debug Error in services launch sequence:gdb server unable to start
qinyun_sun
There appears to be an issue with your network settings.
The gdb server was unable to start a required server component.Please contact technical support.
my pc system is windows 10  64bit
we have the same problem, when use devkit-mpc5744p (opensda) to flash the RBF file .
An error - while flashing the RBF file on devkit-mpc5744p
i do not understand the feedback from this:"The issue is that the computer name was incorrect in my /etc/hosts file (linux)." my pc is windows.
jiri_kral
Can you please share debug console output
or try to start gdb server from command line?
Jiri
