Kernel panic while trying implement IPCF sample demo
Abhiram_m_s
While trying to load IPCF sample in linux and when i entered this command,
insmod /lib/modules/`uname -r`/extra/ipc-shm-sample.ko
I received the following error
Please let me know how to proceed.
Daniel-Aguirre
Can you let us know which BSP/RTD/IPCF versions are you working with? Also, are you working with an NXP reference board?
Please, let us know.
Abhiram_m_s
BSP 38.0, RTD 4.0.2 and IPCF 4.9.0
i am working with nxp s32g3 rdb3
Daniel-Aguirre
Thanks for your feedback. Can you share the full boot log in which the commands of uboot are seen?
Also, did you build the BSP? Or are you working with the pre-built BSP provided by NXP (provided under a *.tgz file)?
