build the Bootloader for S32R45 failed
10,640 次查看
aiweixin
1. edit the D:/NXP/Platform_Software_Integration_S32R45_2022_03/code/framework/realtime/swc/bootloader/platforms/S32R45/build/launch.bat file, by replacing the default paths with the actual paths on my local host.
2. execute launch.bat, but failed.
标记 (2)
10,532 次查看
petervlna
if you does not set environment variables for cygwin, it will report errors.
Refer to the attachments to see how to set cygwin paths.
Peter
6 回复数
10,533 次查看
petervlna
Peter
10,526 次查看
aiweixin
Hi Peter,
    Thank you for your idea, it's very very useful.
Best regards!
10,593 次查看
petervlna
our RADAR team is asking for the name of your company in order to be able to support you.
Peter
10,584 次查看
aiweixin
Hi Peter,
    I have send the info to you separately.
10,549 次查看
petervlna
Thank you,
We have analyzed your query and RADAR team will support your issue.
We are analyzing it at this moment and feedback you ASAP.
Peter
10,604 次查看
petervlna
I have asked RADAR expert for feedback.
Peter
