S32k118evb RGB LED components
2,001件の閲覧回数
ALKAREEM
I have the S32K118evb,
I want to use the RGB LED on the board so that I can send the different values of the R, G, and B components to the RGB LED so that I can get the corresponding color to these components,
How can I do this and where to start???
for example, I want to send [ 5, 10, 255],  for [R, G, B]
I can turn the RGB LED on and off but,  how can I control the intensity of each color component
Thanks in advanced
2 返答(返信)
1,991件の閲覧回数
VaneB
Hi @ALKAREEM
You can control the brightness of the LED with the PWM mode of the FlexTimer module. We have available examples of this implementation in the two software we offer for the S32K1 devices, attached to my answer are the links to download them.
Real-Time Drivers for S32K1
S32 SDK for S32K1xx
B.R.
VaneB
1,948件の閲覧回数
ALKAREEM
I will try it, Thank you so much
