LLCE FlexRay configuration on S32DS
Yang_C
I am encountering a configuration issue for LLCE FlexRay on S32DS.
I would like to set this parameter to TRUE, after spending a long time on the IDE, still could not find the right place to change it. Is there someone can provide any clue?
My IDE version is S32DS3.5.10.
Thank you in advance.
Joey_z
Hi,Yang_C
Regarding "repeatTx", the driver is supported, but the interface configuration interface in EB is not. The main reason is that "repeatTx" is not a standard ECUC configuration item defined by the AUTOSAR FlexRay Interface (FrIf) specification, but rather an underlying Message Buffer extension attribute of the NXP FlexRay_IP Driver.
Joey
Yang_C
Thank you Joey. I will try manually update.
Yang_C
Hi Joey,
Thanks for your reply, I am a little bit confused because you mentioned EB does not support configuring 'Repeat TX', but I am using S32DS. Wondering if S32DS support set repeat TX for FlexRay?
BR,
Yang
Joey_z
Hi,Yang_C
Thank you for your reply.
The S32DS is also not configurable and needs to be manually modified, but there are drivers that can achieve this function.
Joey
Joey_z
Hi,Yang_C
Thank you for contacting us.
What version of LLCE are you using? And are you using S32G2 or S32G3?
Joey
Yang_C
Hi Joey,
I am using S32G399 with S32DS3.5.10, LLCE 1.0.7, RTD 4.0.2.
BR,
Yang
Joey_z
Hi,Yang_C
This seems to be an issue with the software itself. I will assist you in confirming it with the internal software developers!
Joey
Yang_C
Hi Joey,
Thank you for your help.
Looking forward to you reply.
BR,
Yang
%3CLINGO-SUB%20id%3D%22lingo-sub-2396202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELLCE%20FlexRay%20configuration%20on%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20encountering%20a%20configuration%20issue%20for%20LLCE%20FlexRay%20on%20S32DS.%3C%2FP%3E%3CP%3EI%20would%20like%20to%20set%20this%20parameter%20to%20TRUE%2C%20after%20spending%20a%20long%20time%20on%20the%20IDE%2C%20still%20could%20not%20find%20the%20right%20place%20to%20change%20it.%20Is%20there%20someone%20can%20provide%20any%20clue%3F%3C%2FP%3E%3CP%3EMy%20IDE%20version%20is%20S32DS3.5.10.%3C%2FP%3E%3CP%3EThank%20you%20in%20advance.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22LLCE_FlexRay_Config.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LLCE_FlexRay_Config.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LLCE_FlexRay_Config.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LLCE_FlexRay_Config.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LLCE_FlexRay_Config.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LLCE_FlexRay_Config.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LLCE_FlexRay_Config.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LLCE_FlexRay_Config.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LLCE_FlexRay_Config.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392544iE434AED62DC16585%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22LLCE_FlexRay_Config.png%22%20alt%3D%22LLCE_FlexRay_Config.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LLCE%20FlexRay%20configuration%20on%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CSPAN%3EYang_C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20us.%3C%2FP%3E%0A%3CP%3EWhat%20version%20of%20LLCE%20are%20you%20using%3F%20And%20are%20you%20using%20S32G2%20or%20S32G3%3F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LLCE%20FlexRay%20configuration%20on%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Joey%2C%3C%2FP%3E%3CP%3EI%20am%20using%20S32G399%20with%20S32DS3.5.10%2C%20LLCE%201.0.7%2C%20RTD%204.0.2.%26nbsp%3B%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EYang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LLCE%20FlexRay%20configuration%20on%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CSPAN%3EYang_C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThis%20seems%20to%20be%20an%20issue%20with%20the%20software%20itself.%20I%20will%20assist%20you%20in%20confirming%20it%20with%20the%20internal%20software%20developers!%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LLCE%20FlexRay%20configuration%20on%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Joey%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20for%20your%20help.%3C%2FP%3E%3CP%3ELooking%20forward%20to%20you%20reply.%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EYang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LLCE%20FlexRay%20configuration%20on%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CSPAN%3EYang_C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ERegarding%20%22repeatTx%22%2C%20the%20driver%20is%20supported%2C%20but%20the%20interface%20configuration%20interface%20in%20EB%20is%20not.%20The%20main%20reason%20is%20that%20%22repeatTx%22%20is%20not%20a%20standard%20ECUC%20configuration%20item%20defined%20by%20the%20AUTOSAR%20FlexRay%20Interface%20(FrIf)%20specification%2C%20but%20rather%20an%20underlying%20Message%20Buffer%20extension%20attribute%20of%20the%20NXP%20FlexRay_IP%20Driver.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LLCE%20FlexRay%20configuration%20on%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20Joey.%20I%20will%20try%20manually%20update.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LLCE%20FlexRay%20configuration%20on%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2CYang_C%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EThe%20S32DS%20is%20also%20not%20configurable%20and%20needs%20to%20be%20manually%20modified%2C%20but%20there%20are%20drivers%20that%20can%20achieve%20this%20function.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LLCE%20FlexRay%20configuration%20on%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Joey%2C%3C%2FP%3E%3CP%3EThanks%20for%20your%20reply%2C%20I%20am%20a%20little%20bit%20confused%20because%20you%20mentioned%20EB%20does%20not%20support%20configuring%20'Repeat%20TX'%2C%20but%20I%20am%20using%20S32DS.%20Wondering%20if%20S32DS%20support%20set%20repeat%20TX%20for%20FlexRay%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EYang%3C%2FP%3E%3C%2FLINGO-BODY%3E
