SPI_CANSBC issue
SPI_CANSBC issue
Divya_123
Hi team, We are using S32 Design Studio, SPI Master as s32k312 microcontroller, trying to read and write data using CAN-SBC(TCAN1167) as slave. For this workspace we are using RTD 3.0.0.But unable to read and write. We have tested example code, and is working fine. But for the new slave CAN-SBC.We couldn't able to transmit and receive data from the slave. Can you share any working code for S32K312 and give some valuable instructions/suggestion
Divya_123
have any example code for CAN SBC TCAN1167
PetrS
I dont think so
BR, Petr
PetrS
what example did you refer to? If that was working then it would not be much difficult to adopt it to communicate it with your connected slave.
Check the connection, pin setting, SPI config to follow slave SPI protocol and measure SPI lines to know what is generated (transmitted/received).
BR, Petr
