S32K14x frequency requirement
1,683件の閲覧回数
Mohit_Manvar
Hello experts,
I am using the S32K342EVB board. In which I am using FTM_PWM for PWM output generation. My Core frequency is 48 Mhz.
I want 6.144MHz frequency but getting 6.87MHz.
below is reference of configuration.
Help me to get required frequency.
タグ(1)
5 返答(返信)
1,659件の閲覧回数
VaneB
Hi @Mohit_Manvar
Could you share your clock configurations and an image of your PWM showing the frequency?
B.R.
VaneB
1,646件の閲覧回数
Mohit_Manvar
Hi @VaneB
please find screenshots below:
Clock Configuration
Frequency snapshot
Note: I am using S32 design studio for developing pwm freq.
peripheral -> FTM_PWM
1,584件の閲覧回数
VaneB
Hi @Mohit_Manvar
If you decrease the expected frequency, it has the same behavior?
Also, how are you measuring the signal?
1,574件の閲覧回数
Mohit_Manvar
Hello @VaneB,
Yes, I'm facing same issue on decreasing frequency.
I'm not getting exact frequency as per input.
I'm measuring output via oscilloscope by connecting on Headers of eval board.
1,561件の閲覧回数
VaneB
Hi @Mohit_Manvar
Could you share images of your tests?
