Enabling Multicore Application on S32G3 using S32G3 Platform Software Integration
TrikiIkram
Hello;
We are trying to reproduce the steps on doc AN13750 applied to the S32G399a, our concern is regarding the build of the IPCF modules.
In the doc it is said to use the "0001-ipc-multi-instances.patch" but this is not applicable on the S32G3
Is there a way to explain to us how to proceed the build of the IPCF modules in the case of the S32G3 in order to be able to go through all the steps in the document and succeed the dual boot.
chenyin_h
Hello, @TrikiIkram
Thanks for your post.
1. Sorry that there is still not a public document for your reference, which would act as a similar reference as AN13750 for S32G3.
2. Currently, I suggest using AN13750 as a reference, not a step-by-step guide for using it on S32G3, for setup the IPCF on S32G3 platform, I suggest directly trying the single instance samples instead of the multi-instance sample, so that you will not need apply the patch mentioned.
Chenyin
%3CLINGO-SUB%20id%3D%22lingo-sub-2389207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEnabling%20Multicore%20Application%20on%20S32G3%20using%20S32G3%20Platform%20Software%20Integration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3B%26nbsp%3B%3C%2FP%3E%3CP%3EWe%20are%20trying%20to%20reproduce%20the%20steps%20on%20doc%20AN13750%20applied%20to%20the%20S32G399a%2C%20our%20concern%20is%20regarding%20the%20build%20of%20the%20IPCF%20modules.%26nbsp%3B%3C%2FP%3E%3CP%3EIn%20the%20doc%20it%20is%20said%20to%20use%20the%26nbsp%3B%22%3CSTRONG%3E0001-ipc-multi-instances.patch%3C%2FSTRONG%3E%22%20but%20this%20is%20not%20applicable%20on%20the%20S32G3%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22TrikiIkram_0-1782919427268.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22TrikiIkram_0-1782919427268.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390993iB9EA87632D35828D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22TrikiIkram_0-1782919427268.png%22%20alt%3D%22TrikiIkram_0-1782919427268.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIs%20there%20a%20way%20to%20explain%20to%20us%20how%20to%20proceed%20the%20build%20of%20the%20IPCF%20modules%20in%20the%20case%20of%20the%20S32G3%20in%20order%20to%20be%20able%20to%20go%20through%20all%20the%20steps%20in%20the%20document%20and%20succeed%20the%20dual%20boot.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Enabling%20Multicore%20Application%20on%20S32G3%20using%20S32G3%20Platform%20Software%20Integration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263731%22%20target%3D%22_blank%22%3E%40TrikiIkram%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3E1.%20Sorry%20that%20there%20is%20still%20not%20a%20public%20document%20for%20your%20reference%2C%20which%20would%20act%20as%20a%20similar%20reference%20as%20AN13750%20for%20S32G3.%3C%2FP%3E%0A%3CP%3E2.%20Currently%2C%20I%20suggest%20using%20AN13750%20as%20a%20reference%2C%20not%20a%20step-by-step%20guide%20for%20using%20it%20on%20S32G3%2C%20for%20setup%20the%20IPCF%20on%20S32G3%20platform%2C%20I%20suggest%20directly%20trying%20the%20single%20instance%20samples%20instead%20of%20the%20multi-instance%20sample%2C%20so%20that%20you%20will%20not%20need%20apply%20the%20patch%20mentioned.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
