn2_cofb0_clken%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EREQ0%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprtn2_cofb0_clken%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EREQ1%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprtn2_cofb0_clken%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EREQ2%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprtn2_cofb0_clken%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EREQ3%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%86%99%E5%85%A5%E6%8E%A7%E5%88%B6%E9%94%AE%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PCONF%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EOSSE%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PCONF%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPCE%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PUPD%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EOSSUD%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PUPD%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPCUD%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%2F*%20%E5%91%8A%E8%AF%89%E7%A1%AC%E4%BB%B6%E6%A3%80%E6%9F%A5%E4%B8%8A%E8%BF%B0%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%98%E5%8C%96%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%86%99%E5%85%A5%E6%8E%A7%E5%88%B6%E9%94%AE%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMAX_TRIES%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3Ebreak%3B%3C%2FSPAN%3E%3CSPAN%3E%20%3CFONT%20color%3D%22%23FF0000%22%3E%2F*%20%E4%BB%A3%E7%A0%81%E5%9C%A8%E8%BF%99%E9%87%8C%E5%A4%B1%E6%95%88-%E6%97%B6%E9%92%9F%E6%B0%B8%E8%BF%9C%E4%B8%8D%E4%BC%9A%E5%90%AF%E7%94%A8%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%20%EF%BC%8C%20%E5%9B%A0%E6%AD%A4%20RESET%20%E5%90%8E%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%20*%2F%3C%2FFONT%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%7D%20%3C%2FSPAN%3E%3CSPAN%3E%E8%80%8C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprtn2_cofb0_stat%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ER%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3E0xf%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%2F*%20RESET%20PFE%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_RGM%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRST_0%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%5D.%3C%2FSPAN%3E%3CSPAN%3EPRST_0%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPERIPH_0_RST%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EMC_RGM%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPSTAT_0%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%5D.%3C%2FSPAN%3E%3CSPAN%3EPSTAT_0%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPERIPH_0_STAT%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMAX_TRIES%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%89%93%E7%A0%B4%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%7D%20%20%20%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%81%9A%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ES32G_GPR%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EGENCTRL1%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ECTRL%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%2F*%20%E5%B0%86%20PFE%20%E4%BB%8E%20RESET%20%E4%B8%AD%E7%A7%BB%E9%99%A4%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_RGM%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRST_0%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%5D.%3C%2FSPAN%3E%3CSPAN%3EPRST_0%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPERIPH_0_RST%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PCONF%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EOSSE%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PCONF%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPCE%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PUPD%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EOSSUD%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PUPD%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPCUD%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%2F*%20%E5%91%8A%E8%AF%89%E7%A1%AC%E4%BB%B6%E6%A3%80%E6%9F%A5%E4%B8%8A%E8%BF%B0%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%98%E5%8C%96%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%86%99%E5%85%A5%E6%8E%A7%E5%88%B6%E9%94%AE%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMAX_TRIES%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%89%93%E7%A0%B4%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%7D%20%3C%2FSPAN%3E%3CSPAN%3E%E8%80%8C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EMC_RGM%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPSTAT_0%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%5D.%3C%2FSPAN%3E%3CSPAN%3EPSTAT_0%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPERIPH_0_STAT%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PCONF%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EOSSE%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PCONF%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPCE%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PUPD%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EOSSUD%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EMC_ME%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPRTN2_PUPD%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPCUD%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%2F*%20%E5%91%8A%E8%AF%89%E7%A1%AC%E4%BB%B6%E6%A3%80%E6%9F%A5%E4%B8%8A%E8%BF%B0%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%98%E5%8C%96%20*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%86%99%E5%85%A5%E6%8E%A7%E5%88%B6%E9%94%AE%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EMC_RGM%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPSTAT_0%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%5D.%3C%2FSPAN%3E%3CSPAN%3EPSTAT_0%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EB%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPERIPH_0_STAT%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMAX_TRIES%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%89%93%E7%A0%B4%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7D%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%85%B3%E4%BA%8E%20HIF%20%E5%8F%8A%E5%85%B6%E7%8E%AF%E5%BD%A2%E7%BC%93%E5%86%B2%E5%99%A8%E7%9A%84%E5%85%B7%E4%BD%93%E6%96%87%E4%BB%B6%E3%80%82%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E4%B8%8E%E5%A4%A7%E5%AE%B6%E5%88%86%E4%BA%AB%E4%BA%86%E6%9C%89%E5%85%B3%E3%80%8A%E6%AC%A7%E6%B4%B2%E5%B8%B8%E8%A7%84%E6%AD%A6%E8%A3%85%E5%8A%9B%E9%87%8F%E6%9D%A1%E7%BA%A6%E3%80%8B%E7%9A%84%E6%89%80%E6%9C%89%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E6%9B%B4%E5%A4%9A%E7%9A%84%E7%9B%B8%E5%85%B3%E6%96%87%E4%BB%B6%E4%BA%86%E3%80%82%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%20%3CEM%3ELNX%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%3C%2FEM%3E%E7%9A%84%E7%AC%AC%20%3CEM%3E2.1%20%E8%8A%82%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3%3C%2FEM%3E%E6%88%96%20%3CEM%3EPFE%20FCI%20API%20%E5%8F%82%E8%80%83%3C%2FEM%3E%E7%9A%84%E7%AC%AC%20%3CEM%3E11.5.2%20%E8%8A%82%E9%85%8D%E7%BD%AE%E7%A4%BA%E4%BE%8B%3C%2FEM%3E%E5%92%8C%20%3CEM%3E11.7%20Egress%20QoS%3C%2FEM%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%20%22%E6%97%A0%E5%A4%8D%E6%9D%82%E6%80%A7%20%22%E7%9A%84%E6%95%B0%E6%8D%AE%E5%8C%85%E6%94%B6%E5%8F%91%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E5%88%A9%E7%94%A8%20PFE%EF%BC%8C%E6%81%90%E6%80%95%E6%97%A0%E6%B3%95%E9%81%BF%E5%85%8D%E5%85%B6%E5%A4%8D%E6%9D%82%E6%80%A7%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E6%84%BF%E6%84%8F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20GMAC%20%E6%A8%A1%E5%9D%97%EF%BC%8C%E8%AF%A5%E6%A8%A1%E5%9D%97%E7%9B%B8%E5%BD%93%E7%AE%80%E5%8D%95%EF%BC%8C%E4%BD%86%E6%82%A8%E9%9C%80%E8%A6%81%E5%9C%A8%E4%B8%BB%E5%86%85%E6%A0%B8%E4%B8%AD%E5%A4%84%E7%90%86%E6%89%80%E6%9C%89%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%E5%85%B3%E4%BA%8E%20HIF%EF%BC%8C%E7%89%B9%E5%88%AB%E6%98%AF%E7%8E%AF%E5%BD%A2%E7%BC%93%E5%86%B2%E5%8C%BA%E7%BB%93%E6%9E%84%E5%92%8C%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%99%E6%A0%B7%E6%88%91%E5%B0%B1%E8%83%BD%E5%9C%A8%E4%B8%8D%E5%A4%8D%E6%9D%82%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%8F%91%E9%80%81%E5%92%8C%E6%8E%A5%E6%94%B6%E6%95%B0%E6%8D%AE%E5%8C%85%E3%80%82%E5%A6%82%E4%BD%95%E9%80%9A%E8%BF%87%20MTL%20%E4%B8%AD%E7%9A%84%20DEBUG%20FIFO%20%E6%8E%A5%E5%8F%A3%E4%BC%A0%E8%BE%93%E5%92%8C%E6%8E%A5%E6%94%B6%E6%95%B0%E6%8D%AE%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%E5%8F%91%E9%80%81%E4%BB%BB%E4%BD%95%E5%B8%A7%E4%B9%8B%E5%89%8D%E8%BF%9B%E8%A1%8C%E4%BA%86%E8%BD%AC%E5%82%A8%EF%BC%8C%E4%BB%A5%E6%98%BE%E7%A4%BA%20PFE%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E7%A1%AE%E5%88%87%E5%9C%B0%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20PFE%20%E5%8F%91%E9%80%81%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%8C%E6%88%91%E5%BC%BA%E7%83%88%E5%BB%BA%E8%AE%AE%E4%BD%A0%E6%9F%A5%E7%9C%8B%20PFE%20MCAL%20API%EF%BC%8C%E7%89%B9%E5%88%AB%E6%98%AF%EF%BC%8C%E6%A3%80%E6%9F%A5%E4%BB%8E%20example_application%5C%20src%5C%20sample_app_ethswt_eth.c%20%E5%BC%80%E5%A7%8B%E7%9A%84%E5%87%BD%E6%95%B0%E8%B0%83%E7%94%A8%EF%BC%8C%E5%9C%A8%20tst_PFE_sendDummyFrame%20()%20%E4%B8%AD%E6%9C%89%E5%AF%B9%20API%20eth_43_PFE_Transmit%20()%20%E7%9A%84%E8%B0%83%E7%94%A8%EF%BC%8CMCAL%20%E4%BB%A3%E7%A0%81%E5%8C%85%E6%8B%AC%E5%BE%88%E5%A4%9A%E8%BF%90%E8%A1%8C%E6%97%B6%E7%BC%96%E8%AF%91%E5%8F%AF%E8%83%BD%E5%AF%B9%E4%BD%A0%E6%B2%A1%E6%9C%89%E7%94%A8%E7%9A%84%E6%A3%80%E6%9F%A5%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E6%A0%B9%E6%8D%AE%E9%9C%80%E8%A6%81%E5%88%A0%E9%99%A4%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E8%BF%99%E6%98%AF%E5%85%B3%E4%BA%8E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20PFE%20%E5%8F%91%E9%80%81%E5%8A%9F%E8%83%BD%E7%9A%84%E6%9C%80%E4%BD%B3%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%BA%A2%E8%89%B2%E5%8C%BA%E5%9F%9F%E7%9A%84%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E5%9D%87%E4%B8%8D%E5%8F%AF%E8%AE%BF%E9%97%AE%EF%BC%88%E5%9B%9E%E8%AF%BB%E5%A7%8B%E7%BB%88%E4%B8%BA%200%EF%BC%89%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E4%B8%8E%E5%AE%83%E4%BB%AC%E5%AF%B9%E8%AF%9D%EF%BC%8C%E8%80%8C%E4%B8%94%E6%82%A8%E7%9A%84%20PFE%20%E4%BB%A3%E7%A0%81%E4%BC%BC%E4%B9%8E%E4%B9%9F%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%EF%BC%88%E5%90%A6%E5%88%99%E6%88%91%E5%B0%B1%E4%BC%9A%E8%AE%A4%E4%B8%BA%E5%AE%83%E4%BB%AC%E4%BC%9A%E6%9C%89%E9%9D%9E%E9%9B%B6%E5%80%BC%EF%BC%89%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%BF%99%E4%BC%BC%E4%B9%8E%E8%AF%81%E5%AE%9E%E4%BA%86%E5%9C%A8%20PFE%20%E4%BD%BF%E7%94%A8%E7%9A%84%20GMAC%20%E5%AE%9E%E4%BE%8B%E4%B8%AD%E7%BC%BA%E5%B0%91%20DMA%20%E6%8E%A5%E5%8F%A3%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%B0%86%E5%8E%9F%E5%A7%8B%E6%95%B0%E6%8D%AE%E5%8C%85%E4%BB%8EPFE%20Mac%E5%8F%91%E9%80%81%E5%87%BA%E5%8E%BB%E7%9A%84%E5%94%AF%E4%B8%80%E6%96%B9%E6%B3%95%E6%98%AF%E9%80%9A%E8%BF%87%E4%BB%8E%E6%9C%BA%E6%8E%A5%E5%8F%A3%EF%BC%88%E6%81%A9%E6%99%BA%E6%B5%A6%E6%9C%AA%E8%AE%B0%E5%BD%95%EF%BC%89%E6%88%96%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%EF%BC%88%E5%AF%84%E5%AD%98%E5%99%A8%E6%9C%89%E8%AE%B0%E5%BD%95%E4%BD%86%E6%9C%AA%E8%AE%B0%E5%BD%95%E9%A1%BA%E5%BA%8F%EF%BC%89%E3%80%82%E8%AF%B7%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%EF%BC%8C%E7%A1%AE%E8%AE%A4%E6%88%96%E7%BA%A0%E6%AD%A3%E6%88%91%E7%9A%84%E7%8C%9C%E6%B5%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aaronbaranoff_0-1762802760890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aaronbaranoff_0-1762802760890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364753iCAC932F2B3C6F3E7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aaronbaranoff_0-1762802760890.png%22%20alt%3D%22aaronbaranoff_0-1762802760890.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E8%BD%AC%E5%82%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%AF%94%E8%BE%83%E4%BD%A0%E5%92%8C%E6%88%91%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%E6%97%B6%E6%88%91%E5%8F%91%E7%8E%B0%E4%BD%A0%E6%B2%A1%E6%9C%89%E4%B8%BA%E4%BB%BB%E4%BD%95%E9%98%9F%E5%88%97%2F%E9%A2%91%E9%81%93%E5%AE%89%E8%A3%85%E6%8C%AF%E9%93%83%E7%BC%93%E5%86%B2%E5%8C%BA%E6%88%96%E5%88%97%E8%A1%A8%E5%9C%B0%E5%9D%80%E3%80%82%E9%82%A3%E6%82%A8%E6%98%AF%E5%A6%82%E4%BD%95%E5%8F%91%E9%80%81%E6%95%B0%E6%8D%AE%E5%8C%85%E7%9A%84%EF%BC%9F%E6%98%BE%E7%84%B6%E4%B8%8D%E6%98%AF%E8%AE%B0%E5%BD%95%E7%9A%84%20DMA%20%E6%8E%A5%E5%8F%A3%E3%80%82PFE%20MAC%20%E6%98%AF%E5%90%A6%E7%A6%81%E7%94%A8%E4%BA%86%E8%AF%A5%E6%8E%A5%E5%8F%A3%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E5%8F%91%E9%80%81%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%8A%B1%E6%AD%89%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%EF%BC%8C%E8%BF%99%E9%87%8C%E6%98%AF%E6%89%80%E6%9C%89%20PFE%20EMAC%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%88%E4%BB%8E%200x460A8000-0x460A936C%20%E5%BC%80%E5%A7%8B%EF%BC%89%E7%9A%84%E5%AE%8C%E6%95%B4%E8%BD%AC%E5%82%A8%E6%95%B0%E6%8D%AE%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%BB%E4%BD%95%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E6%9F%A5%E7%9C%8B%E5%99%A8%E8%BF%9B%E8%A1%8C%E6%A3%80%E6%9F%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%A5%E8%BD%AC%E5%AD%98%E6%98%AF%E5%9C%A8%E5%AE%8C%E6%88%90%E6%89%80%E6%9C%89%E5%88%9D%E5%A7%8B%E5%8C%96%E5%90%8E%E8%BF%9B%E8%A1%8C%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200121%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200121%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%E7%9A%84%E6%95%B0%E5%80%BC%E6%9C%89%E6%89%80%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EEL1N0xFFFF0000460A8800%20%E7%9A%84%E5%80%BC%E4%B8%BA%200x00003FF7%EF%BC%8C%E9%97%AE%E9%A2%98%E6%98%AF%E8%BF%99%E4%B8%8D%E6%98%AF%E4%B8%80%E4%B8%AA%E6%9C%89%E8%AE%B0%E5%BD%95%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9F%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E6%9F%A5%E7%9C%8B%E4%BA%86%E6%82%A8%E7%9A%84%20PFE%20%E9%85%8D%E7%BD%AE%E5%90%8E%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E5%AE%83%E4%B9%9F%E6%B2%A1%E6%9C%89%E5%AE%8C%E5%85%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%E6%82%A8%E5%B0%9A%E6%9C%AA%E5%86%99%E4%BF%A1%E7%BB%99%E5%90%8D%E5%8D%95%E4%B8%8A%E7%9A%84%E5%9C%B0%E5%9D%80%EF%BC%88%E6%88%96%E8%80%85%E6%82%A8%E6%97%A0%E6%B3%95%E5%86%99%E4%BF%A1%E7%BB%99%E5%90%8D%E5%8D%95%E4%B8%8A%E7%9A%84%E5%9C%B0%E5%9D%80%EF%BC%89%3C%2FP%3E%3CTABLE%20width%3D%22475%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22136%22%3E0x00000000%3C%2FTD%3E%3CTD%20width%3D%22176%22%3EEL1N%3A0xFFFF0000460A9114%3C%2FTD%3E%3CTD%20width%3D%2280%22%3E00000000%3C%2FTD%3E%3CTD%20width%3D%2283%22%3E0x00000000%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0x00000000%3C%2FTD%3E%3CTD%3EEL1N%3A0xFFFF0000460A9118%3C%2FTD%3E%3CTD%3E00000000%3C%2FTD%3E%3CTD%3E0x00000000%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0x00000000%3C%2FTD%3E%3CTD%3EEL1N%3A0xFFFF0000460A911C%3C%2FTD%3E%3CTD%3E00000000%3C%2FTD%3E%3CTD%3E0x00000000%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E8%BD%AC%E5%82%A8%E5%B9%B6%E6%AF%94%E8%BE%83%20ACCEL_PLL%20%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%EF%BC%8C%E6%A0%B9%E6%8D%AE%E6%96%87%E6%A1%A3%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%20600%20Mhz%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A1%AE%E4%BF%9D%E5%9C%A8%E6%AF%94%E8%BE%83%E4%B9%8B%E5%89%8D%E5%AE%8C%E5%85%A8%E5%90%AF%E7%94%A8%20PFE_MAC_2%20%E5%92%8C%E6%97%B6%E9%92%9F%E3%80%82%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aaronbaranoff_0-1762266317144.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aaronbaranoff_0-1762266317144.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363958i95440068A95BD270%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aaronbaranoff_0-1762266317144.png%22%20alt%3D%22aaronbaranoff_0-1762266317144.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aaronbaranoff_1-1762266376117.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aaronbaranoff_1-1762266376117.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363959i6E381FEDC035A9E6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aaronbaranoff_1-1762266376117.png%22%20alt%3D%22aaronbaranoff_1-1762266376117.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%98%AF%E7%B3%8A%E6%B6%82%E4%BA%86%EF%BC%8C%E8%BF%98%E6%98%AF%E6%BC%8F%E6%8E%89%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%E6%88%91%E8%AE%A4%E4%B8%BA%E6%88%91%E4%BB%AC%E7%9A%84%20PFE%20%E8%AE%BE%E7%BD%AE%E5%B7%B2%E7%BB%8F%E8%B6%B3%E5%A4%9F%E6%8E%A5%E8%BF%91%EF%BC%88MAC%20%E5%9C%B0%E5%9D%80%E5%92%8C%E5%85%B6%E4%BB%96%E9%9D%9E%E5%85%B3%E9%94%AE%E8%AE%BE%E7%BD%AE%EF%BC%89%E3%80%82%E4%BD%86%E6%88%91%E4%BB%AC%E7%9A%84%20CGM_2%20%E8%AE%BE%E7%BD%AE%E6%9C%89%E5%81%8F%E5%B7%AE%E3%80%82%E4%B9%9F%E8%AE%B8%E4%BD%A0%E8%BF%99%E8%BE%B9%E7%9A%84%E5%B7%AE%E5%BC%82%E6%98%AF%E5%9C%A8%E8%AE%BE%E7%BD%AE%E4%B9%8B%E5%89%8D%E6%8D%95%E8%8E%B7%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%96%87%E4%BB%B6%EF%BC%88%E8%A7%81%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%9B%BE%E7%89%87%EF%BC%89%EF%BC%8C%E7%94%A8%E4%BA%8E%20PFE_MAC2%E3%80%82%3C%2FP%3E%3CP%3ECGM_2%20Mux%200%20%E9%9C%80%E8%A6%81%E8%AE%BE%E7%BD%AE%E4%B8%BA%2033%20ACCEL_PLL_PH1_CLK%EF%BC%88%E4%B8%8E%E4%B9%8B%E5%8C%B9%E9%85%8D%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3ECGM2%20Mux%203%20%E9%9C%80%E8%A6%81%E8%AE%BE%E7%BD%AE%E4%B8%BA%20PERIPH_PLL_PHI5_CLK%EF%BC%88%E6%88%91%E5%B7%B2%E7%BB%8F%E8%AE%BE%E7%BD%AE%E4%BA%86%EF%BC%8C%E4%BD%86%E6%82%A8%E6%8C%87%E5%90%91%E7%9A%84%E6%98%AF%20FIRC_CLK%EF%BC%89%E3%80%82%20%3C%2FP%3E%3CP%3ECGM2%20Mux%206%20%E9%9C%80%E8%A6%81%E8%AE%BE%E7%BD%AE%E4%B8%BA%20PFE_MAC2_RX_CLK%EF%BC%88%E6%88%91%E5%B7%B2%E7%BB%8F%E8%AE%BE%E7%BD%AE%E4%BA%86%EF%BC%8C%E4%BD%86%E6%82%A8%E6%8C%87%E5%90%91%E7%9A%84%E6%98%AF%20FIRC_CLK%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aaronbaranoff_3-1762261984775.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aaronbaranoff_3-1762261984775.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363948i7638C5772BA4563E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aaronbaranoff_3-1762261984775.png%22%20alt%3D%22aaronbaranoff_3-1762261984775.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aaronbaranoff_2-1762260652031.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aaronbaranoff_2-1762260652031.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363944iA5BAABF96F01CDB7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aaronbaranoff_2-1762260652031.png%22%20alt%3D%22aaronbaranoff_2-1762260652031.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aaronbaranoff_0-1762260348653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aaronbaranoff_0-1762260348653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363941i711015EBDB4D1414%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aaronbaranoff_0-1762260348653.png%22%20alt%3D%22aaronbaranoff_0-1762260348653.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E5%8F%91%E7%8E%B0%E7%9A%84%E4%B8%8D%E5%90%8C%E4%B9%8B%E5%A4%84%EF%BC%8C%E6%A0%BC%E5%BC%8F%E4%B8%8E%E4%B8%8A%E6%AC%A1%E7%9B%B8%E5%90%8C%E3%80%82%E5%AF%B9%E4%BA%8E%20MC_CGM_2%EF%BC%8C%E6%88%91%E5%9C%A8%E4%B8%8E%E4%B8%8A%E6%AC%A1%E7%9B%B8%E5%90%8C%E7%9A%84%E8%A1%8C%E4%B8%AD%E5%81%9C%E6%AD%A2%E4%BA%86%E7%A8%8B%E5%BA%8F%EF%BC%9B%E5%AF%B9%E4%BA%8E%20PFE_EMAC%EF%BC%8C%E6%88%91%E5%9C%A8%E6%AD%A4%E5%A4%84%E5%81%9C%E6%AD%A2%E4%BA%86%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1762213117490.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1762213117490.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363777iA7FEDA9D353A161B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1762213117490.png%22%20alt%3D%22alejandro_e_0-1762213117490.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%9B%B4%E6%94%B9%E5%90%8E%E8%A1%8C%E4%B8%BA%E6%9C%89%E6%89%80%E4%B8%8D%E5%90%8C%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E6%95%B0%E6%8D%AE%E7%82%B9%E3%80%82%E6%88%91%E7%94%9A%E8%87%B3%E5%B0%9D%E8%AF%95%E5%B0%86%20PFE_MAC2%20%E7%BD%AE%E4%BA%8E%E7%8E%AF%E5%9B%9E%EF%BC%88%E9%80%9A%E8%BF%87%20MAC_CONFIGURATION%EF%BC%89%E5%AF%84%E5%AD%98%E5%99%A8%E7%AC%AC%2012%20%E4%BD%8D%E3%80%82%20%20%E4%BD%86%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E4%B8%8E%E8%BF%99%E4%BA%9B%20DMA%20%E7%9B%B8%E5%85%B3%E5%AF%84%E5%AD%98%E5%99%A8%E9%80%9A%E4%BF%A1%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E6%97%B6%E9%97%B4%E6%A3%80%E6%9F%A5%E8%BF%99%E4%BA%9B%E7%99%BB%E8%AE%B0%E7%B0%BF%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%B0%BD%E5%BF%AB%E7%BB%99%E6%82%A8%E5%9B%9E%E5%A4%8D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%90%A6%E5%B0%86%E6%88%91%E7%9A%84%20MC_CGM_2%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%8E%E4%BD%A0%E7%9A%84%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%EF%BC%9F%E6%88%91%E8%AE%A4%E4%B8%BA%E6%9C%89%E4%B8%80%E4%BA%9B%E9%92%9F%E4%B8%8D%E8%A7%81%E4%BA%86%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%89%80%E6%9C%89%E7%9A%84%20PFE%20%E9%92%9F%E8%A1%A8%E9%83%BD%E5%9C%A8%E9%82%A3%E4%B8%AA%E9%83%A8%E5%88%86%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%AD%A4%E5%A4%96%E8%BF%98%E6%9C%89%20DMA_SysBus_Mode%EF%BC%88%E5%9B%9E%E8%AF%BB%E5%A4%B1%E8%B4%A5%EF%BC%89%E3%80%82%E5%B0%B1%E5%83%8F%E6%B2%A1%E6%9C%89%E9%85%8D%E7%BD%AE%E5%86%85%E9%83%A8%E6%97%B6%E9%92%9F%E4%B8%80%E6%A0%B7%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E7%94%B1%E4%BA%8E%20PRTN2_COFB0_STAT%20%E5%A7%8B%E7%BB%88%E6%8A%A5%E5%91%8A%E4%B8%BA%200%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E8%BF%9B%E8%A1%8C%E6%A3%80%E6%9F%A5%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%97%A0%E6%B3%95%E6%88%90%E5%8A%9F%E5%86%99%E5%85%A5%20DMA_CH0_RxDesc_Ring_Length%20%E5%92%8C%20DMA_CH0_RxDesc_List_Address%20%E4%B9%8B%E5%89%8D%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%E5%BD%93%E6%88%91%E5%90%91%E5%AE%83%E4%BB%AC%E5%86%99%E5%85%A5%E5%B9%B6%E8%AF%BB%E5%9B%9E%E6%95%B0%E5%80%BC%E6%97%B6%EF%BC%8C%E5%8D%B3%E4%BD%BF%E6%88%91%E5%86%99%E5%85%A5%E7%9A%84%E6%98%AF%E4%B8%80%E4%B8%AA%E6%9C%89%E6%95%88%E5%9C%B0%E5%9D%80%EF%BC%8C%E8%AF%BB%E5%9B%9E%E7%9A%84%E6%95%B0%E5%80%BC%E4%B9%9F%E6%98%AF%200%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E8%8E%B7%E5%8F%96%E9%93%BE%E8%B7%AF%E7%8A%B6%E6%80%81%E3%80%81%E5%86%99%E5%85%A5%E5%92%8C%E5%9B%9E%E8%AF%BB%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%88%E5%A6%82%20MAC%20%E5%9C%B0%E5%9D%80%EF%BC%89%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AF%A5%E4%BB%A3%E7%A0%81%E4%B8%8E%E6%88%91%E4%BB%AC%E6%88%90%E5%8A%9F%E6%8E%A7%E5%88%B6%20GMAC%20%E7%9A%84%E4%BB%A3%E7%A0%81%E5%87%A0%E4%B9%8E%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8CPFE_MAC2%20%E4%B8%8D%E5%85%81%E8%AE%B8%E8%AF%BB%E5%86%99%E6%9F%90%E4%BA%9B%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82(%E4%B8%BB%E8%A6%81%E4%B8%8E%20DMA%20%E6%9C%89%E5%85%B3%EF%BC%89%E3%80%82%E9%99%A4%E4%BA%86%E5%AF%84%E5%AD%98%E5%99%A8%E6%AF%94%E8%BE%83%E4%B9%8B%E5%A4%96%E3%80%82%E9%99%A4%E4%BA%86%20PFE_MAC2%20%E4%B9%8B%E5%A4%96%E8%BF%98%E9%9C%80%E8%A6%81%E5%85%B6%E4%BB%96%E4%B8%9C%E8%A5%BF%E6%9D%A5%E5%90%AF%E7%94%A8%E5%85%B6%20DMA%EF%BC%88%E9%99%84%E5%8A%A0%E6%97%B6%E9%92%9F%E6%88%96%20RESET%EF%BC%89%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%88%91%E6%B7%BB%E5%8A%A0%E4%BA%86%E6%A3%80%E6%9F%A5%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%A6%82%E4%B8%8B%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3EDMA_CH0_TxDesc_List_Address%20%EF%BC%88%E5%9B%9E%E8%AF%BB%E5%A4%B1%E8%B4%A5%EF%BC%89%3C%2FLI%3E%3CLI%3EDMA_CH0_TxDesc_Ring_Length%20%EF%BC%88%E5%9B%9E%E8%AF%BB%E5%A4%B1%E8%B4%A5%EF%BC%89%3C%2FLI%3E%3CLI%3EDMA_CH0_RxDesc_List_Address%20%EF%BC%88%E5%9B%9E%E8%AF%BB%E5%A4%B1%E8%B4%A5%EF%BC%89%3C%2FLI%3E%3CLI%3EDMA_CH0_RxDesc_Ring_Length%20%EF%BC%88%E5%9B%9E%E8%AF%BB%E5%A4%B1%E8%B4%A5%EF%BC%89%3C%2FLI%3E%3CLI%3EMTL_TxQ0_Operation_Mode%EF%BC%88%E5%80%BC%E6%AD%A3%E7%A1%AE%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E4%BF%AE%E6%94%B9%EF%BC%89%3C%2FLI%3E%3CLI%3EMTL_RxQ0_Operation_Mode%EF%BC%88%E5%80%BC%E6%AD%A3%E7%A1%AE%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E4%BF%AE%E6%94%B9%EF%BC%89%3C%2FLI%3E%3CLI%3EMAC_RxQ_Ctrl0%EF%BC%88%E4%B8%8D%E5%85%81%E8%AE%B8%E6%8E%A5%E5%8F%97%E5%86%99%E5%85%A5%E5%80%BC%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%20PFE%20EMAC%20%E4%B8%AD%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E6%AD%A3%E7%A1%AE%E5%90%97%EF%BC%9F%E8%BF%99%E4%B8%8E%20GMAC%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E5%85%B1%E4%BA%AB%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E8%BD%AC%E5%82%A8%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E5%B0%86%E5%AE%83%E4%BB%AC%E4%B8%8E%E6%BC%94%E7%A4%BA%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%8F%91%E9%80%81%E5%89%8D%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E7%8A%B6%E6%80%81%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A2%84%E5%85%88%E8%A1%A8%E7%A4%BA%E6%84%9F%E8%B0%A2%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%B6%E8%A1%A8%E7%8E%B0%E5%B0%B1%E5%A5%BD%E5%83%8F%E5%86%85%E9%83%A8%E6%97%B6%E9%92%9F%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%E4%BD%86%E7%94%B1%E4%BA%8E%E5%AD%90%E7%B3%BB%E7%BB%9F%E9%94%99%E8%AF%AF%E6%97%A0%E6%B3%95%E8%AE%A9%E6%88%91%E4%BB%AC%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%BE%88%E9%9A%BE%E5%88%A4%E6%96%AD%E3%80%82%E6%88%91%E5%B7%B2%E7%A1%AE%E8%AE%A4%20PIn%20Mux%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%BC%95%E8%84%9A%EF%BC%8C%E6%97%B6%E9%92%9F%E7%9C%8B%E8%B5%B7%E6%9D%A5%E4%B9%9F%E8%AE%BE%E7%BD%AE%E6%AD%A3%E7%A1%AE%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E5%B7%AE%E5%BC%82%E3%80%82%E5%94%AF%E4%B8%80%E4%BB%A4%E4%BA%BA%E6%83%8A%E8%AE%B6%E7%9A%84%E6%98%AF%EF%BC%8CPFE%20%E5%86%85%E9%83%A8%E6%A8%A1%E5%9D%97%E7%9A%84%20CLKEN%20%E5%B9%B6%E6%B2%A1%E6%9C%89%E5%9C%A8%E4%BB%A3%E7%A0%81%E4%B8%AD%E8%AE%BE%E7%BD%AE%E3%80%82%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%88%91%E6%83%B3%E8%BF%99%E6%98%AF%E8%A2%AB%E5%BF%BD%E8%A7%86%E4%BA%86%EF%BC%8C%E6%88%96%E8%80%85%E6%98%AF%E4%B8%8D%E9%9C%80%E8%A6%81%E3%80%82%20%3C%2FP%3E%3CTABLE%20width%3D%22459%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%2279%22%3E0x0000000F%3C%2FTD%3E%3CTD%20width%3D%22172%22%3EEL1N%3A0x0000000040088530%3C%2FTD%3E%3CTD%20width%3D%2265%22%3E00000000%3C%2FTD%3E%3CTD%20width%3D%2279%22%3E0x00000000%3C%2FTD%3E%3CTD%20width%3D%2264%22%3E%3CP%3EX%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E7%9A%84%20PFE%20GMAC%20%E5%B7%B2%E7%BB%8F%E9%80%80%E5%87%BA%20RESET%20%E7%8A%B6%E6%80%81%E5%B9%B6%E4%B8%94%E6%88%91%E7%9A%84%E9%93%BE%E6%8E%A5%E7%8A%B6%E6%80%81%E6%9C%89%E6%95%88%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%20%E5%9C%A8%20DMA%20%E8%AF%BB%E5%86%99%E4%B9%8B%E5%A4%96%E7%9A%84%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%EF%BC%8C%E6%88%91%E9%83%BD%E8%83%BD%E7%9C%8B%E5%88%B0%E5%86%99%E5%85%A5%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8CDMA%EF%BC%88TX%20%E6%88%96%20RX%EF%BC%89%E4%BC%BC%E4%B9%8E%E5%85%81%E8%AE%B8%E6%88%91%E4%BB%AC%E5%86%99%E5%85%A5%EF%BC%88%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%EF%BC%89%EF%BC%8C%E4%BD%86%E6%95%B0%E5%80%BC%E5%8D%B4%E6%97%A0%E6%B3%95%E4%BF%9D%E7%95%99%EF%BC%88%E4%BC%9A%E8%AF%BB%E5%9B%9E%200%EF%BC%89%E3%80%82%E6%88%91%E8%BF%98%E6%BC%8F%E6%8E%89%E4%BA%86%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%E5%B0%B1%E5%A5%BD%E5%83%8F%E6%88%91%E9%9C%80%E8%A6%81%E9%A2%9D%E5%A4%96%E7%9A%84%E5%A4%96%E9%83%A8%E6%AD%A5%E9%AA%A4%E6%89%8D%E8%83%BD%E8%AE%A9%20PFE%20GMAC%20%E6%88%90%E7%9C%9F%EF%BC%8C%E8%80%8C%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%E5%B9%B6%E6%B2%A1%E6%9C%89%E8%AE%B0%E5%BD%95%E5%9C%A8%E6%A1%88%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E8%BF%9F%E8%BF%9F%E6%B2%A1%E6%9C%89%E5%9B%9E%E5%A4%8D%E3%80%82%E5%9C%A8%E9%85%8D%E7%BD%AE%20PRTN2_COFB0_CLKEN%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E7%BB%88%E4%BA%8E%E8%8E%B7%E5%BE%97%E4%BA%86%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%B7%AE%E5%BC%82%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%E9%99%84%E4%BB%B6%E4%B8%AD%E7%9A%84%20xlsx%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%89%BE%E5%88%B0%E5%AE%83%E4%BB%AC%EF%BC%8C%E4%BD%A0%E4%BC%9A%E5%8F%91%E7%8E%B0%E5%B7%AE%E5%BC%82%E7%94%A8%E7%BA%A2%E8%89%B2%22X%22%20%E6%A0%87%E8%AE%B0%EF%BC%8C%E6%AF%8F%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E8%BD%AC%E5%82%A8%E5%9C%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E9%A1%B5%E9%9D%A2%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9A%84%E7%99%BB%E8%AE%B0%E5%B0%B1%E6%98%AF%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%E8%BF%9B%E8%A1%8C%E7%9A%84%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1761785544655.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1761785544655.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363139iC93697C72C532393%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1761785544655.png%22%20alt%3D%22alejandro_e_0-1761785544655.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%89%80%E6%9C%89%E4%BF%A1%E6%81%AF%E3%80%82%E6%88%91%E8%AF%95%E7%9D%80%E6%B5%8B%E8%AF%95%20PFE%20%E6%BC%94%E7%A4%BA%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E5%9C%A8%E4%BD%BF%E7%94%A8%20S32%20%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%EF%BC%8C%E5%AF%BC%E8%87%B4%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E6%8C%89%E7%85%A7%E6%BC%94%E7%A4%BA%E7%A8%8B%E5%BA%8F%E8%AF%B4%E6%98%8E%E4%B8%AD%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E7%94%A8%E5%8A%B3%E7%89%B9%E5%B7%B4%E8%B5%AB%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E6%B2%A1%E6%9C%89%E5%B8%A6%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%8B%E5%91%A8%E5%8E%BB%E4%B9%B0%E4%B8%80%E4%B8%AA%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%E7%94%B5%E8%AF%9D%EF%BC%8C%E6%88%91%E5%92%8C%E6%88%91%E7%9A%84%E5%9B%A2%E9%98%9F%E4%B8%8D%E5%A4%84%E7%90%86%E4%B8%8E%E5%AE%A2%E6%88%B7%E7%9A%84%E9%80%9A%E8%AF%9D%EF%BC%8C%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E9%80%9A%E5%B8%B8%E9%9C%80%E8%A6%81%E8%8A%B1%E7%9B%B8%E5%BD%93%E9%95%BF%E7%9A%84%E6%97%B6%E9%97%B4%E6%9D%A5%E6%9F%A5%E6%89%BE%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%E4%BB%A5%E4%BE%BF%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E8%BF%9F%E8%BF%9F%E6%9C%AA%E6%94%B6%E5%88%B0%E7%9B%B8%E5%85%B3%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%9C%A8%E5%93%AA%E4%B8%AA%E6%97%B6%E5%8C%BA%EF%BC%8C%E4%B9%9F%E8%AE%B8%E4%BB%80%E4%B9%88%E6%97%B6%E5%80%99%E5%8F%AF%E4%BB%A5%E4%BA%92%E5%8A%A8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%98%E6%B7%BB%E5%8A%A0%E4%BA%86%20S32G_GPR%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9A%8F%E9%99%84%E5%AF%84%E5%AD%98%E5%99%A8%E6%95%B0%E6%8D%AE%EF%BC%88%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%AD%E7%9A%84%20excel%20%E6%A0%BC%E5%BC%8F%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191087%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191087%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E5%89%8D%E6%89%80%E8%BF%B0%EF%BC%8CMC_ME.PRTN2_COFB0_STAT.R%20%E4%B8%BA%200%20%E4%BC%BC%E4%B9%8E%E6%98%AF%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E7%9B%AE%E5%89%8D%E5%8F%AA%E6%9C%89%E8%B7%B3%E8%BF%87%E6%A3%80%E6%9F%A5%E8%BF%99%E4%B8%80%E5%8F%98%E9%80%9A%E5%8A%9E%E6%B3%95%E3%80%82%E4%B8%BA%E6%89%BE%E5%88%B0%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%EF%BC%8C%E6%88%91%E6%83%B3%E5%88%B0%E7%9A%84%E4%B8%8B%E4%B8%80%E4%B8%AA%E5%8A%9E%E6%B3%95%E6%98%AF%E5%B0%86%E6%82%A8%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%8E%E6%88%91%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%EF%BC%8C%E8%AF%B7%E5%8F%91%E9%80%81%20MC_ME%20%E6%95%B4%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E8%BD%AC%E5%82%A8%EF%BC%8C%E5%B0%B1%E5%9C%A8%E9%85%8D%E7%BD%AE%20PRTN2_COFB0_STAT%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E8%BF%99%E6%A0%B7%E6%88%91%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%85%B6%E4%B8%8E%E4%B8%80%E4%B8%AA%E5%8F%AF%E7%94%A8%E7%A4%BA%E4%BE%8B%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%94%9A%E8%87%B3%E5%B0%9D%E8%AF%95%E5%B0%86%E5%85%B6%E6%8E%A8%E9%80%81%E5%88%B0%E5%90%AF%E5%8A%A8%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%9C%80%E6%97%A9%E6%9C%9F%E9%98%B6%E6%AE%B5%EF%BC%8C%E7%BB%93%E6%9E%9C%E4%B9%9F%E6%98%AF%E4%B8%80%E6%A0%B7%E3%80%82%20%3C%2FP%3E%3CP%3EMC_ME.PRTN2_COFB0_STAT.R%20%E4%B8%BA%200%EF%BC%88%E5%BA%94%E4%B8%BA%200xf%EF%BC%89......%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%BA%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%98%E6%98%AF%E6%B2%A1%E6%89%BE%E5%88%B0%E3%80%82PFE%20%E5%88%86%E5%8C%BA%E6%9C%AA%E5%AE%8C%E5%85%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%E5%9D%97%E6%97%B6%E9%92%9F%E4%B8%8D%E5%90%AF%E7%94%A8%E3%80%82%E6%B2%A1%E6%9C%89%E5%85%B3%E4%BA%8E%E9%A2%84%E6%9C%9F%E9%A1%BA%E5%BA%8F%E7%9A%84%E6%98%8E%E7%A1%AE%E6%96%87%E4%BB%B6%E3%80%82%E5%BC%80%E6%9C%BA%E8%BF%87%E7%A8%8B%E5%9C%A8%20S32G2%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%9A%84%E5%9B%BE%20148%20%E4%B8%AD%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%8F%90%E5%8F%8A%E5%8C%BA%E5%9D%97%E6%97%B6%E9%92%9F%EF%BC%88PRTN2_COFB0_STAT%20%E6%88%96%20PRTN2_COFB0_STAT%20%E6%88%96%20PRTN2_COFB0_CLKEN%EF%BC%89%E3%80%82%E6%88%91%E5%B8%8C%E6%9C%9B%E5%85%B6%E4%BB%96%E5%9C%A8%E8%BF%99%E6%96%B9%E9%9D%A2%E6%9C%89%E7%BB%8F%E9%AA%8C%E7%9A%84%E7%94%A8%E6%88%B7%E8%83%BD%E6%8F%90%E4%BE%9B%E4%B8%80%E4%B8%AA%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%E3%80%82%E5%AE%83%E5%B7%B2RESET%EF%BC%8CPCS%20%E6%A0%87%E5%BF%97%E6%98%BE%E7%A4%BA%E6%97%B6%E9%92%9F%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E4%BD%86%E5%8C%BA%E5%9D%97%E6%97%B6%E9%92%9F%E6%9C%AA%E5%90%AF%E7%94%A8%EF%BC%8C%E4%BD%86%E4%B8%8D%E7%9F%A5%E9%81%93%E5%8E%9F%E5%9B%A0%E3%80%82%E6%88%91%E7%94%9A%E8%87%B3%E8%AF%95%E7%9D%80%E6%8A%8A%E8%82%BE%E5%A4%96%E9%92%9F%E6%8E%92%E9%99%A4%E5%9C%A8%E5%A4%96%E3%80%82%E9%80%9A%E8%BF%87%E4%BD%BF%E7%94%A8%20FIRC%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%AE%BE%E7%BD%AE%EF%BC%88PFE_MACx_RX_CLK%E3%80%81PFE_MACx_TX_CLK%E3%80%81PFE_PE_CLK%EF%BC%89%E5%90%8E%EF%BC%8C%E5%B0%86%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%9A%84%20FIRC%E3%80%82PFE%20%E5%88%86%E5%8C%BA%E4%BB%8D%E5%A4%84%E4%BA%8E%20RESET%20%E7%8A%B6%E6%80%81%EF%BC%8C%E4%BD%86%E5%B7%B2%E5%90%AF%E7%94%A8%E7%9A%84%E5%8C%BA%E5%9D%97%E6%97%B6%E9%92%9F%E4%BC%9A%E8%A2%AB%E5%BF%BD%E7%95%A5%E3%80%82%E6%88%91%E8%AF%95%E8%BF%87%E5%9C%A8%E5%89%A9%E4%BD%99%E7%9A%84%20PFE%20%E5%88%86%E5%8C%BA%E9%80%80%E5%87%BA%20RESET%20%E4%B9%8B%E5%89%8D%E5%92%8C%E4%B9%8B%E5%90%8E%E7%A7%BB%E5%8A%A8%E5%8C%BA%E5%9D%97%E6%97%B6%E9%92%9F%E5%90%AF%E7%94%A8%E4%B9%9F%E4%B8%8D%E4%BC%9A%E4%BA%A7%E7%94%9F%E4%BB%BB%E4%BD%95%E5%BD%B1%E5%93%8D%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%87%20EL1%20%E5%92%8C%20EL3%20%E6%A8%A1%E5%BC%8F%E3%80%82%E6%88%91%E7%94%9A%E8%87%B3%E5%B0%9D%E8%AF%95%E5%BF%BD%E7%95%A5%20PRTN2_COFB0_STAT%EF%BC%8C%E4%B8%8D%E7%AE%A1%E6%88%91%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%20PRTN2_COFB0_CLKEN%20REQs%20%E5%90%AF%E7%94%A8%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E5%BF%BD%E7%95%A5%E4%BA%86%E7%8A%B6%E6%80%81%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E5%B0%B1%E5%8F%AF%E4%BB%A5%E8%AF%BB%E5%8F%96%20PFE%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E4%BD%86%E5%90%91%E6%9F%90%E4%BA%9B%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%86%99%E5%85%A5%E5%8D%B4%E5%A4%B1%E8%B4%A5%E4%BA%86%EF%BC%8C%E8%80%8C%E4%B8%94%E8%A1%8C%E4%B8%BA%E4%B9%9F%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%E8%A7%81%E8%A1%A8%20195%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20RDB2%20%E6%9D%BF%EF%BC%88%E7%9B%B4%E5%88%B0%E6%88%91%E4%BB%AC%E7%9A%84%E6%9D%BF%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%EF%BC%89%EF%BC%8C%E4%BD%86%E8%BF%90%E6%B0%94%E4%B8%8D%E4%BD%B3%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aaronbaranoff_0-1761131927374.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aaronbaranoff_0-1761131927374.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362094i83FB42E3A575E7CF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aaronbaranoff_0-1761131927374.png%22%20alt%3D%22aaronbaranoff_0-1761131927374.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aaronbaranoff_1-1761131980418.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aaronbaranoff_1-1761131980418.png%22%20style%3D%22width%3A%20387px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362095i840D227CADDED8EA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aaronbaranoff_1-1761131980418.png%22%20alt%3D%22aaronbaranoff_1-1761131980418.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E8%AF%A6%E7%BB%86%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E8%BF%99%E5%8F%A5%E8%AF%9D%E5%90%97%EF%BC%9F%20%22%E4%BD%86%E5%9D%97%E7%BA%A7%E6%97%B6%E9%92%9F%E4%B8%8D%E4%BC%9A%E5%90%AF%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E5%BF%BD%E7%95%A5%E7%8A%B6%E6%80%81%EF%BC%8C%E8%99%BD%E7%84%B6%E5%8F%AF%E4%BB%A5%E8%AF%BB%E5%8F%96%E8%AE%B8%E5%A4%9A%20PFE%20GMAC%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%90%91%20DMA%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%86%99%E5%85%A5%E6%95%B0%E6%8D%AE%E6%97%B6%EF%BC%8C%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%97%E9%93%BE%E6%8E%A5%E7%8A%B6%E6%80%81%E3%80%82%22%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%9F%A5%E7%9C%8B%E4%BA%86%E6%96%87%E6%A1%A3%EF%BC%8C%E5%92%8C%E4%BD%A0%E4%B8%80%E6%A0%B7%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E4%BB%BB%E4%BD%95%E5%85%B3%E4%BA%8E%20EL3%20%E5%92%8C%20EL0%20%E7%9A%84%E5%85%B7%E4%BD%93%E8%AF%B4%E6%98%8E%EF%BC%8C%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%20EL0%EF%BC%8C%E4%BB%A5%E9%81%BF%E5%85%8D%E8%AE%BF%E9%97%AE%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%A4%8D%E5%88%B6%E4%BA%86%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E5%A2%9E%E5%8A%A0%E4%BA%86%E6%A3%80%E6%9F%A5%E5%8A%9F%E8%83%BD%E3%80%82PFE%20%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%20RESET%EF%BC%8C%E4%BD%86%E6%A8%A1%E5%9D%97%E7%BA%A7%E6%97%B6%E9%92%9F%E6%9C%AA%E5%90%AF%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E5%BF%BD%E7%95%A5%E7%8A%B6%E6%80%81%EF%BC%8C%E8%99%BD%E7%84%B6%E5%8F%AF%E4%BB%A5%E8%AF%BB%E5%8F%96%E8%AE%B8%E5%A4%9A%20PFE%20GMAC%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%90%91%20DMA%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%86%99%E5%85%A5%E6%95%B0%E6%8D%AE%E6%97%B6%EF%BC%8C%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%97%E9%93%BE%E6%8E%A5%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%B8%E4%BF%A1%E7%8A%B6%E6%80%81%E6%98%AF%E4%B8%80%E6%9D%A1%E7%BA%BF%E7%B4%A2%EF%BC%8C%E4%BD%86%E5%8D%B4%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E3%80%82%E5%9C%A8%E5%90%AF%E5%8A%A8%20PFE%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E5%90%AF%E7%94%A8%E4%BA%86%E6%97%B6%E9%92%9F%E5%92%8C%E5%BC%95%E8%84%9A%E5%A4%8D%E7%94%A8%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%20EL1%20%E4%B8%8E%20EL3%20%E6%A8%A1%E5%BC%8F%E6%88%96%E7%B1%BB%E4%BC%BC%E6%A8%A1%E5%BC%8F%EF%BC%8C%E6%88%91%E5%9C%A8%E6%96%87%E6%A1%A3%E4%B8%AD%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E8%A7%84%E5%AE%9A%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2188546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%20AUTOSAR%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%94%99%E8%AF%AF%E7%9A%84%E5%8F%82%E8%80%83%EF%BC%8C%E6%88%91%E5%9C%A8%E5%86%85%E9%83%A8%E6%A3%80%E6%9F%A5%E4%BA%86%E4%B8%8E%E8%AF%A5%E9%94%99%E8%AF%AF%E4%BF%AE%E5%A4%8D%E7%9B%B8%E5%85%B3%E7%9A%84%E6%9B%B4%E6%94%B9%EF%BC%8C%E6%9B%B4%E6%94%B9%E7%9A%84%E5%87%BD%E6%95%B0%E6%98%AF%20p%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eower_ip_mc_me_configureCOFB%20()%3C%2FFONT%3E%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%20RTD%205.0.0%20%E4%B8%AD%E7%9C%8B%E5%88%B0%E6%9C%80%E7%BB%88%E7%9A%84%E5%AE%9E%E7%8E%B0QLP3.%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E9%97%AE%E9%A2%98%E4%B8%8D%E5%87%BA%E5%9C%A8%E5%86%99%E5%85%A5%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E8%80%8C%E6%98%AF%E5%9C%A8%E8%AF%BB%E5%8F%96%E9%AA%8C%E8%AF%81%E6%97%B6%EF%BC%8C%E4%BD%A0%E4%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E4%B8%AD%E7%9C%8B%E5%88%B0%EF%BC%8C%E5%BD%93%20POWER_IP_MC_ME_PRTN2_COFB0_STAT_RESERVED%20%E8%A2%AB%E5%AE%9A%E4%B9%89%E4%B8%BA%20ad%20STD_ON%20%E6%97%B6%EF%BC%8C%E5%88%86%E5%8C%BA%E7%B4%A2%E5%BC%95%E7%9A%84%E9%AA%8C%E8%AF%81%E4%BC%9A%E8%A2%AB%E8%B7%B3%E8%BF%87%E3%80%82%E6%A3%80%E6%9F%A5%E4%BB%BB%E4%BD%95%20S32G%20%E7%9A%84%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%8C%E9%83%BD%E4%BC%9A%E5%8F%91%E7%8E%B0%20POWER_IP_MC_ME_PRTN2_COFB0_STAT_RESERVED%20%E4%B8%BA%20true%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3CEM%3EResource_TS_T40D11M50I0R0%5Cresource%5CCORTEXM_S32G2XXM7_s32g274a_bga525.properties%3C%2FEM%3E%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1760746521281.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1760746521281.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361476i2AF99FE5EA59911A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1760746521281.png%22%20alt%3D%22alejandro_e_0-1760746521281.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E6%98%AF%EF%BC%8C%E6%B3%A8%E5%86%8C%E9%AA%8C%E8%AF%81%E5%AD%98%E5%9C%A8%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E7%9B%AE%E5%89%8D%E8%B7%B3%E8%BF%87%E5%AE%83%E6%98%AF%E5%B7%B2%E7%9F%A5%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2187538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%94%9A%E8%87%B3%20AUTOSAR%20%E4%BB%A3%E7%A0%81%E4%B9%9F%E6%8A%A5%E5%91%8A%E4%BA%86%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E5%8D%B4%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%88%96%E8%AF%B4%E6%98%8E%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aaronbaranoff_0-1760618074933.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aaronbaranoff_0-1760618074933.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361186i6CAC46A1F3AD4177%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aaronbaranoff_0-1760618074933.png%22%20alt%3D%22aaronbaranoff_0-1760618074933.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2187522%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187522%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%A6%81%E9%97%AE%E7%9A%84%E4%B8%8D%E6%98%AF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%82%A3%E4%B9%88%E5%85%B7%3CSPAN%3E%E4%BD%93%E3%80%82%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E6%B3%A8%E5%86%8C%EF%BC%88%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E8%AF%95%E5%9B%BE%E8%AE%A9%200-3%20%E5%9D%97%E5%9C%A8%20PRTN2_COFB0_STAT%20%E4%B8%AD%E5%90%AF%E7%94%A8%E5%85%B6%E6%97%B6%E9%92%9F%E3%80%82%20%E5%8D%B3%E4%BD%BF%E6%88%91%E6%83%B3%E6%8C%89%2047.4%20%E7%89%88%E4%BD%BF%E7%94%A8%E4%BD%A0%E4%BB%AC%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%88%91%E9%9C%80%E8%A6%81%3CSTRONG%3E%EF%BC%88%E6%8C%89%E7%85%A7%E6%9C%AC%E6%96%87%E6%A1%A3%22MC_ME%20%E5%88%86%E5%8C%BA%202%20%E6%98%A0%E5%B0%84%22%20%E9%83%A8%E5%88%86%E6%89%80%E8%BF%B0%EF%BC%8C%E5%9C%A8%20MC_ME%20%E4%B8%AD%E5%90%AF%E7%94%A8%20PFE%20COFB%20%E6%97%B6%E9%92%9F%EF%BC%89%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%99%E6%98%AF%E6%9C%80%E5%9F%BA%E6%9C%AC%E7%9A%84%E9%A1%BA%E5%BA%8F%EF%BC%8C%E4%BD%86%E5%AE%83%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E8%80%8C%E4%B8%94%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B9%9F%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E6%89%80%E9%9C%80%E7%9A%84%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E4%BF%A1%E6%81%AF%E3%80%82%E5%88%86%E5%8C%BA%E5%B7%B2RESET%EF%BC%8C%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E5%9B%BE%20148%20%E6%9C%AA%E6%B6%B5%E7%9B%96%E5%9C%A8%E5%88%86%E5%8C%BA%E5%86%85%E5%90%AF%E7%94%A8%E5%8C%BA%E5%9D%97%E6%97%B6%E9%92%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3Emc_me.prtn2_cofb0_clken.b.req0%20%3D%201%3B%3CBR%20%2F%3Emc_me.prtn2_cofb0_clken.b.req1%20%3D%201%3B%3CBR%20%2F%3Emc_me.prtn2_cofb0_clken.b.req2%20%3D%201%3B%3CBR%20%2F%3Emc_me.prtn2_cofb0_clken.b.req3%20%3D%201%3B%3CBR%20%2F%3E%3CBR%20%2F%3Emc_me.prtn2_pconf.b.osse%20%3D%201%3B%3CBR%20%2F%3Emc_me.prtn2_pupd.b.ossud%20%3D%201%3B%3CBR%20%2F%3Emc_me.prtn2_pconf.b.pce%20%3D%201%3B%3CBR%20%2F%3Emc_me.prtn2_pupd.b.pcud%20%3D%201%EF%BC%9B%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%2F*%20%E5%91%8A%E8%AF%89%E7%A1%AC%E4%BB%B6%E6%A3%80%E6%9F%A5%E4%B8%8A%E8%BF%B0%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%98%E5%8C%96%20*%2F%3CBR%20%2F%3EWrite_Control_Key()%EF%BC%9B%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E8%AF%BB%E5%8F%96%E4%BA%86%3CSPAN%3EPRTN2_COFB0_STAT%EF%BC%8C%E4%BD%86%E7%8A%B6%E6%80%81%E4%BB%8E%E6%9C%AA%E6%98%BE%E7%A4%BA%E6%97%B6%E9%92%9F%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186099%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PFE%20subsystem%20bring%20up%20on%20S32G2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186099%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246004%22%20target%3D%22_blank%22%3E%40aaronbaranoff%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%86%8D%E6%AC%A1%E8%81%94%E7%B3%BB%E6%88%91%E4%BB%AC%E3%80%82%E5%9C%A8%E8%BF%99%E6%AC%A1%E8%BF%90%E5%8A%A8%E4%B8%AD%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%88%86%E4%BA%AB%E4%BB%A5%E5%89%8D%E6%B2%A1%E6%9C%89%E5%88%86%E4%BA%AB%E8%BF%87%E7%9A%84%E4%BB%BB%E4%BD%95%E8%B5%84%E6%BA%90%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E3%80%81FCI%20API%E6%96%87%E6%A1%A3%E4%BB%A5%E5%8F%8A%E4%BB%A3%E7%A0%81%E6%88%96%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%E3%80%82%E7%94%B1%E4%BA%8E%20A53%20%E7%9A%84%E8%BD%AF%E4%BB%B6%E6%94%AF%E6%8C%81%E4%B8%BB%E8%A6%81%E9%9B%86%E4%B8%AD%E5%9C%A8%20Linux%20%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%8C%E8%80%8C%20PFE%20%E5%8F%88%E6%98%AF%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E5%A4%8D%E6%9D%82%E7%9A%84%E6%A8%A1%E5%9D%97%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%E6%9F%A5%E7%9C%8B%E6%82%A8%E7%9A%84%E7%A8%8B%E5%BA%8F%E4%B8%BA%E6%82%A8%E6%8F%90%E4%BE%9B%E5%A4%AA%E5%A4%9A%E6%94%AF%E6%8C%81%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%AF%E4%BB%A5%E5%83%8F%E4%BB%A5%E5%BE%80%E4%B8%80%E6%A0%B7%E5%BB%BA%E8%AE%AE%E6%82%A8%E6%9F%A5%E7%9C%8B%E5%B7%B2%E6%8F%90%E4%BE%9B%E7%9A%84%E5%AE%9E%E7%8E%B0%E6%96%B9%E6%A1%88%EF%BC%8C%E5%B9%B6%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E9%9C%80%E6%B1%82%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%95%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%86%85%E9%83%A8%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E6%9C%89%E8%AE%A1%E5%88%92%E7%89%88%E6%9C%AC%E6%9B%B4%E5%A4%9A%E4%B8%8EPFE%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9B%B8%E5%85%B3%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BD%86%E6%98%AF%E6%88%91%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%E4%BC%9A%E5%AF%B9%E6%82%A8%E7%9A%84%E6%A1%88%E4%BE%8B%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%86%8D%E8%81%94%E7%B3%BB%E4%BD%A0%E7%9A%84%3C%2FP%3E%3C%2FLINGO-BODY%3E
