SDK cannot be found when creating a new Application project on S32DS3.5
1,060 次查看
ukn
I recently installed S32DS3.5 and the attached image contains the  all the packages I installed along with S32DS. When I try to create an application project, I cannot see any SDK in it. Also, when I try to create a new project from example, I cannot see any examples. How do I get the SDK? should I install anything else?
986 次查看
VaneB
Hi @ukn
I ask you to please provide an image of the information provided in the installation details. This situation usually happens when it is not installed all the necessary packages or if you do not have the right version of these.
B.R.
VaneB
566 次查看
terry-1987
how you fix the issue?
987 次查看
VaneB
Hi @ukn
B.R.
VaneB
981 次查看
ukn
Hi @VaneB ,
I reinstalled the S32DS3.5 and the related packages and it fixed the issue.
