S32K118_PWR Mode_switch_VLPSA_Abort Issue
2,908件の閲覧回数
Kurubara
Hi Team,
                   Im facing Issue Like When im Switching from the VLPR to VLPs Power Mode Im Not able to Switch the Sleep State to DeepSleep State Due to VLPSA Bit Was Set 1 As Information Mention In the S32K1XX Micro Reference Manual
Very Low Power Stop Aborted
When set, this read-only status bit indicates an interrupt occurred during the previous stop mode entry
sequence, preventing the system from entering that mode. This field is cleared by reset or by hardware at
the beginning of any stop mode entry sequence and is set if the sequence was aborted.
NOTE: This bit will not get set if STOP1/STOP2 get aborted.
0 The previous stop mode entry was successful.
1 The previous stop mode entry was aborted
As Mentioned Above State Was Setting How Could I Identify the Where Exactly The Status Read from the Interrupt.
Could Please the Below Attached Snippet
2,687件の閲覧回数
danielmartynek
HI @Kurubara,
The SDK is a legacy SW that is no longer supported.
Please use RTD.
You need to have compatible S32DS IDE.
BR, Daniel
7 返答(返信)
2,825件の閲覧回数
danielmartynek
Hi @Kurubara,
Please disable all peripherals that are not used in VLPS mode.
For example, set the FlexCAN module to Module Disable mode.
Next, turn off all source clocks except SIRC and LPO.
Only after completing these steps should the system enter VLPS.
BR, Daniel
2,821件の閲覧回数
Kurubara
Hi Whatever Mention Same Reference of Application Note i Implemented Can check this was My Implementation both Sleep and Wakeup Sequence
void Enter_VLPS_Mode (void)
status_t retValue;
Turn_OFF_MODULE_POWER_ENABLE();
Accelerometer_Set_Low_Power_Mode (&ACC_Info);
// Delay_mSec(20);
Turn_OFF_AUX_BAT_MON_EN();
Turn_OFF_MAIN_BAT_MON_EN();
Turn_ON_LEVEL_TRANS_OE ();
Turn_ON_USB_FORCE_BOOT ();
INT_SYS_DisableIRQ(ADC0_IRQn);
INT_SYS_DisableIRQ(CAN0_ORed_0_31_MB_IRQn);
INT_SYS_DisableIRQ(CAN0_ORed_Err_Wakeup_IRQn);
INT_SYS_DisableIRQ(LPIT0_IRQn);
INT_SYS_DisableIRQ(LPUART1_RxTx_IRQn);
INT_SYS_DisableIRQ(LPUART0_RxTx_IRQn);
// INT_SYS_DisableIRQ(LPI2C0_Master_Slave_IRQn);
INT_SYS_DisableIRQ(FTFC_IRQn);
// INT_SYS_DisableIRQ(PORT_IRQn);
CAN_DeInit();
Pit_DeInit();
// LPI2C_DeInit();
UART_DeInit();
Turn_ON_Green_LED_1();
Turn_ON_Green_LED_2();
INT_SYS_ClearPending(ADC0_IRQn);
INT_SYS_ClearPending(CAN0_ORed_0_31_MB_IRQn);
INT_SYS_ClearPending(CAN0_ORed_Err_Wakeup_IRQn);
INT_SYS_ClearPending(LPIT0_IRQn);
INT_SYS_ClearPending(LPUART1_RxTx_IRQn);
INT_SYS_ClearPending(LPUART0_RxTx_IRQn);
INT_SYS_ClearPending(FTFC_IRQn);
RTC_SetAlarmAfterPeriod (Configured_Heartbeat_Frequency,0,0);
// status_t Status;
// Status = RTC_DRV_GetNextAlarmTime(RTCTIMER1, &AlarmTime);
//Delay_mSec(5000);
Accelerometer_Read_Data(&ACC_Info);
PINS_DRV_ClearPortIntFlagCmd(PORTD);
INT_SYS_ClearPending(PORT_IRQn);
// WDOG->CNT = 0xD928C520; // Unlock
// //WDOG_CNT = 0xD928C520;
// //WDOG->CS = WDOG_CS_CMD32EN_MASK | WDOG_CS_CLK_LPO_MASK;
// WDOG->CS &= ~WDOG_CS_INT_MASK; // Disable WDOG interrupt
// INT_SYS_ClearPending(WDOG_IRQn);
// INT_SYS_DisableIRQ(WDOG_IRQn);
// //SMC->PMPROT = SMC_PMPROT_AVLP_MASK;
// disable_clock_monitors();
// scg_configure_freq_for_VLPR();
retValue = POWER_SYS_SetMode(VLPR, POWER_MANAGER_POLICY_AGREEMENT);
if (retValue == STATUS_SUCCESS)
while (SMC->PMSTAT != 0x04);
// Disable all GPIO interrupts
for (int i = 0; i < 32; i++)
PORTA->PCR[i] &= ~PORT_PCR_IRQC_MASK;
PORTB->PCR[i] &= ~PORT_PCR_IRQC_MASK;
PORTC->PCR[i] &= ~PORT_PCR_IRQC_MASK;
PORTD->PCR[i] &= ~PORT_PCR_IRQC_MASK;
PORTE->PCR[i] &= ~PORT_PCR_IRQC_MASK;
// Clear flags
PORTA->ISFR = 0xFFFFFFFF;
PORTB->ISFR = 0xFFFFFFFF;
PORTC->ISFR = 0xFFFFFFFF;
PORTD->ISFR = 0xFFFFFFFF;
PORTE->ISFR = 0xFFFFFFFF;
// Clear NVIC
// /* Prepare deep sleep */
// PMC->REGSC |= PMC_REGSC_BIASEN_MASK;
// S32_SCB->SCR |= S32_SCB_SCR_SLEEPDEEP_MASK;
//// SMC->PMCTRL = SMC_PMCTRL_STOPM(0b010);
// Clear_All_Wake_Sources();
//__disable_irq();
//POWER_SYS_SetMode(VLPS, POWER_MANAGER_POLICY_AGREEMENT);
retValue = POWER_SYS_SetMode(VLPS, POWER_MANAGER_POLICY_AGREEMENT);
// if (!POWER_SYS_GetCurrentMode() == POWER_MANAGER_VLPS)
STANDBY();
// After Wakeup initialize all the disabled peripherals.
// Enter_VLPR_Mode ();
// CAN_Init();
// Pit_Init();
// LPI2C_INIT();
// LPUART_Initialization();
// INT_SYS_EnableIRQ(ADC0_IRQn);
// INT_SYS_EnableIRQ(CAN0_ORed_0_31_MB_IRQn);
// INT_SYS_EnableIRQ(CAN0_ORed_Err_Wakeup_IRQn);
// INT_SYS_EnableIRQ(LPIT0_IRQn);
// INT_SYS_EnableIRQ(LPUART1_RxTx_IRQn);
// INT_SYS_EnableIRQ(LPUART0_RxTx_IRQn);
// INT_SYS_EnableIRQ(LPI2C0_Master_Slave_IRQn);
// INT_SYS_EnableIRQ(FTFC_IRQn);
// Turn_ON_MODULE_POWER_ENABLE();
void Restore_From_VLPS_To_RUN(void)
// Go back to RUN Mode
POWER_SYS_SetMode(RUN, POWER_MANAGER_POLICY_AGREEMENT);
while (SMC->PMSTAT != 0x01); // Ensure we are in RUN
// Restore the RUN cocke.
CLOCK_SYS_UpdateConfiguration(0U, CLOCK_MANAGER_POLICY_AGREEMENT);
// Bring the disabled things back.
Turn_ON_AUX_BAT_MON_EN();
Turn_ON_MAIN_BAT_MON_EN();
Turn_OFF_LEVEL_TRANS_OE();
Turn_OFF_USB_FORCE_BOOT ();
// Re initialize the modules we have de-inititalized.
CAN_Init();
Pit_Init(); /* or LPIT_Init, be consistent with what you use */
LPI2C_INIT();
ADC_Initialization();
CSEC_Init();
RTC_Init(); /* if you need it active right after wake */
Accelerometer_Init(&ACC_Info);
// Re enable the IRQ's we disabled.
INT_SYS_EnableIRQGlobal();
2,811件の閲覧回数
danielmartynek
The VLPSA flag can be triggered when one of the peripherals, such as FlexCAN, fails to acknowledge the transition to VLPS mode.
It also appears that you are using very old drivers, likely the legacy SDK drivers, which are no longer supported. I strongly recommend migrating to the latest RTD drivers.
To debug this issue, open POWER_SYS_SetMode() and locate the WFI instruction in the corresponding sub‑function. Set a breakpoint at that point. When the core halts on the WFI, inspect all relevant clock and peripheral registers.
2,786件の閲覧回数
Kurubara
Hi danielmartynak,
thank u for Quick Response, For S32K118, RFM‑quality software support is provided by NXP Real‑Time Drivers (RTD) v3.0.0. This release includes full quality and safety packages and is the recommended and supported solution for production‑grade applications, including correct VLPS handling. Legacy S32SDK drivers are no longer supported for RFM use. which RTD Version I Need to Use For RFM Quality.
2,780件の閲覧回数
danielmartynek
Hi @Kurubara,
You can use the latest S32K1_S32M24X Real Time Drivers AUTOSAR R21-11 Version 3.0.0 QLP06.
2,750件の閲覧回数
Kurubara
Hi @Daniel,
currently I'm Using SDK2.2 Version for S32K118 RFM there is not Exact RTD version We are using, Its only Flex CAN or Any Other peripherals also. Can i know the List of peripherals
2,688件の閲覧回数
danielmartynek
HI @Kurubara,
Please use RTD.
BR, Daniel
%3CLINGO-SUB%20id%3D%22lingo-sub-2345129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K118_PWR%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81_VLPSA_%E4%B8%AD%E6%AD%A2%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2345129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3EVLPR%E3%81%8B%E3%82%89VLPs%E9%9B%BB%E6%BA%90%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81S32K1XX%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%83%85%E5%A0%B1%E3%81%AB%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABVLPSA%E3%83%93%E3%83%83%E3%83%88%E3%81%8C1%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%82%92%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BD%8E%E3%81%84%E9%9B%BB%E5%8A%9B%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%8C%E4%B8%AD%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%B0%82%E7%94%A8%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E5%89%8D%E5%9B%9E%E3%81%AE%E5%81%9C%E6%AD%A2%E3%83%A2%E3%83%BC%E3%83%89%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E4%B8%AD%E3%81%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%81%9D%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%AE%E3%82%92%E9%98%B2%E3%81%8E%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E5%81%9C%E6%AD%A2%E3%83%A2%E3%83%BC%E3%83%89%E9%96%8B%E5%A7%8B%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AE%E9%96%8B%E5%A7%8B%E4%BD%8D%E7%BD%AE%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%8C%E4%B8%AD%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9ASTOP1%2FSTOP2%E3%81%8C%E4%B8%AD%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E0%20%E5%89%8D%E5%9B%9E%E3%81%AE%E5%81%9C%E6%AD%A2%E3%83%A2%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%201.%20%E5%89%8D%E5%9B%9E%E3%81%AE%E5%81%9C%E6%AD%A2%E3%83%A2%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%E3%81%8C%E4%B8%AD%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%8A%B6%E6%85%8B%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E6%AD%A3%E7%A2%BA%E3%81%AB%E7%89%B9%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8B%E8%A8%98%E3%81%AE%E6%B7%BB%E4%BB%98%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2345129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ES32K1%E7%94%A8S32%20SDK%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K118_PWR%20Mode_switch_VLPSA_Abort%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E7%A7%81%E3%81%8C%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%9F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E5%90%8C%E3%81%98%E5%8F%82%E7%85%A7%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%81%A8%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E7%A7%81%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20void%20Enter_VLPS_Mode%20(void)%3CBR%20%2F%3E%E3%83%A4%E3%83%BC%E3%82%B8%E3%83%A5%3CBR%20%2F%3Estatus_t%20retValue%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20Turn_OFF_MODULE_POWER_ENABLE()%3B%3CBR%20%2F%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%A8%88%E3%81%AE%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%EF%BC%88%26amp%3BACC_Info%EF%BC%89%3CBR%20%2F%3E%20%2F%2F%20Delay_mSec(20)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20Turn_OFF_AUX_BAT_MON_EN()%3B%3CBR%20%2F%3E%20Turn_OFF_MAIN_BAT_MON_EN()%3B%3CBR%20%2F%3E%20Turn_ON_LEVEL_TRANS_OE()%3B%3CBR%20%2F%3E%20Turn_ON_USB_FORCE_BOOT()%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20INT_SYS_DisableIRQ(ADC0_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_DisableIRQ(CAN0_ORed_0_31_MB_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_DisableIRQ(CAN0_ORed_Err_Wakeup_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_DisableIRQ(LPIT0_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_DisableIRQ(LPUART1_RxTx_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_DisableIRQ(LPUART0_RxTx_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_DisableIRQ(LPI2C0_Master_Slave_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_DisableIRQ(FTFC_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_DisableIRQ(PORT_IRQn)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20CAN_DeInit()%3B%3CBR%20%2F%3E%20Pit_DeInit()%3B%3CBR%20%2F%3E%20%2F%2F%20LPI2C_DeInit()%3B%3CBR%20%2F%3E%20UART_DeInit()%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20Turn_ON_Green_LED_1()%3B%3CBR%20%2F%3E%20Turn_ON_Green_LED_2()%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20INT_SYS_ClearPending(ADC0_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_ClearPending(CAN0_ORed_0_31_MB_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_ClearPending(CAN0_ORed_Err_Wakeup_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_ClearPending(LPIT0_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_ClearPending(LPUART1_RxTx_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_ClearPending(LPUART0_RxTx_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_ClearPending(FTFC_IRQn)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20RTC_SetAlarmAfterPeriod%20(Configured_Heartbeat_Frequency%2C0%2C0)%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20status_t%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20RTC_DRV_GetNextAlarmTime(RTCTIMER1%2C%20%26amp%3BAlarmTime)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%E9%81%85%E5%BB%B6%E6%99%82%E9%96%93%EF%BC%885000%E3%83%9F%E3%83%AA%E7%A7%92%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%20Accelerometer_Read_Data(%26amp%3BACC_Info)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20PINS_DRV_ClearPortIntFlagCmd(PORTD)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20INT_SYS_ClearPending(PORT_IRQn)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20WDOG-%26gt%3BCNT%20%3D%200xD928C520%3B%20%2F%2F%20%E3%83%AD%E3%83%83%E3%82%AF%E8%A7%A3%E9%99%A4%3CBR%20%2F%3E%2F%2F%20%2F%2FWDOG_CNT%20%3D%200xD928C520%3B%3CBR%20%2F%3E%20%2F%2F%20%2F%2FWDOG-%26gt%3BCS%20%3D%20WDOG_CS_CMD32EN_MASK%20%7C%20WDOG_CS_CLK_LPO_MASK%3B%3CBR%20%2F%3E%20%2F%2F%20WDOG-%26gt%3BCS%20%26amp%3B%3D%20~WDOG_CS_INT_MASK%3B%20%2F%2F%20WDOG%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%2F%2F%20INT_SYS_ClearPending(WDOG_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_DisableIRQ(WDOG_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20%2F%2FSMC-%26gt%3BPMPROT%20%3D%20SMC_PMPROT_AVLP_MASK%3B%3CBR%20%2F%3E%20%2F%2F%20disable_clock_monitors()%3B%3CBR%20%2F%3E%20%2F%2F%20scg_configure_freq_for_VLPR()%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20retValue%20%3D%20POWER_SYS_SetMode(VLPR%2C%20POWER_MANAGER_POLICY_AGREEMENT)%3B%3CBR%20%2F%3E%20if%20(retValue%20%3D%3D%20STATUS_SUCCESS)%3CBR%20%2F%3E%E3%83%A4%E3%83%BC%E3%82%B8%E3%83%A5%3CBR%20%2F%3Ewhile%20(SMC-%26gt%3BPMSTAT%20!%3D%200x04)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEGPIO%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3Efor%20(int%20i%20%3D%200%3B%20i%20%26lt%3B%2032%3B%20i%2B%2B)%3CBR%20%2F%3E%E3%83%A4%E3%83%BC%E3%82%B8%E3%83%A5%3CBR%20%2F%3EPORTA-%26gt%3BPCR%5Bi%5D%20%26amp%3B%3D%20~PORT_PCR_IRQC_MASK%3B%3CBR%20%2F%3E%20PORTB-%26gt%3BPCR%5Bi%5D%20%26amp%3B%3D%20~PORT_PCR_IRQC_MASK%3B%3CBR%20%2F%3E%20PORTC-%26gt%3BPCR%5Bi%5D%20%26amp%3B%3D%20~PORT_PCR_IRQC_MASK%3B%3CBR%20%2F%3E%20PORTD-%26gt%3BPCR%5Bi%5D%20%26amp%3B%3D%20~PORT_PCR_IRQC_MASK%3B%3CBR%20%2F%3E%20PORTE-%26gt%3BPCR%5Bi%5D%20%26amp%3B%3D%20~PORT_PCR_IRQC_MASK%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%3CBR%20%2F%3EPORTA-%26gt%3BISFR%20%3D%200xFFFFFFFF%3B%3CBR%20%2F%3E%20PORTB-%26gt%3BISFR%20%3D%200xFFFFFFFF%3B%3CBR%20%2F%3E%20PORTC-%26gt%3BISFR%20%3D%200xFFFFFFFF%3B%3CBR%20%2F%3E%20PORTD-%26gt%3BISFR%20%3D%200xFFFFFFFF%3B%3CBR%20%2F%3E%20PORTE-%26gt%3BISFR%20%3D%200xFFFFFFFF%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20NVIC%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%3CBR%20%2F%3EINT_SYS_ClearPending(PORT_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_DisableIRQ(PORT_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%20%2F*%20%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%81%AE%E6%BA%96%E5%82%99%20*%2F%3CBR%20%2F%3E%20%2F%2F%20PMC-%26gt%3BREGSC%20%7C%3D%20PMC_REGSC_BIASEN_MASK%3B%3CBR%20%2F%3E%20%2F%2F%20S32_SCB-%26gt%3BSCR%20%7C%3D%20S32_SCB_SCR_SLEEPDEEP_MASK%3B%3CBR%20%2F%3E%20%2F%2F%2F%2F%20SMC-%26gt%3BPMCTRL%20%3D%20SMC_PMCTRL_STOPM(0b010)%3B%3CBR%20%2F%3E%20%2F%2F%20Clear_All_Wake_Sources()%3B%3CBR%20%2F%3E%20%2F%2F__disable_irq()%3B%3CBR%20%2F%3E%20%2F%2FPOWER_SYS_SetMode(VLPS%2C%20POWER_MANAGER_POLICY_AGREEMENT)%3B%3CBR%20%2F%3E%20retValue%20%3D%20POWER_SYS_SetMode(VLPS%2C%20POWER_MANAGER_POLICY_AGREEMENT)%3B%3CBR%20%2F%3E%20if%20(retValue%20%3D%3D%20STATUS_SUCCESS)%3CBR%20%2F%3E%E3%83%A4%E3%83%BC%E3%82%B8%E3%83%A5%3CBR%20%2F%3E%2F%2F%20if%20(!POWER_SYS_GetCurrentMode()%20%3D%3D%20POWER_MANAGER_VLPS)%3CBR%20%2F%3E%20%2F%2F%20%E3%83%A4%E3%83%9F%E3%83%B3%E3%83%BB%3CBR%20%2F%3E%2F%2F%3CBR%20%2F%3E%20%2F%2F%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%BE%85%E6%A9%9F%E3%81%99%E3%82%8B%EF%BC%88%EF%BC%89%3B%3CBR%20%2F%3E%20%2F%2F%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2F%20Enter_VLPR_Mode()%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20CAN_Init()%3B%3CBR%20%2F%3E%20%2F%2F%20Pit_Init()%3B%3CBR%20%2F%3E%20%2F%2F%20LPI2C_INIT()%3B%3CBR%20%2F%3E%20%2F%2F%20LPUART_Initialization()%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_EnableIRQ(ADC0_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_EnableIRQ(CAN0_ORed_0_31_MB_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_EnableIRQ(CAN0_ORed_Err_Wakeup_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_EnableIRQ(LPIT0_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_EnableIRQ(LPUART1_RxTx_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_EnableIRQ(LPUART0_RxTx_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_EnableIRQ(LPI2C0_Master_Slave_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20INT_SYS_EnableIRQ(FTFC_IRQn)%3B%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20Turn_ON_MODULE_POWER_ENABLE()%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%20void%20Restore_From_VLPS_To_RUN(void)%3CBR%20%2F%3E%E3%83%A4%E3%83%BC%E3%82%B8%E3%83%A5%3CBR%20%2F%3E%2F%2F%20%E5%AE%9F%E8%A1%8C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E6%88%BB%E3%82%8B%3CBR%20%2F%3EPOWER_SYS_SetMode(RUN%2C%20POWER_MANAGER_POLICY_AGREEMENT)%3B%3CBR%20%2F%3E%20while%20(SMC-%26gt%3BPMSTAT%20!%3D%200x01)%3B%20%2F%2F%20RUN%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2F%20RUN%E3%82%B3%E3%83%83%E3%82%AF%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ECLOCK_SYS_UpdateConfiguration(0U%2C%20CLOCK_MANAGER_POLICY_AGREEMENT)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E5%85%83%E3%81%AB%E6%88%BB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ETurn_ON_MODULE_POWER_ENABLE()%3B%3CBR%20%2F%3E%20Turn_ON_AUX_BAT_MON_EN()%3B%3CBR%20%2F%3E%20Turn_ON_MAIN_BAT_MON_EN()%3B%3CBR%20%2F%3E%20Turn_OFF_LEVEL_TRANS_OE()%3B%3CBR%20%2F%3E%20Turn_OFF_USB_FORCE_BOOT()%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%9F%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E5%86%8D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ECAN_Init()%3B%3CBR%20%2F%3E%20Pit_Init()%3B%20%2F*%20%E3%81%BE%E3%81%9F%E3%81%AF%20LPIT_Init%E3%80%82%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E4%B8%80%E8%B2%AB%E6%80%A7%E3%82%92%E6%8C%81%E3%81%9F%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20*%2F%3CBR%20%2F%3E%20LPI2C_INIT()%3B%3CBR%20%2F%3E%20LPUART_Initialization()%3B%3CBR%20%2F%3E%20ADC_Initialization()%3B%3CBR%20%2F%3E%20CSEC_Init()%3B%3CBR%20%2F%3E%20RTC_Init()%3B%20%2F*%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E7%9B%B4%E5%BE%8C%E3%81%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%20*%2F%3CBR%20%2F%3E%20Accelerometer_Init(%26amp%3BACC_Info)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9FIRQ%E3%82%92%E5%86%8D%E5%BA%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EINT_SYS_EnableIRQ(ADC0_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_EnableIRQ(CAN0_ORed_0_31_MB_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_EnableIRQ(CAN0_ORed_Err_Wakeup_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_EnableIRQ(LPIT0_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_EnableIRQ(LPUART1_RxTx_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_EnableIRQ(LPUART0_RxTx_IRQn)%3B%3CBR%20%2F%3E%20INT_SYS_EnableIRQ(FTFC_IRQn)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20INT_SYS_EnableIRQGlobal()%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%7D%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K118_PWR%20Mode_switch_VLPSA_Abort%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EVLPSA%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AF%E3%80%81FlexCAN%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%8CVLPS%E3%83%A2%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%8F%A4%E3%81%84%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E5%AF%BE%E8%B1%A1%E5%A4%96%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%9F%E6%97%A7%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AESDK%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E6%9C%80%E6%96%B0%E3%81%AERTD%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%E3%82%92%E5%BC%B7%E3%81%8F%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81POWER_SYS_SetMode()%20%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%82%B5%E3%83%96%E9%96%A2%E6%95%B0%E5%86%85%E3%81%AE%20WFI%20%E5%91%BD%E4%BB%A4%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%81%AE%E5%9C%B0%E7%82%B9%E3%81%AB%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%B3%E3%82%A2%E3%81%8CWFI%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A8%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E6%A4%9C%E6%9F%BB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K118_PWR%20Mode_switch_VLPSA_Abort%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261357%22%20target%3D%22_blank%22%3E%40Kurubara%3C%2FA%3E%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3EVLPS%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81FlexCAN%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E7%84%A1%E5%8A%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%AC%A1%E3%81%AB%E3%80%81SIRC%E3%81%A8LPO%E4%BB%A5%E5%A4%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%A7%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AFVLPS%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%AF%E3%81%84%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%E3%80%81%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K118_PWR%20Mode_switch_VLPSA_Abort%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F2671%22%20target%3D%22_blank%22%3E%40Daniel%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3CBR%20%2F%3E%E7%8F%BE%E5%9C%A8%E3%80%81S32K118%20RFM%20%E3%81%AB%E3%81%AF%20SDK2.2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20RTD%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82Flex%20CAN%20%E3%82%84%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE**%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB**%E3%82%82%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K118_PWR%20Mode_switch_VLPSA_Abort%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261357%22%20target%3D%22_blank%22%3E%40Kurubara%3C%2FA%3E%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E6%96%B0%E3%81%AES32K1_S32M24X%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90AUTOSAR%20R21-11%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82QLP06%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH2%20class%3D%22page-sub-heading%22%20id%3D%22toc-hId--467824618%22%20id%3D%22toc-hId--467858322%22%20id%3D%22toc-hId--467858322%22%20id%3D%22toc-hId--467858322%22%3E%26nbsp%3B%3C%2FH2%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K118_PWR%20Mode_switch_VLPSA_Abort%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81danielmartynak%E3%81%95%E3%82%93%E3%80%82%3CBR%20%2F%3E%E8%BF%85%E9%80%9F%E3%81%AA%E3%81%94%E5%AF%BE%E5%BF%9C%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82S32K118%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81RFM%E5%93%81%E8%B3%AA%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AFNXP%20Real-Time%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20(RTD)%20v3.0.0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AA%E5%93%81%E8%B3%AA%E3%81%8A%E3%82%88%E3%81%B3%E3%82%BB%E3%83%BC%E3%83%95%E3%83%86%E3%82%A3%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%81%A9%E5%88%87%E3%81%AAVLPS%E5%87%A6%E7%90%86%E3%82%92%E5%90%AB%E3%82%80%E3%80%81%E7%94%9F%E7%94%A3%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%90%91%E3%81%91%E3%81%AB%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%E5%BE%93%E6%9D%A5%E3%81%AES32SDK%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81RFM%E3%81%A7%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82RFM%E5%93%81%E8%B3%AA%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%A9%E3%81%AERTD%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K118_PWR%20Mode_switch_VLPSA_Abort%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261357%22%20target%3D%22_blank%22%3E%40Kurubara%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AESDK%E3%81%AF%E6%97%A7%E5%BC%8F%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3ERTD%E3%82%92%E3%81%94%E4%BD%BF%E7%94%A8%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8BS32DS%20IDE%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%E3%80%81%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
