how to add a macro function in symbols with S21DS?
1,055件の閲覧回数
JhonYF
As below,I want add a macro function named "Error_Handler()", the value is aseembly code,but it can not work and result the IDE report an error"expected string literal before 'BKPT",I don not konw what to do next , hope for help  ,thanks!
“Error_Handler()” is the macro function“Error_Handler()” is the macro function
タグ(1)
3 返答(返信)
1,026件の閲覧回数
VaneB
Hi @JhonYF
I tried to reproduce your issue and got the same error as you. This error does not appear when you use the __asm__("BKPT") directly in the code, so it looks like the problem is macro.
Please refer to the community post below, which provides recommendations that will be useful for you.
Using Assembler Macros in C
B.R.
VaneB
962件の閲覧回数
JhonYF
@VaneB thanks for reply,but I still can not make it
1,004件の閲覧回数
JhonYF
Thanks for reply,but I still didn't make it
