Unicode problem
Unicode problem
qpeng
When I tried to configurate DDR and valiated it,there was an error message in log window as below,
(gdb) (gdb) (gdb) Python Exception <type 'exceptions.UnicodeDecodeError'> 'gbk' codec can't decode bytes in position 37-38: illegal multibyte sequence: Could not convert arguments to Python string.
Could you please help me on this problem?
Thanks & Best Regards
Qiang
mikedoidge
Could you please share the image of the configuration you created? It would help us to reproduce the issue.
Mike
