error during installation (S32DS for PA 1.1)
taekyoungkim
I have faced error during installation (S32DS PA1.1)
The error message is like below...
Would you please share with me how to solve this problem?
martin_kovar
have you admin rights at your computer? Are you sure that firewall does not block the communication with activation server?
Did you also try offline activation?
Martin
taekyoungkim
Yes, I have admin rights.
Also offline activation shows same result when I pressed xml save button.
What is the meaning of FNP error code? Can you clarify it?
For activation, what does the S32DS program do?
martin_kovar
I am not license expert, so I cannot tell you what is the internal process of the activation. I will contact someone, who can help you more with your issue.
Martin
martin_kovar
could you please try following activation key?
0996-86F5-0571-7E44
I contacted  TomasPaez, so he will handle your issue as soon as possible.
Martin
