MPU - Unaligned Error
Girish1984
I am having issues when MPU is enabled. I get Unaligned error when I try to execute below instruction(marked in red arrow):
Below is my MPU configuration
I face the same issue wile executing "mla" instruction. Does enabling MPU causes issue with instructions handling 32 bit operand?
Thanks in advance.
-Girish
#S32G #MPU
MayanksPatel
Hi @Girish1984,
Hope you are doing well.
Can you please share this issue in more detail?
Also, Please clarify in which instruction you are facing the issue. (only MLA instruction or other)
