Regarding RGB Image Conversion
curdcynthia1
Hello Everyone,
I have NXP SBC-S32V234 Board and S32 DS for Vision 2018.R1 software.
Now I want to convert RGB image to RGB by creating a new kernel.
My project Goal:
Load an RGB Image and display the same RGB image on HDMI
Setting i have done while creating my own kernel project:
1.Input setting of kernel:
2.Output setting  of kernel project is same as input setting.
In my apex program project i have done the following settings:
What is the probable reason of this distortion.It seems like my own created kernel is not working properly.Where should i do modification of my kernel and what modification should i do to get the exact same input image at output???
Maureen A. Powers
TalktoWendys
bpe
Please be aware, that currently we provide support to APEX, ISP and related software  only via Support Cases.
This Community is not appropriate to discuss question of this kind.
Platon
curdcynthia1
Thank you
Very important tips you share with us keep sharing more. Thank you.
USPayServ Login
