Can we install docker on S32g-VNP-RDB2
iamramcharan
Pasted the dockerd error logs  on S32g-VNP-RDB2:
ERRO[2024-02-02T10:11:49.448791462Z] failed to mount overlay: no such device storage-driver=overlay2
ERRO[2024-02-02T10:11:49.449041872Z] exec: "fuse-overlayfs": executable file not found in $PATH storage-driver=fuse-overlayfs
ERRO[2024-02-02T10:11:49.452702822Z] AUFS was not found in /proc/filesystems storage-driver=aufs
ERRO[2024-02-02T10:11:49.457810032Z] failed to mount overlay: no such device storage-driver=overlay
ERRO[2024-02-02T10:11:49.457974239Z] Failed to built-in GetDriver graph devicemapper /var/lib/docker
WARN[2024-02-02T10:11:49.473057658Z] Your kernel does not support cgroup memory limit
WARN[2024-02-02T10:11:49.473181863Z] Your kernel does not support CPU realtime scheduler
WARN[2024-02-02T10:11:49.473219064Z] Unable to find blkio cgroup in mounts
WARN[2024-02-02T10:11:49.473256266Z] Unable to find cpuset cgroup in mounts
WARN[2024-02-02T10:11:49.473291667Z] Unable to find pids cgroup in mounts
INFO[2024-02-02T10:11:49.474916334Z] stopping healthcheck following graceful shutdown module=libcontainerd
INFO[2024-02-02T10:11:49.474925734Z] stopping event stream following graceful shutdown error="context canceled" module=libcontainerd namespace=plugins.moby
Tags (2)
iamramcharan
I am using the default BSP that comes with s32g
Bio_TICFSL
Which BSP are you using? apparently is not supported by kernel. However with docker is better you decompressed all in the host then upload to the S32G.
