How to know lwip stack version in different sdk?
4,061 次查看
rajani_sureja33
I am using s32 design studio power architecture version 2017.R1 ide for development for mpc5748g controller. It has different sdk packages. So which one is the latest one that one should i use for development. and  how to know its lwip stack version info?
Rajani Sureja
Embedded S/W Engineer
4 回复数
3,788 次查看
stanish
There is a text file that lists SW content in a SDK:
"<S32DS ROOT>\S32DS\S32_SDK_S32PA_RTM_2.0.0\SW-Content-Register-S32-SDK_Power_Architecture.txt"
See the text file snippet below:
TCP/IP stack Description: Adaptation layer to S32 SDK for Power Architecture and FreeRTOS of LWIP stack
                            Version: 1.8.0
                            Author: NXP
                            License: NXP EULA
                            Format: source code
LWIP                  Description: LWIP stack
                            Version: STABLE_2_0_2
                            Author: Adam Dunkels at the Computer and Networks Architectures (CNA) lab at the Swedish Institute of Computer Science (SICS)
                            License: BSD like [see /middleware/tcpip/lwip/COPYING file]
                            Format: source code
WolfSSL                  Description: wolfSSL embedded SSL library
                            Version: 3.11.0
                            Author: wolfSSL
                            License: GNU General Public License v2.0
                            Format: source code
Stan
3,788 次查看
rajani_sureja33
Thank you Silva,
Would you explained why there are so many sdk version(EAR, RTM meaning) and which one (stable release) should we use for development?
Rajani
3,788 次查看
jiri_kral
Hi Rajani,
For development you can use latest RTM version (2.0.0).
Jiri
3,787 次查看
rajani_sureja33
Thank you Jiri:)
