Re: Require procedure for using the SDK RTM V3.0.3
1,178 次查看
vijaysubramanian
while installing the KSDK 1.1.0,
Following error is encountered, Can you pls help to find solution..
An error occurred while collecting items to be installed
session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=null --> [R]com.freescale.processorexpert.ksdk-1.1.0.sp_root 1.0.0.b141204, action=).
The required Touchpoint: com.freescale.updater.touchpoint 1.0.0 touchpoint for the collect action is not included in the installation manager configuration.
0 回复数
