How to enable bootloader debugger project with ds IDE ?
fengxianeric
Hi, I build bootloader by command and tresos, but how to use ds to establish such project as doc mentioned below ?
Daniel-Aguirre
The following HOWTO tells the steps to be able to debug a blob image loaded to NOR Flash:
HOWTO: JTAG Flash Programming with S32 Debugger an... - NXP Community
We recommend starting from an easier project, like a blink, to understand the process to be able to debug from external flash.
Please, let us know.
fengxianeric
Thanks caring.
Yes I know how to do programming.
and how to connect debugger.
My point is how to build Ds boot loader project because I did by eb project plus make according doc guide.
Thanks again
Daniel-Aguirre
Thanks for your feedback.
At this moment, there is no bootloader project available under S32DS. The image you shared was a debugging session under S32DS, hence we shared on how to debug under S32DS. We apologize.
