How to create a Dynamic Entry for CB_SG_IR in S32G-VNP-RDB
1,344件の閲覧回数
Atkinson
Contributor V
int WriteCB_SG_IR(uint32_t index) {
int cs = 0;
uint32_t CBSGIR_OFFSET     = 142;
uint32_t CBSGIR_CTRL_OFFSET = 147;
const uint32_t SWREG_BASE    = 0;
uint32_t CB_SG_IR_ADDRESS      = SWREG_BASE + CBSGIR_OFFSET;
uint32_t CB_SG_IR_ADDRESS_CTL  = SWREG_BASE + CBSGIR_CTRL_OFFSET;
if (index >= 64) {
        return -1;
    uint32_t RTAGOFFSET_0 = 0;
    uint32_t RTAGOFFSET_1 = 0;
    uint32_t RTAGOFFSET_2 = 0;
    uint32_t RTAGOFFSET_3 = 0;
    uint32_t RTAGOFFSET_4 = 0;
    uint32_t RTAGOFFSET_5 = 0;
    uint32_t RTAGOFFSET_6 = 0;
    uint32_t RTAGOFFSET_7 = 0;
    uint32_t RTAGOFFSET_8 = 0;
    uint32_t RTAGOFFSET_9 = 0;
    uint32_t RTAGOFFSET_10 = 0;
    uint32_t REPLACE_PORTS = 0;
    uint32_t TAG_PORTS = 0x7FF;
    uint32_t SEQ_REC_PORTS = 0;
    uint32_t IND_REC_PORTS = 0;
    uint32_t IND_REC_TIMEOUT = 0;
    uint32_t SEQRECOFFSET = 0;
    uint32_t GENSEQNUM = 0x1;
    uint32_t SEQGENRST = 0;
    uint32_t VALID = 1U;
    uint32_t RDWRSET = 1U;
    uint32_t TARGETEDTBL = 0;
    uint32_t CB_SG_IR_Entry[CB_SGIR_ADDR_RANGE] = {0};
    CB_SG_IR_Entry[0] =
    ((GENSEQNUM & 0x1) << 28) |
    ((SEQRECOFFSET & 0x1F) << 29) |
    ((IND_REC_TIMEOUT & 0xFFFF) << 34);
    CB_SG_IR_Entry[1] =
    ((SEQ_REC_PORTS & 0x7FF) << 0) |
        ((IND_REC_PORTS & 0x7FF) << 11);
    CB_SG_IR_Entry[2] =
        ((TAG_PORTS & 0x7FF) << 0) |
        ((REPLACE_PORTS & 0x7FF) << 11);
    CB_SG_IR_Entry[3] =
        ((RTAGOFFSET_0 & 0x3F) << 0)  |
        ((RTAGOFFSET_1 & 0x3F) << 6) |
        ((RTAGOFFSET_2 & 0x3F) << 12) |
        ((RTAGOFFSET_3 & 0x3F) << 18) |
        ((RTAGOFFSET_4 & 0x3F) << 24);
    CB_SG_IR_Entry[4] =
        ((RTAGOFFSET_5 & 0x3F) << 0) |
        ((RTAGOFFSET_6 & 0x3F) << 6) |
        ((RTAGOFFSET_7 & 0x3F) << 12) |
        ((RTAGOFFSET_8 & 0x3F) << 18) |
        ((RTAGOFFSET_9 & 0x3F) << 24) |
        ((RTAGOFFSET_10 & 0x3F) << 30);
    uint32_t status = 0;
    status = spi_read_DynamicEntry(CB_SG_IR_ADDRESS_CTL, cs);
    uint8_t counter = 0;
    while ((status & (1 << 31)) != 0){
       counter++;
    for (int i = 0; i < CB_SGIR_ADDR_RANGE; i++) {
    Std_ReturnType ret = spi_write_DynamicEntry(CB_SG_IR_ADDRESS + i, CB_SG_IR_Entry[i]);
    if (ret != E_OK) {
    return -2;
    uint32_t readBack = 0;
    ret = spi_read_DynamicEntry(CB_SG_IR_ADDRESS + i, &readBack);
    if (ret != E_OK || readBack != CB_SG_IR_Entry[i]) {
    return -3;
    uint32_t CTRL_VALUE = (VALID << 31) |
                          (RDWRSET << 30) |
                          (SEQGENRST << 9) |
                          (TARGETEDTBL << 6) |
                          (index & 0x3F);
    Std_ReturnType ret = spi_write_DynamicEntry(CB_SG_IR_ADDRESS_CTL, CTRL_VALUE);
        if (ret != E_OK) {
            return -4;
        do {
            ret = spi_read_DynamicEntry(CB_SG_IR_ADDRESS_CTL, &status);
            if (ret != E_OK) {
                return -5;
        } while ((status >> 31) & 1U);
    return 0;  // Success
I am trying to create a Dynamic Entry for CB Sequence Generation and Recovery Table in which followed up the example from SJA1110 EVM Host tools CB_SG_IR.py. where i am facing some issue with the bit settings
Add on to that, see when we are configuring this
IND_REC_TIMEOUT value is written after 32 bit register value which is we are exceeding the 32 bits where the values will be written into the wrong register ryt?? can you double check whether it will be written within 32bit register
One more thing when i debug, i could see the CB_SG_IR_Entry[0] is written with some values what we are expecting to write but in the case of other CB_SG_IR_Entr[1],[2],[3] there is no value written
I am thinking the root cause of the issue is due to bit change ??
As you mentioned the spi_read and spi_write is as same as L2 Lookup table which i used to configure dynamically which is working fine in L2 Lookup table.
Is there any other thing we are missing out ??
タグ(1)
2 返答(返信)
1,315件の閲覧回数
PavelL
Hello @Atkinson ,
Finally, I understand your issue clearly.
It turns out the root cause is related to bit alignment across 32-bit words — something quite fundamental when working with hardware register programming.
Below is the corrected code. I hope I’ve implemented it without errors, but please let me know if anything still looks off.
// Entry[0] – bits 0–31
CB_SG_IR_Entry[0] =
((GENSEQNUM & 0x1) << 28) | // Bit 28
((SEQRECOFFSET & 0x7) << 29); // Bits 29–31
// Entry[1] – bits 32–63
CB_SG_IR_Entry[1] =
((SEQRECOFFSET >> 3) & 0x3) << 0 | // Bits 32–33
((IND_REC_TIMEOUT & 0xFFFF) << 2) | // Bits 34–49
((SEQ_REC_PORTS & 0x7FF) << 18) | // Bits 50–60
((IND_REC_PORTS & 0x7FF) << 29); // Bits 61–71
// Entry[2] – bits 64–95
CB_SG_IR_Entry[2] =
((TAG_PORTS & 0x7FF) << 0) | // Bits 72–82
((REPLACE_PORTS & 0x7FF) << 11) | // Bits 83–93
((RTAGOFFSET_0 & 0x3) << 30); // Bits 94–95 (lower 2 bits)
// Entry[3] – bits 96–127
CB_SG_IR_Entry[3] =
((RTAGOFFSET_0 >> 2) & 0xF) << 0 | // Bits 96–99 (upper 4 bits)
((RTAGOFFSET_1 & 0x3F) << 4) | // Bits 100–105
((RTAGOFFSET_2 & 0x3F) << 10) | // Bits 106–111
((RTAGOFFSET_3 & 0x3F) << 16) | // Bits 112–117
((RTAGOFFSET_4 & 0x3F) << 22) | // Bits 118–123
((RTAGOFFSET_5 & 0xF) << 28); // Bits 124–127 (lower 4 bits)
// Entry[4] – bits 128–159
CB_SG_IR_Entry[4] =
((RTAGOFFSET_5 >> 4) & 0x3) << 0 | // Bits 128–129 (upper 2 bits)
((RTAGOFFSET_6 & 0x3F) << 2) | // Bits 130–135
((RTAGOFFSET_7 & 0x3F) << | // Bits 136–141
((RTAGOFFSET_8 & 0x3F) << 14) | // Bits 142–147
((RTAGOFFSET_9 & 0x3F) << 20) | // Bits 148–153
((RTAGOFFSET_10 & 0x3F) << 26); // Bits 154–159
Pavel
1,303件の閲覧回数
PavelL
Hello @Atkinson ,
I adapted example_vlan_lookup_table.py to work with the CB SG IR table. Please find the Python script attached. I’ve also included two .hex files for the SJA1110-EVM, which contain the switchcore configuration for my minimal IEEE 802.1CB example. Just remove the .txt extension from the filenames.
Save all files to the folder where host tools were unzipped, e.g. sja1110evm_hosttools_v1.2\SJA1110EVM
To load the configuration onto the board, follow the DIP switch settings as described in UM575112-AH1901 SJA1110 - EVM User Manual (v1.2), section 3.3 “Quick Start using the Python Host Tools Package”, and run:
python setup_sja1110evm.py --hex1 switchcore_0_Config_CB.hex --hex2 switchcore_1_Config_CB.hex
Then, run the dynamic change example:
python __example_cb_sgir_table.py
You should see output similar to:
CB SG/IR Lookup Table SW0:
| IDX | REPLACE_PORTS | TAG_PORTS | IND_REC_PORTS | SEQ_REC_PORTS | IND_REC_TIMEOUT | SEQRECOFFSET | GENSEQNUM |
|  0  |       0       |    1056   |       0       |       0       |        0        |      0       |     1     |
|  1  |       0       |     0     |       2       |       2       |        0        |      0       |     0     |
|  2  |       0       |     0     |       2       |       2       |        0        |      0       |     0     |
|  3  |       0       |     0     |       0       |       0       |        0        |      0       |     0     |
|  15 |       0       |     0     |       0       |       0       |        0        |      0       |     0     |
CB SG/IR Lookup Table SW1:
|  0  |       0       |     0     |       4       |       4       |        0        |      0       |     0     |
|  1  |       0       |     0     |       4       |       4       |        0        |      0       |     0     |
|  2  |       0       |    1056   |       0       |       0       |        0        |      0       |     1     |
Change entry #1.
[0, 2097152, 1, 0, 0, 0]
Reading again...
|  1  |       0       |     0     |       8       |       8       |        0        |      0       |     0     |
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-2152047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G-VNP-RDB%E3%81%A7CB_SG_IR%E3%81%AE%E5%8B%95%E7%9A%84%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3Eint%20WriteCB_SG_IR(uint32_t%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9)%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%95%B4%E6%95%B0%20cs%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint32_t%20CBSGIR_OFFSET%20%3D%20142%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint32_t%20CBSGIR_CTRL_OFFSET%20%3D%20147%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%AE%9A%E6%95%B0%20uint32_t%20SWREG_BASE%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint32_t%20CB_SG_IR_ADDRESS%20%3D%20SWREG_BASE%20%2B%20CBSGIR_OFFSET%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint32_t%20CB_SG_IR_ADDRESS_CTL%20%3D%20SWREG_BASE%20%2B%20CBSGIR_CTRL_OFFSET%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif%20(%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%26gt%3B%3D%2064)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E-1%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_0%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_1%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_2%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_3%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_4%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_5%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_6%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_7%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_8%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_9%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RTAGOFFSET_10%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20REPLACE_PORTS%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20TAG_PORTS%20%3D%200x7FF%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20SEQ_REC_PORTS%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20IND_REC_PORTS%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20IND_REC_TIMEOUT%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20SEQRECOFFSET%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20GENSEQNUM%20%3D%200x1%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20SEQGENRST%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20%E6%9C%89%E5%8A%B9%20%3D%201U%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20RDWRSET%20%3D%201U%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88TBL%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20CB_SG_IR_Entry%5BCB_SGIR_ADDR_RANGE%5D%20%3D%20%7B0%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECB_SG_IR_%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B0%5D%20%3D%3C%2FDIV%3E%3CDIV%3E((GENSEQNUM%20%26amp%3B%200x1)%20%26lt%3B%26lt%3B%2028)%20%7C%3C%2FDIV%3E%3CDIV%3E((SEQRECOFFSET%20%26amp%3B%200x1F)%20%26lt%3B%26lt%3B%2029)%20%7C%3C%2FDIV%3E%3CDIV%3E((IND_REC_TIMEOUT%20%26amp%3B%200xFFFF)%20%26lt%3B%26lt%3B%2034)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECB_SG_IR_%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B1%5D%20%3D%3C%2FDIV%3E%3CDIV%3E((SEQ_REC_PORTS%20%26amp%3B%200x7FF)%20%26lt%3B%26lt%3B%200)%20%7C%3C%2FDIV%3E%3CDIV%3E((IND_REC_PORTS%20%26amp%3B%200x7FF)%20%26lt%3B%26lt%3B%2011)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECB_SG_IR_%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B2%5D%20%3D%3C%2FDIV%3E%3CDIV%3E((TAG_PORTS%20%26amp%3B%200x7FF)%20%26lt%3B%26lt%3B%200)%20%7C%3C%2FDIV%3E%3CDIV%3E((REPLACE_PORTS%20%26amp%3B%200x7FF)%20%26lt%3B%26lt%3B%2011)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECB_SG_IR_%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B3%5D%20%3D%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_0%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%200)%20%7C%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_1%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%206)%20%7C%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_2%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2012)%20%7C%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_3%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2018)%20%7C%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_4%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2024)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECB_SG_IR_%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B4%5D%20%3D%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_5%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%200)%20%7C%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_6%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%206)%20%7C%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_7%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2012)%20%7C%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_8%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2018)%20%7C%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_9%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2024)%20%7C%3C%2FDIV%3E%3CDIV%3E((RTAGOFFSET_10%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2030)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20spi_read_DynamicEntry(CB_SG_IR_ADDRESS_CTL%2C%20cs)%3B%3C%2FDIV%3E%3CDIV%3Euint8_t%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Ewhile%20((%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%26amp%3B%20(1%20%26lt%3B%26lt%3B%2031))%20!%3D%200)%7B%3C%2FDIV%3E%3CDIV%3E%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%2B%2B%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20spi_read_DynamicEntry(CB_SG_IR_ADDRESS_CTL%2C%20cs)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E(int%20i%20%3D%200%3B%20i%20%26lt%3B%20CB_SGIR_ADDR_RANGE%3B%20i%2B%2B)%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3C%2FDIV%3E%3CDIV%3EStd_ReturnType%20ret%20%3D%20spi_write_DynamicEntry(CB_SG_IR_ADDRESS%20%2B%20i%2C%20CB_SG_IR_Entry%5Bi%5D)%3B%3C%2FDIV%3E%3CDIV%3Eif%20(ret%20!%3D%20E_OK)%20%7B%3C%2FDIV%3E%3CDIV%3E-2%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%90%E3%83%83%E3%82%AF%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Eret%20%3D%20spi_read_DynamicEntry(CB_SG_IR_ADDRESS%20%2B%20i%2C%20%26amp%3BreadBack)%3B%3C%2FDIV%3E%3CDIV%3Eif%20(ret%20!%3D%20E_OK%20%7C%7C%20readBack%20!%3D%20CB_SG_IR_Entry%5Bi%5D)%20%7B%3C%2FDIV%3E%3CDIV%3E-3%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20CTRL_VALUE%20%3D%20(%E6%9C%89%E5%8A%B9%20%26lt%3B%26lt%3B%2031)%20%7C%3C%2FDIV%3E%3CDIV%3E(RDWRSET%20%26lt%3B%26lt%3B%2030)%20%7C%3C%2FDIV%3E%3CDIV%3E(SEQGENRST%20%26lt%3B%26lt%3B%209)%20%7C%3C%2FDIV%3E%3CDIV%3E(%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88TBL%20%26lt%3B%26lt%3B%206)%20%7C%3C%2FDIV%3E%3CDIV%3E(%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%26amp%3B%200x3F)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EStd_ReturnType%20ret%20%3D%20spi_write_DynamicEntry(CB_SG_IR_ADDRESS_CTL%E3%80%81CTRL_VALUE)%3B%3C%2FDIV%3E%3CDIV%3Eif%20(ret%20!%3D%20E_OK)%20%7B%3C%2FDIV%3E%3CDIV%3E-4%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%81%99%E3%82%8B%20%7B%3C%2FDIV%3E%3CDIV%3Eret%20%3D%20spi_read_DynamicEntry(CB_SG_IR_ADDRESS_CTL%E3%80%81%26amp%3Bstatus)%3B%3C%2FDIV%3E%3CDIV%3Eif%20(ret%20!%3D%20E_OK)%20%7B%3C%2FDIV%3E%3CDIV%3E-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%7D%20while%20((%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%26gt%3B%26gt%3B%2031)%20%26amp%3B%201U)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E0%E3%82%92%E8%BF%94%E3%81%99%3B%20%2F%2F%20%E6%88%90%E5%8A%9F%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CP%3E%3CBR%20%2F%3ESJA1110%20EVM%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%83%84%E3%83%BC%E3%83%AB%20CB_SG_IR.py%20%E3%81%AE%E4%BE%8B%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81CB%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E7%94%9F%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E5%8B%95%E7%9A%84%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E3%81%84%E3%81%A4%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E((GENSEQNUM%20%26amp%3B%200x1)%20%26lt%3B%26lt%3B%2028)%20%7C%3CBR%20%2F%3E%20((SEQRECOFFSET%20%26amp%3B%200x1F)%20%26lt%3B%26lt%3B%2029)%20%7C%3CBR%20%2F%3E%20((IND_REC_TIMEOUT%20%26amp%3B%200xFFFF)%20%26lt%3B%26lt%3B%2034)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20IND_REC_TIMEOUT%E5%80%A4%E3%81%AF32%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%80%A4%E3%81%AE%E5%BE%8C%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF32%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%80%A4%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFryt%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F32%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%86%85%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%99%82%E3%81%AB%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81CB_SG_IR_Entry%5B0%5D%E3%81%AB%E3%81%AF%E6%9C%9F%E5%BE%85%E9%80%9A%E3%82%8A%E3%81%AE%E5%80%A4%E3%81%8C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AB%E3%80%81%E4%BB%96%E3%81%AECB_SG_IR_Entr%5B1%5D%E3%80%81%5B2%5D%E3%80%81%5B3%5D%E3%81%AB%E3%81%AF%E5%80%A4%E3%81%8C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E6%A0%B9%E6%9C%AC%E7%9A%84%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%82%8B%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81spi_read%20%E3%81%A8%20spi_write%20%E3%81%AF%E3%80%81%E5%8B%95%E7%9A%84%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20L2%20%E3%83%AB%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81L2%20%E3%83%AB%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%BB%96%E3%81%AB%E8%A6%8B%E9%80%83%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20create%20a%20Dynamic%20Entry%20for%20CB_SG_IR%20in%20S32G-VNP-RDB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248906%22%20target%3D%22_blank%22%3E%40Atkinson%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3Eexample_vlan_lookup_table.py%20%E3%82%92%20CB%20SG%20IR%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E9%81%A9%E5%BF%9C%E3%81%95%E3%81%9B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%B7%BB%E4%BB%98%E3%81%AE%20Python%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81SJA1110-EVM%20%E7%94%A8%E3%81%AE%202%20%E3%81%A4%E3%81%AE%20.hex%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E5%90%8C%E6%A2%B1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%20IEEE%20802.1CB%20%E3%81%AE%E4%BE%8B%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%B3%E3%82%A2%E6%A7%8B%E6%88%90%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%81%8B%E3%82%89%20.txt%20%E6%8B%A1%E5%BC%B5%E5%AD%90%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%9B%E3%82%B9%E3%83%88%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E8%A7%A3%E5%87%8D%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%EF%BC%9Asja1110evm_hosttools_v1.2%5CSJA1110EVM%3C%2FP%3E%0A%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81UM575112-AH1901%20SJA1110%20-%20EVM%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%20(v1.2)%20%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%203.3%E3%80%8CPython%20%E3%83%9B%E3%82%B9%E3%83%88%E3%83%84%E3%83%BC%E3%83%AB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%80%8D%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%82%A3%E3%83%83%E3%83%97%E3%83%BB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%BE%93%E3%81%84%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Epython%20setup_sja1110evm.py%20--hex1%20switchcore_0_Config_CB.hex%20--hex2%20switchcore_1_Config_CB.hex%3C%2FPRE%3E%0A%3CP%3E%3CSPAN%3E%E6%AC%A1%E3%81%AB%E3%80%81%E5%8B%95%E7%9A%84%E5%A4%89%E6%9B%B4%E3%81%AE%E4%BE%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Epython%20__example_cb_sgir_table.py%3C%2FPRE%3E%0A%3CP%3E%3CSPAN%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%87%BA%E5%8A%9B%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3E%3CFONT%20size%3D%222%22%3ECB%20SG%2FIR%20Lookup%20Table%20SW0%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%20IDX%20%7C%20REPLACE_PORTS%20%7C%20TAG_PORTS%20%7C%20IND_REC_PORTS%20%7C%20SEQ_REC_PORTS%20%7C%20IND_REC_TIMEOUT%20%7C%20SEQRECOFFSET%20%7C%20GENSEQNUM%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%200%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%201056%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%201%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%202%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%203%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E...%3CBR%20%2F%3E%7C%26nbsp%3B%2015%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3ECB%20SG%2FIR%20Lookup%20Table%20SW1%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%20IDX%20%7C%20REPLACE_PORTS%20%7C%20TAG_PORTS%20%7C%20IND_REC_PORTS%20%7C%20SEQ_REC_PORTS%20%7C%20IND_REC_TIMEOUT%20%7C%20SEQRECOFFSET%20%7C%20GENSEQNUM%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%200%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%201%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%202%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%201056%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%203%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E...%3CBR%20%2F%3E%7C%26nbsp%3B%2015%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3EChange%20entry%20%231.%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%5B0%2C%202097152%2C%201%2C%200%2C%200%2C%200%5D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3EReading%20again...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3ECB%20SG%2FIR%20Lookup%20Table%20SW0%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%20IDX%20%7C%20REPLACE_PORTS%20%7C%20TAG_PORTS%20%7C%20IND_REC_PORTS%20%7C%20SEQ_REC_PORTS%20%7C%20IND_REC_TIMEOUT%20%7C%20SEQRECOFFSET%20%7C%20GENSEQNUM%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%200%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%201056%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%201%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3E%20%26nbsp%3B8%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%208%26nbsp%3B%26nbsp%3B%3C%2FFONT%3E%26nbsp%3B%26nbsp%3B%3C%2FSTRONG%3E%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%202%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%203%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E...%3CBR%20%2F%3E%7C%26nbsp%3B%2015%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3ECB%20SG%2FIR%20Lookup%20Table%20SW1%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%20IDX%20%7C%20REPLACE_PORTS%20%7C%20TAG_PORTS%20%7C%20IND_REC_PORTS%20%7C%20SEQ_REC_PORTS%20%7C%20IND_REC_TIMEOUT%20%7C%20SEQRECOFFSET%20%7C%20GENSEQNUM%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%200%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%201%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%202%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%201056%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C%26nbsp%3B%203%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E...%3CBR%20%2F%3E%7C%26nbsp%3B%2015%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%2B-----%2B---------------%2B-----------%2B---------------%2B---------------%2B-----------------%2B--------------%2B-----------%2B%3C%2FFONT%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%99%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20create%20a%20Dynamic%20Entry%20for%20CB_SG_IR%20in%20S32G-VNP-RDB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248906%22%20target%3D%22_blank%22%3E%40Atkinson%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E3%81%AF%E3%81%A3%E3%81%8D%E3%82%8A%E3%81%A8%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%A0%B9%E6%9C%AC%E7%9A%84%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%80%8132%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%AF%E3%83%BC%E3%83%89%E9%96%93%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%20%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%A4%E6%98%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E6%89%B1%E3%81%86%E3%81%A8%E3%81%8D%E3%81%AB%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%8F%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E4%BD%95%E3%81%8B%E3%81%8A%E3%81%8B%E3%81%97%E3%81%84%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3C!--ScriptorStartFragment--%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%0A%3CP%3E%2F%2F%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B0%5D%20%E2%80%93%20%E3%83%93%E3%83%83%E3%83%880%EF%BD%9E31%3CBR%20%2F%3E%20CB_SG_IR_%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B0%5D%20%3D%3CBR%20%2F%3E%20((GENSEQNUM%20%26amp%3B%200x1)%20%26lt%3B%26lt%3B%2028)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88%2028%3CBR%20%2F%3E%20((SEQRECOFFSET%20%26amp%3B%200x7)%20%26lt%3B%26lt%3B%2029)%3B%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%8829%EF%BD%9E31%3C%2FP%3E%0A%3CP%3E%2F%2F%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B1%5D%20%E2%80%93%20%E3%83%93%E3%83%83%E3%83%8832%EF%BD%9E63%3CBR%20%2F%3E%20CB_SG_IR_%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B1%5D%20%3D%3CBR%20%2F%3E%20((SEQRECOFFSET%20%26gt%3B%26gt%3B%203)%20%26amp%3B%200x3)%20%26lt%3B%26lt%3B%200%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%8832%EF%BD%9E33%3CBR%20%2F%3E%20((IND_REC_TIMEOUT%20%26amp%3B%200xFFFF)%20%26lt%3B%26lt%3B%202)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%8834%EF%BD%9E49%3CBR%20%2F%3E%20((SEQ_REC_PORTS%20%26amp%3B%200x7FF)%20%26lt%3B%26lt%3B%2018)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%8850%EF%BD%9E60%3CBR%20%2F%3E%20((IND_REC_PORTS%20%26amp%3B%200x7FF)%20%26lt%3B%26lt%3B%2029)%3B%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%8861%EF%BD%9E71%3C%2FP%3E%0A%3CP%3E%2F%2F%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B2%5D%20%E2%80%93%20%E3%83%93%E3%83%83%E3%83%8864%EF%BD%9E95%3CBR%20%2F%3E%20CB_SG_IR_%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B2%5D%20%3D%3CBR%20%2F%3E%20((TAG_PORTS%20%26amp%3B%200x7FF)%20%26lt%3B%26lt%3B%200)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%8872%EF%BD%9E82%3CBR%20%2F%3E%20((REPLACE_PORTS%20%26amp%3B%200x7FF)%20%26lt%3B%26lt%3B%2011)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%8883%EF%BD%9E93%3CBR%20%2F%3E%20((RTAGOFFSET_0%20%26amp%3B%200x3)%20%26lt%3B%26lt%3B%2030)%3B%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%8894%EF%BD%9E95%EF%BC%88%E4%B8%8B%E4%BD%8D2%E3%83%93%E3%83%83%E3%83%88%EF%BC%89%3C%2FP%3E%0A%3CP%3E%2F%2F%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B3%5D%20%E2%80%93%20%E3%83%93%E3%83%83%E3%83%8896%EF%BD%9E127%3CBR%20%2F%3E%20CB_SG_IR_%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B3%5D%20%3D%3CBR%20%2F%3E%20((RTAGOFFSET_0%20%26gt%3B%26gt%3B%202)%20%26amp%3B%200xF)%20%26lt%3B%26lt%3B%200%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%8896%EF%BD%9E99%EF%BC%88%E4%B8%8A%E4%BD%8D4%E3%83%93%E3%83%83%E3%83%88%EF%BC%89%3CBR%20%2F%3E%20((RTAGOFFSET_1%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%204)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88100%EF%BD%9E105%3CBR%20%2F%3E%20((RTAGOFFSET_2%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2010)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88106%EF%BD%9E111%3CBR%20%2F%3E%20((RTAGOFFSET_3%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2016)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88112%EF%BD%9E117%3CBR%20%2F%3E%20((RTAGOFFSET_4%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2022)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88118%EF%BD%9E123%3CBR%20%2F%3E%20((RTAGOFFSET_5%20%26amp%3B%200xF)%20%26lt%3B%26lt%3B%2028)%3B%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88124%EF%BD%9E127%EF%BC%88%E4%B8%8B%E4%BD%8D4%E3%83%93%E3%83%83%E3%83%88%EF%BC%89%3C%2FP%3E%0A%3CP%3E%2F%2F%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B4%5D%20%E2%80%93%20%E3%83%93%E3%83%83%E3%83%88128%EF%BD%9E159%3CBR%20%2F%3E%20CB_SG_IR_%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5B4%5D%20%3D%3CBR%20%2F%3E%20((RTAGOFFSET_5%20%26gt%3B%26gt%3B%204)%20%26amp%3B%200x3)%20%26lt%3B%26lt%3B%200%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88128%EF%BD%9E129%EF%BC%88%E4%B8%8A%E4%BD%8D2%E3%83%93%E3%83%83%E3%83%88%EF%BC%89%3CBR%20%2F%3E%20((RTAGOFFSET_6%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%202)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88130%EF%BD%9E135%3CBR%20%2F%3E%20((RTAGOFFSET_7%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88136%EF%BD%9E141%3CBR%20%2F%3E%20((RTAGOFFSET_8%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2014)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88142%EF%BD%9E147%3CBR%20%2F%3E%20((RTAGOFFSET_9%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2020)%20%7C%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88148%EF%BD%9E153%3CBR%20%2F%3E%20((RTAGOFFSET_10%20%26amp%3B%200x3F)%20%26lt%3B%26lt%3B%2026)%3B%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88154%EF%BD%9E159%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3CSPAN%3E%3C!--ScriptorEndFragment--%3E%3C%2FSPAN%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%99%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
