Integrate_LLCE_CAN/LIN(MCALDRIVER) SCRIPTS ISSUE
1,255件の閲覧回数
Chandan1
As per the Document.
During integrating of LLCE_CAN/LIN by using MCAL DRIVERS.
In goldvips32g binaries and scripts are not available.
and we executed the following below commands as mentioned below.
root@s32g274ardb2:~# ls
can-gw cloud-gw containers eth-gw fleetwise ml ota
root@s32g274ardb2:~# cd can-gw/
root@s32g274ardb2:~/can-gw# ls
avtp_listener.py can-secoc-fast-crypto.sh canperf.sh
can-aidps-fast-path.sh can-secoc-slow-crypto.sh gen_multi_pdu_payload.sh
can-aidps-slow-path.sh can-slow-path.sh gen_secure_payload.sh
can-fast-path.sh can-to-eth.sh
can-multi-pdu-path.sh canperf-multi.sh
root@s32g274ardb2:~/can-gw# cd ..
root@s32g274ardb2:~# can cloud-gw/
-sh: can: command not found
root@s32g274ardb2:~# cd cloud-gw/
root@s32g274ardb2:~/cloud-gw# ls
telemetry-collector
telemetry-collector
root@s32g274ardb2:~/cloud-gw# cd ..
root@s32g274ardb2:~# cd containers/
root@s32g274ardb2:~/containers# ls
goldvip-update-agents.yaml
root@s32g274ardb2:~/containers# cd ..
root@s32g274ardb2:~# cd eth-gw/
root@s32g274ardb2:~/eth-gw# ls
eth-bridge-target.sh eth-common.sh eth-slow-path-target.sh
eth-cleanup-target.sh eth-idps-slow-path-target.sh
eth-common-target.sh eth-pfe-fast-path-target.sh
root@s32g274ardb2:~/eth-gw# cd ..
root@s32g274ardb2:~# cd fleetwise/
root@s32g274ardb2:~/fleetwise# ls
deploy.py utils.py
root@s32g274ardb2:~/fleetwise# cd ..
root@s32g274ardb2:~# cd ml/
root@s32g274ardb2:~/ml# ls
bms pred_maintain
root@s32g274ardb2:~/ml# cd ..
root@s32g274ardb2:~# cd ota/
Note: We Run the command [Dmesg] for related anything about LIN,so we did not found anything related above mentioned issue.
Chandan K S
1,191件の閲覧回数
nxf92355
Hi Chandan
Hope You are doing well.
Please Explain about your issue in brief.
Regards ,
Tushar
