UJA1169A SBC middleware configuration question
993 次查看
samcs
I wonder what is the difference of the options of Watchdog mode Control , on UJA1169A SBC middleware configuration,
There are 3 options in ConfigTools of S32DS 3.4, Autonomous, TimeOut, Window.
I found when I selected Autonomous, seems the task scheduler works well,but TimeOut and Window options not work well.
Does anybody know the reason? thanks
976 次查看
danielmartynek
Hello @samcs,
This is explained in the datasheet of the SBC.
https://www.nxp.com/docs/en/data-sheet/UJA1169A.pdf
Section 7.2 Watchdog
Regadrs,
