IPCF version compatible with S32G BSP42
hittzt
Senior Contributor I
I noticed that, the newest SDK BSP42 for S32G has been released, but I did not find where to get the compatible IPCF version for this new released BSP42.
So would you please help to check the issue?
Zhantao
chenyin_h
Hi, @hittzt
Thanks for your reply.
I have checked it internally and found that currently we do not release the IPCF with pre-built images, sorry for your inconvenience.
Regarding to your issue on S32DS, I suggest submiting a private support ticket, which will be routed to correct person to handle.
Chenyin
hittzt
Hi @chenyin_h,
Thanks for you rapid reply.
Would you please tell me how to submit a private support ticket?
Zhantao
chenyin_h
Hello, @hittzt
Thanks for your post.
I noticed that the latest IPCF is 4.10.
May I know if you have tried it on BSP42? are there some compatible issues found with IPCF4.10?
Chenyin
hittzt
Hi @chenyin_h,
Thanks for you reply.
As you see, the latest IPCF version now is 4.10, but the related IPCF binary used for S32G platform should be built by S32DS v3.5 tool, the expiration date of which is Jul 29, 2024, so I can not build the IPCF v4.10 binary.
Is there any other way I can get the latest IPCF v4.10 binary?
Zhantao
