Thank you very much for your reply.
I have solved this problem! The problem is version mismatch。
I'll list the solutions:
1. Find the corresponding eb tresos version from the RTD you are using.
for example:
open this file
2. Install the corresponding eb tresos.
3. NOTE:
You must Activate the eb tresos with Corresponding activation code even if other versions of eb tresos has been already activated.
4. copy all "<mod>_TS_T40D11M40I2R0" directories and .JAR files from C:\NXP\SW32G_RTD_4.4_4.0.2_HF02\eclipse\plugins to the "<Tresos Install Path>\plugins" directory.
