What is the meaning of , Direction: No Pin Routed?
samcs
What is the meaning of direction, No Pin Routed,
lukaszadrapa
Hi Sam,
this is the case when a pin function of a module allows both input and output configuration. Some functions are input or output only, some can be configured as needed. In case of ENET, here is an example:
Lukas
