gcc not found in path , cannot open linker file
2,151件の閲覧回数
moonlight
hello,
      could you please help me to solve this problem?
      I imported the example project from SDK in S32 design studio and build it.
      problems show 4 errors in the  follow:
console window:
タグ(1)
1,958件の閲覧回数
stanish
Thanks for reporting this issue.
Can you please indicate which MCU are you targeting?
Can you share your test project with us?
This will help us to reproduce and resolve the issue much faster.
Thank you!
Stan
